2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Wheel vibration/juddering
      10-13-2020, 07:16 PM   #1
psybience
Drives: 2010 BMW 330i Coupe
My G20 320i msport makes an odd juddering/vibration when making tight turns and applying the accelerator simultaneously. It's done this since I got the car from new (only done 1100 miles). Is this normal?
The juddering feels like it's coming from the front wheels. It's not affecting performance in anyway (as far as I can tell) but feels weird, like the car is front wheel drive. My old e92 didn't do this.
Would appreciate some advice here!
      10-13-2020, 09:37 PM   #2
Socosurf
Drives: 2020 BMW 330xi
You sure it's not the lane / steering assist?
      10-13-2020, 10:59 PM   #3
VipinLJ
VipinLJ's Avatar
+1.
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      10-14-2020, 01:10 AM   #4
psybience
I have that turned off. It usually occurs when going around roundabouts quickly or making a quick U-turn, with the accelerator down.
      10-28-2020, 06:00 AM   #5
mborecki
Drives: BMW 8
Look on those docs - maybe will help with taking in BMW...
https://static.nhtsa.gov/odi/tsbs/20...76367-9999.pdf
https://static.nhtsa.gov/odi/tsbs/20...70576-9999.pdf
TICKING NOISE WHILE CORNERING WITHOUT THE BRAKES
APPLIED
https://static.nhtsa.gov/odi/tsbs/20...78996-9999.pdf
https://static.nhtsa.gov/odi/tsbs/20...74009-9999.pdf
      10-30-2020, 12:15 AM   #6
Ghozthunter
Eleet Tech
Ghozthunter's Avatar
Drives: a bimmer
I too have noticed this and I always thought it was the lane assist but now am not sure lol. Its only the steering wheel that vibrates but not the car.
      10-30-2020, 09:18 AM   #7
cnichols138
X3M Comp is a beast
89
Drives: 2022 BMW X3M Comp
Lane assistant has two parts. it will take control of the wheel or the vibrate when you get to either lane. Sometime in turns my will vibrate even though I stay in the lines. That is the main reason I turned off the lane assistant...because rise in the road that moved any direction sent the car to the middle of the road. Try going in a straight line and go toward the end of the road. you will probably feel the wheel vibrate. I think you can also adjust the feel more or less vibrate too.
      10-31-2020, 12:55 PM   #8
exhibhooligan
exhibhooligan's Avatar
Drives: 2022 430i Gran Coupe
This happened to me the other day in my 330i! It was just the steering wheel juddering when I made a turn. It began happening in the middle of my drive. Once I parked and turned off the car for a few minutes and began to drive again the juddering went away and hasn't returned again. I just figured it was a random software bug with the electronic steering.
      11-01-2022, 05:34 PM   #9
Tom20182018
Drives: G20 BMW 330i xdrive
It’s a bug in lane keep assist. It happened when you switch lane keep assist setting when driving. Turing the car off and on then it’s gone.
      01-02-2023, 03:25 PM   #10
Jamieb3009
Drives: BMW G22 4 Series 2021
Did anyone get anywhere with this? I have a 2020 G22 4 series which i think has the same issue. When turning right over unperfect ground at maybe 15 - 25 mph (i.e going round a roundabout), a rattle/vibration can be felt through the steering wheel. Almost as if something is tapping from the inside of the steering wheel out. No vibrations on the car whatsoever. It is definitely not the lane assist vibration as i have this fully deactivated and it still does it...
      01-03-2023, 10:22 PM   #11
Younge
Drives: BMW M340i
Took me a while to find the thread.
https://g20.bimmerpost.com/forums/sh....php?t=1730772
Some guys have complained about similar issues and discovered pre delivery wasn’t completed correctly.
Worth a read.
      01-04-2023, 05:26 AM   #12
gnolivos
Drives: Various BMW
Not saying this is the issue, but be aware that if you have your turn signal on, and a car is in your blind spot, the wheel will vibrate to alert you. I think this happens even with all your assists off.
https://g20.bimmerpost.com/forums/sh...5#post29807925
      02-01-2024, 04:15 AM   #13
RobH1
Drives: BMW M440i xdrive
Same issue
Hi, I know this was posted some time ago...did you resolve the issue as I have the same going on with my 4 series. Been back to the main dealer twice but still unresolved. Thanks.
