05-21-2020, 02:25 PM | #1 |
Rep 112
Software Update 03/2020: Lost Climate control rules
I just got my M340i back from the service center after the sunroof stopped working. The sunroof motor had to be replaced. I read somewhere that steering wheel heating can now be added to the climate control rules but I do not see the climate control rules option anymore in the menu. Anyone else on 03/2020 who can still see the option?
05-21-2020, 02:38 PM | #2 |
Rep 3,959
Did you make sure to log yourself back into your profile?
05-21-2020, 04:43 PM | #4 |
Rep 3,959
Isn't it under pre-ventilation?
05-21-2020, 04:45 PM | #5 |
Rep 112
No, it is usually under the menu pictured. I just saw another thread where someone mentioned that a hard-reset brings all the features back. I will try that and post the results here.
05-24-2020, 04:40 PM | #6 |
Rep 112
Doing a reset and then logging back in brought the Climate Control rules back. I can now see the setting that lets you program steering wheel heating as well.
09-26-2020, 05:19 PM | #7 |
Rep 355
I’m having the same issue. Can you explain how you did this? I have done a hard reset by holding down the volume knob a number of times and also changing profiles to guest and back to my profile and the climate rules still don’t show up. What am I doing wrong here?
09-26-2020, 07:20 PM | #8 |
Rep 2,699
Drives: 23 X5MC
That did not happen to me. But I am still upset that they didn't update to 7/2020. I am stuck on 3/2020 like you
09-30-2020, 10:16 AM | #9 | |
Rep 112
10-01-2020, 09:03 PM | #10 |
Rep 355
I just tried that and it didn’t help. Do you think if I reset vehicle data back to factory settings that would work? I don’t feel like doing it because then I would have to set everything up all over again but if that would work I would suck it up and do it.
10-05-2020, 05:19 PM | #11 |
Rep 112
I am not sure if this helps but check if you accepted all the terms and conditions in settings. I am not exactly sure what the name of that sub menu is but let me get back to you.
10-08-2020, 08:57 PM | #12 |
Rep 355
I talked to BMW assist and a BMW genius and sadly nothing worked and I would have to take it in. I tried adding the BMW recorder and that doesn’t even show up in Apps. The worst part is I am tuned and once I get an update they will lock it again and I would have to ship it back to California if I want to get retuned.
10-21-2020, 12:03 PM | #13 | |
Rep 112
