2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Coasting in Eco Pro or Comfort mode to save fuel
      08-14-2019, 01:55 AM   #1
Eagle Creek
Part of the bimmer family!
Eagle Creek's Avatar
Netherlands
139
Drives: BMWG20; BMW E90
2019 G20 330e  [0.00]
Hey guys,
According to the manual, in Eco Pro or Comfort mode, the car uses a "coasting" to reduce fuel consumption. Indeed, I noticed during my test drive that the HUD shows an icon to signal the driver to lift off from the gas when going down hill. But, I don't understand why the G20 prefers to disconnect the engine from the gearbox (which requires fuel to keep the engine running) in order to achieve savings.
Here's why. When I drive my E90 down hill, and I lift my foot off the gas, the consumption meter goes to zero while the car maintains quite some speed, only slowing slightly due to the engine. By comparison, when I put the car in neutral (just for testing), the consumption meter actually rises. On the other hand, there's no engine braking effect anymore, and therefore I'm able to maintain speed longer or even see an increase in speed when going downhill.
Conclusion: when the engine is not connected to the wheels, some fuel is needed to keep it running. However, when it is connected to the wheels, no fuel is needed to keep it running.
What am I not seeing here ?
      08-14-2019, 02:17 AM   #2
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Drives: BMW iX3 MSport High Exec (G08)
While coasting, speed reduction is as minimal as possible. Especially on slight declines you will notice constant speed. That compensates for the little gas needed.
Grz D.!
      08-14-2019, 02:29 AM   #3
Eagle Creek
Netherlands
139
So what you are saying is BMW chooses to use a little bit of gas to keep the engine running and by doing so prolonging the amount of time no additional gas for acceleration is needed?
Imo this would only be beneficial at modest declines for a reasonable amount of distance. At more steep declines keeping it in gear the weight of the car alone should keep it rolling with 0 usage of gas. Does the car indeed detect this and in this case choose the keep the engine connected to the wheels?
I drove a manual KIA in France last summer, went down a hill in second gear and didn't have to give any gas for almost 5 full minutes. Just going down in 2nd and breaking ever so slightly every now and then. Absolutely no gas needed.
VetteGuy845.50
      08-15-2019, 04:39 AM   #4
Eagle Creek
Netherlands
139
Appearantly coasting isn't available at a more steep decline:
https://www.bimmerpost.com/forums/sh...php?p=25140361
      08-15-2019, 08:06 AM   #5
Pauleebe
Pauleebe's Avatar
Drives: Inbetween BMW's.
I don't think the E90 had coasting (was introduced with F30 after a few production years). Therefore, what are you comparing your G20 coasting mode to in your E90? Is your E90 a manual that you would put into neutral/clutch-engaged, or an automatic you would actually shift into neutral? Or would you keep it in gear and just take your foot off the gas?
      08-15-2019, 09:13 AM   #6
mkoesel
Moderator
Drives: No BMW for now
From the second paragraph of his post:
"By comparison, when I put the car in neutral (just for testing), the consumption meter actually rises."
He does not specify what type of transmission the car has, but that is actually immaterial to the experiment. The point is to disconnect the engine from the wheels, which is what putting the transmission in neutral does.
"When I drive my E90 down hill, and I lift my foot off the gas, the consumption meter goes to zero while the car maintains quite some speed, only slowing slightly due to the engine."
      08-15-2019, 09:26 AM   #7
mkoesel
Moderator
It would seem that that is the logic, yes. Perhaps the car can glide for short periods as well?
https://en.wikipedia.org/wiki/Gliding_(vehicle)
That would provide the best of both worlds - no fuel used and no energy loss to the frictional forces inside the engine. However, this might not be safe to do without 48V (which the G20 does not have yet), because the electro-hydraulic braking system may require more energy than could be provided by the battery alone, and it might not be possible to fire up the engine quick enough to provide that in a panic situation.
