08-05-2021, 01:52 PM | #1 |
Rep 5
What's the 330e like once the battery is depleted?
A significant part of my driving is local, however there are a few times per week when I have to drive past the electric range and the long distance trips once or twice a year.
Every time I've tested the 330e, it's had more than 30% charge so the electric motor was always engaged. What's the acceleration and power delivery like once the battery is depleted? Is it much worse than a 330i? Thanks in advance. |
08-05-2021, 02:23 PM | #2 |
Rep 1,354
According to everything I've seen/read, it's got the same motor out of a 320i, which means it will feel lethargic, especially when you consider the extra mass from the battery pack.
08-05-2021, 02:59 PM | #3 |
Rep 606
although that is true, my experience is that with simple brake regeneration, the power is fed directly back into the battery pack and accelerating is then done with electric power using as much gas during constant driving as possible.
I am really surprised about the battery power as well. I drive it 100% electric on normal days and it is very easy to accelerate fast enough to be quicker than the rest of the cars at the traffic lights try to get a test drive for a longer period of time or ask them to have it empty when you get it. I am impressed with the range and yes, only on gas it's a bit sluggish buy that hardly happened till now (1750kms total, 1050 electric) |
08-05-2021, 03:33 PM | #4 |
Rep 4,210
I believe you are wrong. BMW saves approximately 20% of the battery capacity to extend the life of the battery pack. I believe that BMW lets you invade that remaining 20% for boost.
08-05-2021, 04:00 PM | #5 |
Rep 278
Drives: BMW G20 330e M Sport
If you don't have any e boost remaining, then it can be pretty sluggish (in lower speeds, seems to be better at kick down at around 90kmph)
Think the ICE alone is only about 180bhp. Thread here about some of the comparisons between 330i and e https://g20.bimmerpost.com/forums/sh....php?t=1762993 |
08-09-2021, 05:31 AM | #6 |
Rep 278
Just done a 1200km journey. Amsterdam to Lake Garda in Italy. Started with a full charge and got 48km out of it, but it regenerated 60km of range on the trip thanks to the roads in Switzerland.
Average petrol consumption was 6.2l per 100km. Which I didn't think was too bad considering the fun I had on the journey through Germany 😬 |
bavarianride1510.50 injin097.00 |
08-09-2021, 11:40 AM | #7 | |
Rep 5,092
Was there any recharge opportunity along your journey, e.g. a lunch/dinner break, or sleepover along the Alps? |
08-09-2021, 11:43 AM | #8 | |
Rep 5,092
08-09-2021, 12:37 PM | #9 | |
Rep 4,210
I have been driving a BMW PHEV for almost five years and have never failed to have boost. |
DRuw130.50 |
08-09-2021, 03:52 PM | #10 | |
Rep 5,092
If so then it is up to how long the driver cruises before battery has enough juice for another eboost. I think when u said "have never failed to have boost", u might have been readjusted to eboost-with-enough-juice, instead of eboost-on-demand. |
08-09-2021, 04:42 PM | #11 | ||
Rep 278
No overnight stop in Switzerland this time. Only stop breaks for 10-15 mins every 2.5 hours and then about 45 mins for lunch. No opportunity to plug it in. Total trip was about 13.5 hours I think. 0-60 time would be a guess at around 8. Tbh I've not timed it even when boost is available. |
08-09-2021, 08:45 PM | #12 | |
Rep 6,302
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ Last edited by tturedraider; 08-10-2021 at 04:31 PM.. |
08-10-2021, 03:37 PM | #13 | |
Rep 12
Sure, driving full electric until ICE takes over in then kicking it down, braking hard and flooring again many times would probably result in no juice anymore at some point, but that would be quite an artificial situation - at least for me. And I wonder which of the brakes or the battery would fail first In practice, I quite often find myself in situations where there is either some engine braking or not demanding the full power from the ICE which means battery can be charged. And the car does that quickly for the first "few miles" of e-autonomy. |
bavarianride1510.50 |
08-10-2021, 03:46 PM | #14 | |
Rep 5,092
Now it somewhat makes sense why BMW engineers use 180HP vs. 250HP version of 4-cylinder, namely, while the reduced power band costs mpg if pushed, drivers do not suffer much before battery has enough juice to sustain another bursts(or 2?) of eboost. |
08-11-2021, 08:40 AM | #15 | |
Rep 4,210
08-11-2021, 12:57 PM | #16 | |
Rep 5,092
But I can see how daily use can be planned to start with full charge, then stay in hybrid mode by default, and only eboost/EV only once in a while. The key disadvantage is mainly trunk space and range on road trips, so one has to weight in pros and cons. |
08-11-2021, 01:16 PM | #17 |
Rep 606
well, in the Netherlands, electrical power is way cheaper then gas. I charge the car at night and start in the morning fully charged.
I drive approximately 45kms to work where I can charge as well so when I leave after work it's full again. So I basically drive ev On the long drive, I put it on hybrid or adaptive and make sure that electric is depleted at the end of the drive so I drive as efficient as possible. Eboost is available as soon as you have breaked 3 or 4 times or simply coasting a bit and I'm really surprised on how efficient that works! Just driving on the highway doesn't charge the batteries, unless you push the button to actively regenerate or drive in sport mode. |
08-11-2021, 01:25 PM | #18 | |
Rep 5,092
3-4 brakes to charge up is pretty good, so city driving can refill eboost too. |
08-11-2021, 01:38 PM | #19 |
Rep 2
I recently bought a 330e and I'm actually happy with the millage.
I commute 65 km (one way) and I'm able to charge it both at work and my house.(55km out of the 65km is highway) So for one way trip, I drive about 30km electric and the rest 35km with gas; so far I'm averaging 4.1l/100km with 76% Fuel remaining and total 279km on odometer. I'll be posting a review on how 330e does for a long distance trip after about a month or so. But so far it seems great |
08-12-2021, 08:09 AM | #20 | |
Rep 4,210
It would have been much better given the space reduction if they had made the hybrid a hatch instead of a trunk. |
08-12-2021, 08:26 AM | #21 |
Rep 27
I asked this exact question at the dealer when I picked up my 330e.
They told me that the battery will always have a minimum amount of charge even if you never plug it in. So that at all times the car has access to all it's horses and it never turns into basically a heavy 320i. They also said driving like that would be very very costly I am still in the first 1000km so haven't tested 0-100 times with&without charge yet. If I do I'll report here. |
08-12-2021, 11:15 AM | #22 | |
Rep 5,092
So the car does turn into a sluggish 320i with extra 400+lb when battery does not have enough juice, but the driver can adapt to hide that sluggishness by not demanding power during that window of recharging. It is similar to BEV drivers needing to plug in at low-rate hours, and hide on-the-road (slow) charge time with breaks/stayovers, and limp to next charge port during road trips. I do wonder what is effective mpg when a 330e driver starts a road trip of, say, 1000 miles, with 100% empty battery. Or what is hybrid range with a full (10.6 gallons?) tank and 100% empty battery. |
