Technical Topics DIYs and Coding Discussions Code Trailer Hitch
      10-28-2020, 11:18 AM   #1
haussi
Drives: G20 330i
Code Trailer Hitch
Hello together,
does some of you retrofitted a G20 with a Trailer Hitch? The mechanical and electrical part is already done. Now I have to code it. Currently, no light is shining at the trailer.
I can code it with E-Sys, but I don't know on wich ECU I have to do it.
Thanks for help!
      01-31-2021, 10:47 AM   #2
Litos_
Portugal
Drives: BMW 330E G20
Originally Posted by haussi View Post
Hello together,
Thanks for help!
Hi,
Have you managed to solve your problem?
I already fixed the trailer, and connected the cabling that is intented to the rear section of the car. havent done the connection to the front section of the car.
My rear fuse box is not suitable, I think , for the trailer, because is smaller than it should be.
Does your fuse box is equal as the one in the install instructions?
Regards
      01-31-2021, 01:34 PM   #3
Kokosnoot
Drives: G21
Hi,
I’ve done the retrofit for an electric tow hitch on my G21. Via Esys you add the 3AC to your FA and then code all modules in the car with the new FA.
Ps: wiring the harness to the front fuse box & doorplug = PITA..
Best regards,
Joren
      02-09-2021, 01:19 PM   #4
Litos_
Portugal
Hi Joren,
You are right!! It is a PITA to wiring the harness to the front fuse box!
I couldn't access the door plug, I have no idea how to reach that plug..hug!
I also have my rear fuse box smaller than it should be, does your rear fuse box has all the space to plug all the connectors?
My rear fuse box
Can you help?
      02-09-2021, 01:25 PM   #5
Litos_
Portugal
I don't think that the picture was correctly attached
https://ibb.co/PzYcFgy
      02-09-2021, 01:26 PM   #6
Litos_
Portugal
      02-09-2021, 04:15 PM   #7
Kokosnoot
Drives: G21
Hi Litos,
To acces the doorswitch you have to remove your front fusebox completely and than you
can reach far enough behind the liner of the footwell to pull the plug out. (To remove the
plug you have to lift up the plastic piece at the door side).
I had the smaller rear fusebox so I bought a new one from BMW with a new LIN-module.
I have posted a link in my topic with a PDF from BMW (in Dutch). If you need more help, let me know 👍🏻
File Type: pdf BMW installation manual - trekhaak G2x.pdf (1.69 MB, 453 views)
krm347.00
      02-23-2021, 06:03 PM   #8
Litos_
Portugal
Hi Joren,
First of all, many thanks for your prompt reply and all your precious information.
This weekend I finally found a way, with your help, to reach the door plug connector. And after beeing thru a really difficult task, I found another! How in hell will I unpin the pin 22 of the connector!!?? It is in the middle line, no way to push the unlock pin...grrrrrr I had to cut and solder the other one! Couldnt find a safe way to remove it.
Thanks for the manual, I also have one in Portuguese.
Do you have the reference number of the new rear fusebox?
Do you think it is the same to my car? How much did you pay for it?
Once again, thanks dude.
Bye
Carlos
      02-24-2021, 01:41 AM   #9
Kokosnoot
Drives: G21
Hi Carlos,
You could have unpinned nr 22 with a small blunt needle in the little hole you have next to the plug. (Again, also a big PITA).
The part number for:
rear fuse box: 61148734160 - €110,70
LIN-module: 61358795478 - €61,29
Best regards,
Joren
seccsc239.00
      02-24-2021, 06:24 PM   #10
Litos_
Portugal
Thanks Joren,
Will keep you posted when I replace them.
Thanks!
      09-28-2021, 09:35 AM   #11
daniel_goncalves
Drives: bmw 330e G20
BMW 330e
the instruction in german you post seems not fitting my hybrid model.
I need this instruction manuel for my G20 330e.
anyone can help ?
      03-16-2024, 01:53 PM   #12
NullByteZero
Drives: BMW 320i G20
Originally Posted by Kokosnoot View Post
Hi Carlos,
Best regards,
Joren
Do you have to buy new LIN module or can it be transferred from the old fuse block?
      03-16-2024, 02:02 PM   #13
NullByteZero
Also has anyone had the same problem when trying to code new hitch? My AAG2 module seems to be partially detected? All of the versions seem to be OK except the CAFD has value of FFFFFFFF_255_255_255. Is it possible I've connected something incorrectly?
coding, hitch, trailer
