Technical Topics Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin G20 coolant leak
      02-01-2024, 11:29 PM   #1
Lfk
Drives: BMW 3 Series G20
My 2019 G20 has a slow coolant leak (goes under min after 2 months of topping up and I get a warning). I've had it looked at by three independent mechanics (the ones with the best reviews around me) and each one diagnosed a different problem. All three did a pressure test (or that's what they told me).
The first one told me the leak was from a hose. The second one found it to be from the oil filter housing and wanted to replace that including the heat exchanger. And the third one thought it was the thermostat.
The third one recommended I replace the oil filter housing and heat exchanger with the thermostat because "that's probably going to leak as well later", presumably because replacing the thermostat damages its seal.
At this point I'm really not sure what to do. Obviously at most one (possibly none) of these people is right. What would you do? Is finding a leak really so complicated?
      02-02-2024, 04:22 PM   #2
Delighted_Jester
Delighted_Jester's Avatar
Drives: BMW M340i
If theres nothing obvious under the hood, id climb under and remove the splash shields. Its a pain but i imagine itll let you see up under and around the intake where the thermostat (electric), oil filter housing, etc.
