Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Software updates discussions
      10-17-2024, 01:13 PM   #1827
efisher
Drives: BMW 2020 330i
Originally Posted by DRD_G20 View Post
I'm sorta in the same situation as you are but not regarding maps, just an overall OTA update for the car. I downloaded the software on my phone, then uploaded it my car, everything was fine. Now its telling me that the car will prompt me to start the install but in two weeks nothing...
I drive daily so battery charge is not an issue, I activate the parking break once i get home ... still no prompt. If i go to the dealer they would surly charge me for something that should work and cost 0. This is kinda lame from BMW.
I have found that the OTA updates have a number of safety checks. Being charged because you are driving might eliminate one of the issues, but if the battery is oder than 3 years old it may very well be that the voltage that the battery is providing is lower than the safety check allows. I had this issue recently, checked my battery with a voltage meter and was at 11.9V even though it would start and drove almost every day. I replaced the battery, now showing 12.9V-13.1V and the OTA update happened within a few days.
Not guaranteeing this will fix your issue, but definitely check the voltage of the battery and consider replacing the battery if it is older than 3 years and less than 12V showing.
E__F10.50
      10-20-2024, 02:03 PM   #1828
DRD_G20
DRD_G20's Avatar
Drives: 2020 G20 330i
Thanks for the info. I'll be sure to check this tomorrow with ISTA more thoroughly. I did check the event/ error code but just didn't have time to go further.
      10-21-2024, 05:51 AM   #1829
mdl1978
Drives: BMW G20 330i MSport 7/20 build
Originally Posted by JoB01 View Post
BMW does not care, nor want, to support 8.0 or earlier. They are still very much a legacy automaker when it comes to software.
And yet they are still selling cars wth this software. 2024 X3.
      10-21-2024, 06:49 AM   #1830
JoB01
JoB01's Avatar
26
Drives: 2023 i4 M50 & 2008 E90 M3
Yep- MGU-21 HU’s running on 2018 hardware running “mature” (ie orphaned) software.
The logistics of running a company like bmw must be staggering, tbh… but as an end user- a more “line replaceable/upgradable unit” approach seems to make more sense to me- although I’m sure that’s somewhat stifled by cost and/or regulation.
      10-21-2024, 09:13 AM   #1831
XxSullyxX123
XxSullyxX123's Avatar
66
Drives: '24 M340i xDrive, '20 Rubicon
I'm still on 11/23 in my 2024 m340 here in NY. weird.
2024 BMW M340i xDrive
      10-21-2024, 07:57 PM   #1832
E__F
E__F's Avatar
Drives: 2019 BMW 330i XDrive
I’m also on the same version. Top up my battery with a tender about once a quarter too but haven’t gotten a notification for an update in 8 months.
      10-23-2024, 03:02 AM   #1833
bydn320
Drives: BMW
I have a BMW 320d (2020) imported from Japan, and I am currently in Cyprus. Finally I successfully connected my car to the BMW app without any issues. However, I noticed that the software version on the car is still from 2019.xx (pre-installed), and I haven't received any updates through the app, even though I expected to use the Remote Software Upgrade feature. I do want upgrade in order to use Android Auto as I don't have it now
Has anyone experienced something similar, or do you have any suggestions on how to resolve this and get the latest updates? Any advice would be greatly appreciated
      11-04-2024, 03:59 AM   #1834
luppolone
Drives: BMW 318d G21 2023 LCI
Originally Posted by BeeEhmWie View Post
Anybody notice that the instantaneous fuel economy refresh rate is super slow now? Only responds to large changes otherwise will stick to 1 number until you really change how much throttle / fuel being used.
07/2024 on 2024 G20 330i
I have the same issue, noticed also after a software update, I don't remember which one tho.
A friend of mine, has same car as me, but fuel consumption is still "fast changing".
Any solution you found?
Thanks.
      11-10-2024, 07:30 PM   #1835
BeeEhmWie
BeeEhmWie's Avatar
Drives: 2024 G20 330i MSport Tanzanite
Thanks.
None, however, the AVERAGE still seems to be correct, just the refresh of the instantaneous is low
Spacer76.00
      11-23-2024, 10:04 PM   #1836
den110
den110's Avatar
45
Drives: 2021 Mineral White M440i
2021 M440i  [0.00]
I just noticed I lost caring car and the climate control rules menus. Not sure if it is because of my BMW connected services expiration (after 3 years) or the software update I had a few months ago (03/2024.47). Anyone with similar issue? I tried to reboot Idrive by holding on/off button for 45 secs but no luck. Any help would be appreciated.
      11-24-2024, 01:29 AM   #1837
G22b58
Drives: G22
I see (in the other thread) that the coding worked. BMW implemented the auto heating as an "app" and paid service.
      11-26-2024, 09:57 AM   #1838
den110
den110's Avatar
45
2021 M440i  [0.00]
Coding works. Don't even have to go into expert mode. Got both my heated seats and steering wheel rules back.
      11-27-2024, 09:15 PM   #1839
Eric_M328i
Eric_M328i's Avatar
Drives: 2023 M340i (Build)
2023 BMW M340i  [9.27]
Anyone thats on the latest update i think now 11/2024, can confirm if theres an auto start stop button added in idrive 8 for those that dont have it? I know other models got it already but not sure if we will get it.
Thanks
      11-28-2024, 03:17 AM   #1840
zlatko
Bulgaria
179
Drives: G21 LCI 330d Xdrive
Eric_M328i - haven't noticed it on mine. Where it should appear?
Never mind - found the post, it's a shortcut and by looks of it is just for iD 8.5. I will check my car today though.
      11-29-2024, 03:50 PM   #1841
Eric_M328i
Eric_M328i's Avatar
I think the hardware is slightly different for idrive 8.5 cars but its still not acceptable.
Im sure they can still add it.
I cant stand the hesitation caused by this feature anymore so I guess i will just have to use the sport individual settings set to comfort.
Other options we have include xhp TCU tune (which I dont want right now because of warranty) and Bimmercode was also working on a obd plug in module but no word about that yet.
      Yesterday, 01:01 AM   #1842
zlatko
Bulgaria
179
Eric_M328i - checked yesterday and can not see ASS disable available.
