Technical Topics DIYs and Coding Discussions I added Equalizer Settings on my G20
      07-27-2020, 09:41 PM   #45
chris930
Drives: 2020 G20 M340i
You guys all have expert mode enabled?? I don't have an expert mode to choose from and the contact support for bimmercode wont reply for the beta :/
      07-27-2020, 10:01 PM   #46
VipinLJ
VipinLJ's Avatar
Yes. Expert mode present. Do you run your bimmercode on an Android or apple device?
2020 BMW 330i xDrive
2018 Audi SQ5 Prestige
2017 Audi A7 Prestige
      07-28-2020, 01:47 AM   #47
chris930
I reinstalled the app and it worked!
I found additonal settings that possibly helped.
Hifi System m340i
"Booster" set to mid
LAZ (no idea what that is) Set it to 2 zones
Multichannel "Active"
Im pretty sure I got some audio gains, but it might be all in head lol
      07-28-2020, 03:41 AM   #48
BBH
Drives: BMW G20 330i M-Sport
im running it on an apple device
If you haven't, you can try updating Bimmercode. The app has been updated weeks ago to support Beta Mode for the module relevant for this action(HGU_MGU if I'm not wrong).
      08-05-2020, 09:44 PM   #49
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
Well. It gives us more options but changing those frequency sliders don't change the output. Only the ones on the ends does. That's the treble and bass slider I believe. Also, the preset settings don't work in my car.
This is in my car. Not sure how it works for others with the HiFi system.
HiFi system powers all the speakers with the RAM. Top HiFi HK and the B&W have the woofers powered by a Booster and all other speakers by the RAM.
Coding the RAM from HiFi to HK enables the 7-Band EQ, but in the HiFi there is only a RAM and no Booster -the 7-Band EQ only works with the Booster + RAM (Top HiFi). So the output stays HiFi (all speakers powered by the RAM), and the 7-Band EQ is only a display of the Bass and Treble adjustment of the HiFi.
This is the reason only two bands work with this coding -the Bass (Band 1) and the Treble (Band 7).
pneumodoc233.00
VipinLJ1941.50
      08-06-2020, 12:13 AM   #50
VipinLJ
VipinLJ's Avatar
That clarifies why it won’t work with the HiFi system! Someone said they have the Hifi system and it worked for them whereas it didn’t for me.
      08-06-2020, 07:30 AM   #51
Encanto
Encanto's Avatar
It cannot work without the Booster.
Be grateful that the HiFi RAM does not behave like the Top HiFi RAM after this coding, as there will be no bass from the woofers.
pneumodoc233.00
VipinLJ1941.50
      09-28-2020, 03:03 PM   #52
Medjd11
Drives: 2014 F30
Originally Posted by Guns N Roses View Post
Finally after a lot of try and error here is my first post and contribution to this forum after I purchased my g20 last year I noticed the lack of equalizer settings on my Base 330i I was thinking no problem I can add one WRONG ! Well after going to numerous places getting quotes and getting non sense amounts from 2k to 4K you can do it because of the ram radio thanks to bimmercode and research on expert mode here is the procedure go to bimmercode to HU MGU HEADUNIT then expert mode from there pic 3002 then look for AUDIO-SYSTEM then change the parameters from alev2-Ram to alev4-Ram code and you got a free working Bowersand Wilkins settings and working equalizer enjoy,
WOW! I just coded this to my car. I have the HK sound system and holy moly the sound system is so much better. Incredible! Thank you for finding this!
      10-01-2020, 06:20 PM   #53
Randall
Randall's Avatar
260
Drives: G01 30i, E91 320dA
I’ve coded it today - sounds a lot better on HK.
Is it true that this coding left an error code “wrong amplifier” in memory?
      10-06-2020, 03:41 AM   #54
Randall
Randall's Avatar
260
I will reply to myself
Yes, there is an error B7F87B:
RAM configuration inconsistent with head unit
A6bullet337.00
VipinLJ1941.50
      10-26-2020, 05:22 PM   #55
kinu93
Drives: BMW 330E G20
OMG
can someone plz explain how do i get this function on my BMW330e with audio system is HK with logic 7
i would love to studio , concert mode
      10-26-2020, 07:18 PM   #56
kinu93
what cable and software did you use
      10-26-2020, 10:38 PM   #57
VipinLJ
VipinLJ's Avatar
Bimmercode with an enet cable or a wifi obd cable. Check the Bimmercode website. They have a lost of recommended adapters.
      11-09-2020, 04:06 PM   #58
kinu93
Originally Posted by rickkap View Post
I can't believe what a difference this has made to the sound quality especially the bass now rocks!!
I did this via e-sys (as i have andriod so no expert mode) so if anyone needs the setting it's:
HU_MGU then
CAFD_3E52 then search for
3002 and you will see
AUDIO-SYSTEM change to
alev4-Ram
Great find... thank you dude
how do you get this soft ware e-sys - is it simple to use is this software expansive
      11-09-2020, 05:42 PM   #59
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
kinu93 ,
Good Question. To code you can use a PC (or Apple) or a smartphone.
If you use a computer, you need:
* ENet cable (OBDII connector on one end & LAN connector on other) -- you can get on eBay or Amazon
* E-Sys -- you can get on Bimmerpost or Bimmerfest
* PszdData file -- same as above
* Because BMW trimmed files, you need another program to "map" trimmed out info back into E-Sys; I know of two:
-- ProLauncher-- you can get from Tokenmaster; however, he hasn't been available of late
-- E-SysX -- available at a cost on their website
If you use a smartphone (Android or iPhone), you need:
* Either an OBDII device or ENet with USB-C to LAN adapter
* An app for your phone; I know of two: Carly or Bimmercode
I, like many others, currently use Bimmercode on my Samsung with ENet cable & adapter
Hope that helps!
Al
Retired: 2014 328i
BMW CCA
      11-10-2020, 05:56 PM   #60
kinu93
kinu93 ,
Hope that helps!
thanks - good breakdown of option - i will go with the bimmercode this seems simpler then down loading e sys software - i might mess up
      01-21-2021, 05:46 PM   #61
rcz22
Drives: 2024 G80 M3 6MT
Going to code this tomorrow so I guess I'll find out for myself, but just curious how this error presents itself? is it only in bimmercode, or does the error show itself on the dash..etc. thanks!
      01-29-2021, 11:19 PM   #62
shawntech
The Wolf
shawntech's Avatar
Drives: stuff
  [0.00]
2019 BMW M850i conv ...  [0.00]
This sounds so much incredibly better than logic7 in my 20 m340i with hk but I have 7.2020.60 software and every time I turn the car on I have to cycle through the the dsp profiles or it sounds odd.
      04-07-2024, 03:43 AM   #63
G20agba
G20agba's Avatar
Drives: 2020 bmw 330i
2020 BMW 330i  [0.00]
I tried it on the non-HK HiFi system in my car and couldn't notice a difference with the presets (movie theatre, concert etc). With the equalizer, I noticed a difference only when I changed the two on the ends (bass and treble settings) and none in the middle (100Hz, 200, 500 etc). I tested it on SiriusXM.
Do you have HK or Hi-Fi? How did you code the equalizer to show?