      08-15-2019, 02:26 PM   #8
LarrySinNJ
LarrySinNJ's Avatar
Drives: 2019 330i xDrive
Regardless, I averaged 40MPG in EcoPro mode. Was actually almost 42MPG for most of a 400 mi trip until the last 150 mi when I was going through the Catskill Mtns on Rt 17.
2019 G20 330i xDrive Med. Blue/Cognac Leather ZCV|ZPP|ZPX|HK|Remote Start (Ret'd)
2016 F06 640i xDrive Med. Blue/Red Leather MSport|B&O|Driver Asst+|Cold|Night (Ret'd)
2013 F30 335i xDrive Mineral Grey/Black Leather (Ret'd)
2011 E90 328i xDrive Space Grey/Black Leather(Ret'd)
2009 E90 328i xDrive Monaco Blue/(Ret'd) 2007 E90 328i xDrive Graphite (Ret'd)
      08-15-2019, 03:09 PM   #9
Eagle Creek
Netherlands
139
I'd say the 330e should be able to do so having the electric engine available as an immediate backup.
What do you mean by 48V? Volts?
      08-15-2019, 03:57 PM   #10
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Yes, it detects this. Downhill is only free coasting for a while, after that the clutch is engaged and you're braking on the motor.
Grz D.!
      05-21-2020, 08:35 PM   #11
sddz6269
China
32
Drives: BMW G20 325i
Hi, may I ask how do you know that coasting is activated when driving in Comfort mode?
      05-21-2020, 09:23 PM   #12
Spec23
Drives: na
It doesn't coast in comfort, only in eco-pro. When doing so, the rpm's will be around 1000. It's basically putting the car in neutral.
      05-22-2020, 04:13 AM   #13
hamera
hamera's Avatar
442
Drives: 320i M Sport (G20)
You will see this blue car icon. You can activate coasting yourself by pulling the upshift paddle twice fairly quickly.
It does but less often. Depending on your driving style.
      05-22-2020, 06:47 AM   #14
sddz6269
China
32
Originally Posted by hamera View Post
You will see this blue car icon. You can activate coasting yourself by pulling the upshit paddle twice fairly quickly.
Thank you very much! I can't wait to test it. Since I coded coasting using bimmercode, I'm not sure if it can be activated under Comfort mode.
      05-22-2020, 08:02 AM   #15
Spec23
Drives: na
Don't think mine has ever done that but thanks!
      05-22-2020, 08:46 AM   #16
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Tried mine after reading this. The ‘pulling the upshit paddle twice fairly quickly.’ worked for me in Comfort mode. Didn’t get it to work every time but it did go into coasting.
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      05-22-2020, 09:24 AM   #17
kaipajo
Drives: G20 330e
330e can do this, f30 330e was already doing this. When coasting the engine is turned off, no matter what charge battery system has.
      05-22-2020, 10:29 AM   #18
hamera
hamera's Avatar
442
Yeah, I imagine not many BMW drivers care about this feature at all. Saving fuel? Are you mad?
      05-23-2020, 02:27 AM   #19
SoFlo_Nick
SoFlo_Nick's Avatar
Drives: Current (392 Widebody Charger)
The only time i use ECO Pro is if I'm cruising with little traffic, Other than that I like to have quick access to power.
      05-23-2020, 04:02 AM   #20
Eagle Creek
Netherlands
139
Agreed. Eco pro makes the throttle slow to respond. I found myself in a situation unable to overtake as quickly as I wanted and thereby hindering other traffic. That's why I don't use Eco Pro that often anymore.
      05-23-2020, 11:47 AM   #21
kaipajo
Drives: G20 330e
Yeah it's nothing to do with 48V instalation.
The engine isn't turned off. It's idling when coasting. Still injects fuel to keep it running. It still better to coast than engine brake under certain scenarios
For 330e the engine is for sure turned off, not idling. In eco pro the 330e is coasting/"gliding"
with no engine braking (so not charging batteries either).
Nothing to do with 48V yes, but he/she was wondering if 330e would be able do this.
      05-23-2020, 12:10 PM   #22
hamera
hamera's Avatar
442
My mistake. I was thinking about normal petrol engine, not the hybrid.
