04-13-2020, 12:58 AM | #1 |
Rep 14
Should I routinely idle my car to keep the battery charged?
For the past month I haven't been able to drive my new 330i given the state of the world (I still only have 150 miles on it). Here in Los Angeles we've been encouraged to avoid driving unless absolutely necessary.
To preserve the battery, and perhaps other engine systems, should I at least let it run on idle in my garage? And if so, for how long and how often? Or, do I need to actually drive it somewhere, and again, for how long and how often? |
04-13-2020, 03:32 PM | #2 |
BMW CCA #257
75
Rep 190
Suggest you purchase a "Battery Tender". It costs about $25 on Amazon. Mine works great and it will not overcharge the battery.
2014 F31 328 xDrive Touring
2020 G20 330 xDrive Sedan 2023 G01 X3 xDrive BMW CCA # 257 |
upsidedownfunnel1996.00 |
04-13-2020, 10:42 PM | #3 |
Rep 14
Ahh, yes, if I didn't live in an apartment complex with no available outlet to plug into I'd definitely do that. Any other guidance would be appreciated!
04-14-2020, 03:05 AM | #4 |
Rep 1,687
Mine showed a 'low battery' warning after sitting for just a few days but not since. I am only using it sporadically for short distances and it has been fine for the last three weeks or so. I may be wrong, but I think you will get a message in the Connected app if the battery is getting low assuming you can connect to the car from your apartment.
Not sure about current equipment. in the good old days when you could actually tinker with stuff an engine would need to run over 2000 rpm to start charging the battery. |
04-14-2020, 03:19 AM | #5 | |
Grumpy Old Git
443
Rep 923
My car has just shown “extremely low battery in iDrive screen” due to little running because of lockdown. Yesterday I ordered a charger (one that does gsm batteries) as my current battery charger isn’t suitable for cars with stop/start functionality.
Retired:
04-14-2020, 08:02 AM | #6 |
Rep 465
Drives: BMW G42 M240i XDrive
When was the last time you ran it mate? I've only used mine once in three weeks and it seems to be ok but I'm still debating buying a charger if the lockdown goes on for much longer
Dan
G42 /// M240i Thundernight |
04-14-2020, 08:08 AM | #7 | |
Grumpy Old Git
443
Rep 923
Charger should arrive by next Monday..... we’ll see how that goes....
Retired:
04-14-2020, 08:11 AM | #8 | ||
Rep 465
Dan
04-14-2020, 08:39 AM | #9 | |
Rep 1,687
04-14-2020, 02:22 PM | #10 |
Rep 26
If you have to use a battery tender instead of driving, you could also run the engine a few minutes every two weeks to keep fresher gas in the fuel system. Keeping the gas tank full also helps protect your fuel system.
'23 430i GranCoupe xDrive Msport SanRemo Green
Retired: '15 335i M Sport 6MT. Melbourne Red. '11 328i xDrive. Platinum Bronze. '06 330i Sport 6MT. Monaco Blue. '02 330i Sport. 1988 Porsche 944S 5MT. |
04-14-2020, 02:50 PM | #11 |
Rep 2,499
Idling a cold engine is not good. It's actually far better for the engine to warm up as quickly as possible and spend as little time with cold oil. The fact that your car uses synthetic oil makes that a little less of concern, but still something you should be mindful of. Idling a cold engine for a long time will advance engine wear. Safest thing to do is drive it around for at least 5 minutes and then park it (with the engine left on) if you don't want to go for a high speed 30 minute drive.
The alternator doesn't output significant current until it's past about 2000rpm. If you're just idling at <700rpm, you're not even feeding much current into the battery. Check out this graph of alternator output. Below 1000rpm, there is very little current being delivered. Last edited by upsidedownfunnel; 04-14-2020 at 03:19 PM.. |
Seaford1147.50 |
04-14-2020, 03:40 PM | #12 | |
Rep 4,210
