10-27-2023, 08:46 AM | #45 |
Rep 6
Software upgrade
A couple of days ago I had my wife's software updated on her 2019 330i
For some reason it has never been updated from new. I contacted BMW connected drive and they told me what to do. I tried what they told me but it didn't work. So had to book it into dealer. Dealer wanted £198 which I thought was a bit steep. When my wife collected car I only had to pay £98. Anyway I drove the car yesterday and noticed that the speed limit overrun on the head up display doesn't flash red anymore. Took car back in this morning for dealer to check it out and after road test they say it only flashes in white and not red. Other cars apparently only flash white. But I know it flashed in red. My M440i flashes red so it sounds like a lot of woful they are giving me. Anyone else have this problem and does yours flash red on overspeed. |
10-27-2023, 03:02 PM | #46 |
Rep 520
FWIW, not all LCI have 5G. If you spec the 5G hotspot, you get a 5G data only connection for your devices to use, but BMW ConnectedDrive still runs over a 4G LTE network. It’s cheaper that way since things like BMW Assist will run over VoLTE. Going forward as 5G NR becomes more widely available, the actual system will run over 5G.
2023 BMW M340i xDrive
2020 BMW 330i xDrive 2018 BMW X3 xDrive30i |
10-27-2023, 03:31 PM | #47 | |
Rep 24
Thanks again!!!! ((because I tested Google Maps right after upgrading to the new software version, I realize I did not test Waze with the new software. Maybe that would also have the guidance in the HUD now??? ))) |
toddwalton1331.50 |
10-27-2023, 03:44 PM | #48 |
Rep 24
by the way, after installing the latest software, I had 2 small issues:
-I could not select the automatic time setting (even if I ticked the box, nothing happened) -I could not get into the submenu on Climate Control Rules: was grey and could not be clicked on : After 2 days of driving, miraculously both have been solved today, like the RTTI for Mike330i..... So now everything looks back to normal. |
10-28-2023, 06:12 AM | #49 | |
Rep 110
My RTTI has continued to be extremely hit & miss. Generally I can do my 40 minute morning commute - with RTTI refusing to take part . However, the opposite commute in the afternoon will have RTTI present as soon as the car starts Unless I can guarantee that RTTI will not be working - there's no point going to the Dealer as the response would be the usual "we really need to see it showing the issue" - that I can fully understand. Bit pissed that the issue occurred with latest RSU - now wish I had dismissed the upgrade Regards, Mike. |
10-28-2023, 10:05 AM | #50 |
Rep 24
10-28-2023, 10:14 AM | #51 | |
Rep 1,799
As a general rule with any upgrades — I’d wait for a few months after release before considering an update; gives enough time to gauge reported issues from other users. |
toddwalton1331.50 mermar139.50 |
10-30-2023, 07:17 PM | #52 |
Rep 25
potential fix for those that are stuck , will try it later and see if it works
https://g80.bimmerpost.com/forums/sh....php?t=2044184 |
11-01-2023, 08:37 PM | #53 |
Rep 65
Drives: 2023 BMW M340i xDrive
11-02-2023, 07:42 AM | #54 |
Rep 354
Drives: 2023 M340i
11-02-2023, 09:40 AM | #55 | |
Rep 212
11-02-2023, 10:09 AM | #56 | |
Rep 1,655
I still don't know why any of you use BMW Maps at all when CarPay or Android Auto gives you the vastly superior Google Maps as an option. The features BMW is missing were standard in 2008 when it comes to next turn, lane selection, and live alternate routing, makes zero sense that you choose to live without it. |
11-02-2023, 10:23 AM | #57 | |
Rep 1,799
This all boils down to personal preference and OP is simply asking how to get the arrows for iDrive map. I’m surprised it doesn’t show up in iD8. |
ultrared93103.00 radarguy92.00 |
11-02-2023, 11:09 AM | #58 | |
Rep 1,655
Let's go through these one by one because I must be missing something when I try BMW Navigation: 1. Live Re-Routing: On Google Maps, you get a pop up that says "4 minutes slower" and a different colored line indicating the route you could take alternatively and it happens right on the screen, right on the map, in real time without the need to click anything. It's just right there in your field of vision. BMW Nav doesn't have this, correct? 2. Next Turn w/Exit Name + Distance: On Google Maps, you have a dedicated space on the display that tells you "10 miles to your next turn", has an arrow showing you it's a "right turn", and says "Exit 5 - Garden State Parkway". This detail with arrows and plain English is on the screen all the time, doesn't move around, doesn't pop in and out. BMW Nav doesn't have this, correct? 3. Exit Lane Guidance: On Google Maps, you have a dedicated space on the display that shows you what lane to be in at the time of exiting the road as well as all the other lanes you will encounter. BMW Nav doesn't have this, correct? 4. Dark Mode: On Google Maps, you can set the screen to always be black all the time, no distracting light colors ever, even in daytime. BMW Nav doesn't have this, correct? 5. Overhead Map View: On Google Maps, you get a more overhead view so you can see a lot more streets and crossroads that are approaching. BMW Nav doesn't have this correct? They've got some 3D view with a blue sky and clouds as if you are flying a plane, yes? |
11-02-2023, 11:40 AM | #59 | |
Rep 1,799
toddwalton1331.50 ultrared93103.00 |
11-02-2023, 11:44 AM | #60 | |
Rep 520
11-03-2023, 04:56 AM | #62 |
Rep 212
prjkthack - does this "Route preview" widget show anything other than compass? I haven't tried it when actually navigating, but in any other case it just shows an arrow pointing at the direction of travel.
11-03-2023, 07:41 AM | #63 |
Rep 520
Took a photo to show how lane guidance works in the gauge cluster while on a highway:
11-10-2023, 12:11 PM | #64 |
Rep 1
I know this has been said... But man, my car just updated on Wednesday. I dislike the new font, but I can deal with it.. what I cannot stand is how the font is different in the dash vs the nav screens. It's looks like an after thought now. I actually might look into downgrading because its that annoying to me .
Look at the 4's. Very annoying change. |
WernerM340IX7.50 |
11-10-2023, 12:15 PM | #65 |
Rep 1,799
11-10-2023, 04:05 PM | #66 |
Rep 520
I guess it depends on your situation. Having had a G20 with DAP since 2019, I’ve seen how the software updates have improved that system over the years. Now if I didn’t have it, I probably could care less bout software updates.
