12-03-2022, 01:11 PM | #111 | |
Rep 1,805
Stupid question: If you're having battery issues why can't you take your car to the dealership? |
12-03-2022, 01:11 PM | #112 | |
Rep 5,101
At least the F30 AGM battery is to the right of the trunk behind an easily-removable storage bin. Also charging directly from the battery terminals may bypass certain built-in surge protection available through the jump terminals. |
12-03-2022, 01:14 PM | #113 |
Rep 1,805
12-03-2022, 01:15 PM | #114 | |
Rep 5,101
12-03-2022, 01:18 PM | #115 | |
Rep 1,805
I have gone as long as 2 months at a time with my car parked and locked. Never needed to charge it. So it's a question of why the poster thinks it's ok to keep getting in the trunk to charge the battery. Seems unnecessary if you ask me. Perhaps the battery ought to be disconnected if gone for an extended period of time. Dunno. The longest I've gone is 3 months and I had no problems. |
12-03-2022, 01:32 PM | #116 |
Rep 2,350
No, it doesn’t, you don’tt charge it with both cables connected as the manual says. Either so, some dealers suggested that you could charged via trunk as is! And that is probably a No No, yet, (read the thread) some dealers suggested it as via BMW channel.
12-03-2022, 01:34 PM | #117 | |
Rep 2,350
Read here https://g20.bimmerpost.com/forums/sh....php?t=1884955 |
12-03-2022, 01:35 PM | #118 | |
General
13670
Rep 20,316
You do what you want, but it definitely is not recommended.
12-03-2022, 01:41 PM | #119 | |
Rep 2,350
My 20212 BMW doesnt need anything like it. If I give him the original trickle charger for 3 hours after 5 -6 months he is getting full. I cannot disconnect the battery, otherwise I cannot lock the car in the common parking ground where it sits now (!) Last edited by Teutonic; 12-03-2022 at 01:49 PM.. |
12-03-2022, 01:45 PM | #120 | |
Rep 2,350
I already bought two batteries on my 2021 X4. So screw this. Of course you can remove the battery. How do you think they change the battery? I just wish I can buy a regular bimmer with no BS battery or shitty MHT crap. |
12-03-2022, 01:49 PM | #121 | |
General
13670
Rep 20,316
For example: "If your BMW is equipped with a lead-acid or AGM battery in combination with an intelligent battery sensor (IBS), you must connect the trickle charger at the jump-start terminal points in the engine bay. This way the IBS will recognize the charging. If you charge the battery directly at battery terminals or removed it from the car, this could lead to misinterpretation of the battery condition or unwanted check control messages and fault memory entries. " https://bimmerist.com/how-to-charge-...ry-full-guide/ Good luck with yours.
12-03-2022, 01:52 PM | #122 | |
Rep 2,350
https://g20.bimmerpost.com/forums/sh....php?t=1884955 The shop uses specific smart chargers made for BMw to address all models and batteries. We are not at that level. Only the M340i MHT has troibles being charged with the 5 Ah or 10 Ah either Ctek, Noco or BMW chargers. All behave the same with this car but all work with the rest of the cars including my older BMW or my two Audis. |
12-03-2022, 02:05 PM | #123 | |
Rep 2,350
Are you charging yours? If yes, how and with what charger? Because the IBS doesnt recognize the chargers. Both dealerships do not know how to address the problem. BMW is quiet. MY machanic did not find the response from them. Again, read my thread Your article does not refer to MHT vehicles and suggested a CTEK Mus 4 which is a 4 AH charger, which is perfect fro any battery on these vehicles. But I do have the CTEK 5 and it doesnt work either. So your article is futile for uour case. When you will be in the position to put it in storage like me and can not charge it properly, you will understand. This car does not accept chargers that provide the suggested Ah for this battery. 5-10 Ah battery chargers are perfect for any 80-200 battery. |
12-03-2022, 02:07 PM | #124 | |
General
13670
Rep 20,316
Teutonic2714.00 |
12-03-2022, 03:14 PM | #125 | |
Rep 1,805
This is probably how it works with dealer charger. You can perhaps contact CTEK for more tech details. The 25A rating just means it's the max it *can* push; it doesn't necessarily mean it's pushing at a constant 25A. Based on everything I've read it adjusts itself to what it believes the battery/system needs. You can of course contact CTEK. I don't have a battery analyzer to ascertain exact values while charging but it should be less than 25A going by CTEK. Hope this helps. |
12-03-2022, 03:50 PM | #126 | |
Rep 2,350
Not lastly, that is a shop where they care about speed and time spent not your ideal charging pattern. I guess that the fact that your battery gets charged in one hour instead of 4-5 (that a proper calculated charger) will provide the answer for you. Don’t forget that all these 4-5-6 Ah chargers are made like that for a scope. By the rules, battery charging current should be 10% of the Ah rating of the battery. Charging current for 100Ah Battery = 100 Ah x (10 ÷ 100) = 10Ah That is the ideal Ah for charging such battery. Why do you think BMW sells CTEK rebadged chargers that do not pass the limit? |
12-03-2022, 03:51 PM | #127 | |
Rep 1,805
I'm by no means an expert; I'm just sharing my personal experience and what CTEK claims for that particular charger. But I can bet my money that it doesn't push 25A. If I'm able to get my hands on an analyzer I will be able to verify because I'm interested now that you mention it. |
12-03-2022, 03:54 PM | #128 |
Rep 2,350
Posted wrong, Iguess.
Anyway, regardless of our conversation, my question is “why this vehicle does not accept the 5-10 Ah chargers like other vehicles do? Including 5 or even 7 series that have way bigger batteries?” That is what I care. I can buy a Noco 25 regardless of price. But the principle of the problem bothers me. Not to mention, all those 25 Ah chargers are huge and not practical. |
12-03-2022, 03:57 PM | #129 | |
Rep 1,805
Teutonic2714.00 |
12-04-2022, 05:20 AM | #130 | |
Rep 80
12-04-2022, 12:11 PM | #132 |
Rep 5,101
Yeah I read some posts that 48V battery is charged by 12V battery while the car is in motion, and my guess is that the instruction to open the hood is to disconnect 48V battery from 12V battery. I can't find definitive reference from BMW though.
