BIMMERPOST Universal Forums Cosmetic Care & Detailing (PPF/Wash/Wax/Detailing/Restoration/Repairs) Ceramic Coating - Yes or No?!? M340
      02-29-2020, 10:34 PM   #23
Conezz
Drives: G20
Originally Posted by Burrcold View Post
During the winter yes. Much like most of the northern US states, sand/salt is a way of life. You have to adjust when driving behind large trucks or you are basically a firing range of salt pellets and debris. It'll all be over by next month hopefully and on to normal nice conditions
Nice thing about Socal is that the highways are relatively clean. So long as you don't tailgate, chips aren't an issue.
      03-01-2020, 04:47 PM   #24
Eric S
Eric S's Avatar
293
Drives: in pre-order stages
Has nothing to do with tailgating...my car has 100k miles and the front end is like braille.
PPF for rock chips, coatings for easy car care.
      03-01-2020, 04:48 PM   #25
Burrcold
Drives: 2024 M3 Comp xDrive
100% agreed!
      03-01-2020, 07:55 PM   #26
themnmd
themnmd's Avatar
Drives: 23 X5MC
Originally Posted by RedKloud View Post
Originally Posted by Preciseyyc View Post
I personally use the cquartz line up of products for my vehicles and client vehicles.
You should be planning at least a day with an installer for paint correction, Surface prep and then the ceramic installation as well. I typically keep a
Car 4 hours after install, but over night when ever I can as you want them to stay dry for minimum 12 hours ideally 24.
So I searched online, and the local CQuartz certified place is charging $2K for the complete treatment! Is that normal?
CQ is not that hard did mine myself. Patience and take your time
      03-05-2020, 11:22 PM   #27
Conezz
Drives: G20
What’s your reasoning? Do you mean debris that kicks up from your own tires? Still, that’s not really enough of a concern to get full front paint protection film if you’re not a tailgater. A lot of cars come with the fenders having a piece of paint protection film on them for this reason. My buddy here in San Diego has had his 330i for 8 months now. He drives on the highways and makes a point not to tailgate. He has no chips on the front of his car or windshield. I just remember having expel ultimate forefront on my last two cars. Despite it being self healing, the swirls add it up over time. Not to mention that the film can be damaged from debris itself. What good is a clear bra when the windshield is exposed? Blemishes on the windshield are much more annoying and noticeable than ppf. Everyone has just become so OCD. In the big scheme of things, it’s nothing.
If I had a choice if either protection film or good coating, the coating is it.
      03-06-2020, 02:05 PM   #28
TTG
TTG's Avatar
Drives: M340
I am sorry but I disagree with you.
Repainting your front bumper & hood costs much more than replacing a windshield for starters. Further there is a product called clearplex which goes on your windshield like a PPF if you are that concerned.
Coating doesn't replace PPF and PPF doesn't replace coating. Both are recommended.
I had a seamless PPF done on my car then I coated the entire car myself. PPF is all about the installer. You won't be able to tell its there if it is done right. I also had Xpel ultimate on my last 4 cars and did not experience discolor, swirls or scratches. There is also another product called Stek Dynoshield which is even more impressive than Xpel. Look it up.
Report back after 3 years after 30K + miles about the condition of your paint, not on your friends car after 8 months. The PPF you had clearly protected your previous car's at the expense of the film itself.
Overall this is a well documented fact and you pretty much need PPF on today's soft paints otherwise you will get chips. Coating has minimal protection against chipping.
But then as you stated, to each on its own. Some people don't care about chips or swirls and rather save the $$$
      03-06-2020, 02:15 PM   #29
Eric S
Eric S's Avatar
293
Its all subjective in this arena...
coatings are easy car care and great looks, ZERO rock chip protection
PPF is rock chip protection that has its limits, but if you compare a car with it at 100k miles to a car without it at 100k miles, it will be VERY evident why there is a demand for it.
Rocks dont only from tailgating. Think about it...your traveling at 80mph and there is a car in the next lane over who kicks up rocks left, right, directly behind...you can literally never drive directly behind someone and still end up with chips.
Some people care about chips, some dont. Just like some care about tint, some dont. Some care about Auto vs manual, some care about all the bells and whistles where someone else just wants the base model. To each their own.
      03-08-2020, 11:17 AM   #30
Conezz
Drives: G20
That’s true. But then again he could hit anywhere on the car. Where are we going with this? Might as well wrap the entire car. It’s futile. I said before I had three, not two, full hood / front wraps. The self healing properties of xpel ultimate are overrated. The novelty wore off enough that it just doesn’t seem worthwhile anymore. What did people do before ppf?!
      03-08-2020, 11:25 AM   #31
Conezz
Drives: G20
Replacing damaged clear bra can also get quite expensive.
      03-08-2020, 12:18 PM   #32
Burrcold
Far far less. Plus you get to keep your original paint.
      03-08-2020, 12:49 PM   #33
TheFizzels
Drives: BMW M340i XDrive
If your car's paint isn't damaged or if you do not have any swirl marks, ceramic coating is way easier than applying a coat of wax.
It is pricy bec most detailers will have to do a full paint corrections before applying ceramic coating.
I did mine in less than 2 hrs but my paint was perfect.
Highly recommended as others stated.
PS: Use the search function as many of these things have already been discussed!
https://g20.bimmerpost.com/forums/sh....php?t=1645510
1) could you recommend your product?
2) have anyone done their seats?
3)does ceramic coating change the hue of the paint?
      03-13-2020, 10:26 PM   #34
shawntech
The Wolf
shawntech's Avatar
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
I've been obsessing about new and perfect cars for 20yrs, ppf helps but the fact is if you drive it, it will get chipped and blemished.
      03-14-2020, 06:48 PM   #35
jondagger
Drives: 2016 M235i
I'm doing them for people super cheap in south Florida will I build clientel. 450$ for 2 step and ceramic, 350$ for 1 step and ceramic.
      03-15-2020, 11:17 PM   #36
Eric S
Eric S's Avatar
293
do you want to have the ability to save your paint in an accident?? Client ran her car into the side of her garage on accident. scraped up the clear bra. We peeled it back to inspect, no paint missing. Remove the film, and replace with a 4 hour turn around. Not new paint, 4 day turn around, and twice as much.
      03-26-2020, 11:46 AM   #37
Dravit_M340i
Dravit_M340i's Avatar
129
Drives: 2020 BMW M340i Dravit Grey
For those who have a ceramic coat.. how many layers did you do? Thinking of going with ceramic pro and doing a 4 layer 9h and one layer of light package with lifetime warranty.
      03-26-2020, 12:05 PM   #38
Preciseyyc
Preciseyyc's Avatar
Drives: F15 35i G20 m340
Are you referring to PPF? If so, what's your issue with it? I have Xpel on my entire front end and the entire car ceramic coated. The Xpel is seamless and you would never know it's there. It's already saved my hood from a few stone chips!
Yeah I had a full front xpel ultimate on my past two cars. Decided against it. Just doesn't look completely invisible and does wear after a couple years even with maintenance. Cars are made to be driven, not embalmed. You got to take the good with the bad.
DISCLAIMER: Just my own opinion. Do not be offended.
Xpel has a good warranty if the film looked like shit you should have made them redo it.
Film will only be invisible if you do full panels.
But it's still far better looking than raw metal, primer, etc from rock chips and other debris.
      03-27-2020, 10:57 AM   #39
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
Hi,
Since my car is a fairly dark color, Tanzanite Blue metallic, I had car ceramic coated by a local detailer with two coats of GTechniq.
BTW, regardless of what you do, I strongly encourage having wheels coated as our BMWs throw off a potful of brake dust
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
themnmd1691.00
      03-29-2020, 08:14 AM   #40
M340_pilot
I bought the Adam's kit and did 2 coats on the front end, hood, roof and trunk. All the doors just 1 coat. Wash, clay bar and ceramic coat took 3-4 hours all by hand. Applying the ceramic coat was kinda like waxing a vehicle only you do much smaller (~2'x2') sections at a time and the flash time for removal is much quicker.
As RSnic mentioned...I really want to do the wheels next to make them easier to clean.
      03-29-2020, 09:31 AM   #41
themnmd
themnmd's Avatar
Drives: 23 X5MC
imho ceramic makes cleaning way easier in particular the wheels. i am a Carpro user. as a DIY it is what i am comfortable using. ceramic coating can be a bit less forgiving than wax depending on type and skill level
      03-29-2020, 11:32 AM   #42
pneumodoc
pneumodoc's Avatar
233
Drives: G20, G01
Which coating do you use on your wheels? I got modesta on the rest of the car professionally but didn’t pony up for wheels. Going to coat my takeoffs and then when they are back on in fall coat my summer wheels.
      03-29-2020, 12:41 PM   #43
themnmd
themnmd's Avatar
Drives: 23 X5MC
Which coating do you use on your wheels? I got modesta on the rest of the car professionally but didn't pony up for wheels. Going to coat my takeoffs and then when they are back on in fall coat my summer wheels.
Carpro uk 3.0 same as on car. tip make wheels are super clean 1st
pneumodoc233.00
      04-02-2020, 03:25 PM   #44
Eric S
Eric S's Avatar
293
Modesta BC06 is hands down best from my experience. Tried most everything else. Proper application is key and the effort lasts a long time with minimal effort needed to clean the wheels moving forward.
