09-10-2020, 09:16 PM | #89 |
1942
Rep 3,521
That is normal. Happens in all the cars I've owned to date.
09-23-2020, 12:59 PM | #90 | |
Rep 342
Drives: G20 330ix M Sport
09-23-2020, 01:52 PM | #91 |
Rep 23
Not exactly related but I got a 330i a couple months ago and just last week noticed that the passenger side mirror was facing up as in reflecting the sky instead of the road. I noticed the same thing two days later. I'm not sure if I mistakenly leaned my hand on the controls to cause that but I doubt it. Anyone ever notice anything similar?
11-11-2020, 02:06 PM | #92 |
Rep 1
I have had the reverse happen today, on my drive home from work noticed the drivers side mirror at a strange angle, when I stopped I tried to fold the mirror in using the manual button, only the passenger side folded in, I tried to alter the mirror using the toggle button and it wouldn’t work, fine for the passenger side, repeater light still works, no sign of damage, frustrating, I look like having to call the dealer in the morning!
11-14-2020, 10:17 AM | #93 | |
Rep 22
12-20-2020, 08:13 AM | #94 |
Rep 177
So apparently the replacement units are not that much better... Today my drivers side mirror didn't unfold. Has been already replaced, and lasted just for a couple of months.
01-07-2021, 03:53 PM | #95 |
Rep 473
Had both my driver and passenger modules changed this week as the passenger mirror only worked intermittently, more so in dry weather I found.
Seems to work ok but I have only had it back 3days. They did note the part has been changed to a different part number so hopefully this will solve the issue. Also the dealership noted a PUMA case was open for this fault now so BMW are aware in the UK. |
01-08-2021, 09:19 AM | #96 | |
Rep 1,039
01-08-2021, 10:03 AM | #97 | |
Rep 473
Seems they have recognised its a common fault and issued a new part. Just have to see over the next few weeks/ months if it fixes it. They did show me inside the mirror housing and its surprising all the kit in there especially if you have the blind spot assist and 360 camera. |
01-08-2021, 01:42 PM | #98 | |
Rep 1,039
Yup! There is a fair amount of electronics in such a small space. |
01-09-2021, 07:46 AM | #99 |
Rep 198
Just had the electronics on my side mirror replaced, it is working again. The guy at the dealer said that the problem is so common he wouldn't be surprised if there is a recall by BMW.
01-09-2021, 08:21 AM | #100 | |
Rep 2,699
Drives: 23 X5MC
02-26-2021, 06:28 PM | #101 |
935
Rep 4,326
Drives: M340
Well, this happened to me today for the 1st time.
Passenger side would not fold. I parked the car, left it for couple of hours and when I came back to it, the mirror was folded. Upon startup, it unfolded normally but started acting up again when I got home. I probably used this feature less than 20 times on m car and it still failed. I guess, I will take it in and schedule an in-between oil change while it is in there type of a thing. This is the 1st glitch from any BMW that I have owned in YEARS!
03-12-2021, 04:39 PM | #102 | ||
Rep 28
Replaced under warranty but was told its a common fault from the wiring getting pinched by the folding motor. Stopped using the feature as a result. |
03-17-2021, 09:32 AM | #103 | |
Rep 2
Booked in for Monday at a BMW garage. I’ll keep you posted. |
03-17-2021, 10:17 AM | #104 | |
Rep 1,667
Ego is the anesthesia that deadens the pain of stupidity.
The single biggest problem in communication is the illusion that it has taken place. Wheel horsepower is just crank horsepower after taxes. IG: EmFore_650 |
12-01-2022, 07:10 PM | #105 |
Rep 310
And... after 3 years and 40k kilometers I experienced this issue with side mirrors two weeks ago.
. A day or two after I washed it using high-pressure water nozzle I noticed that side mirror folding, mirror adjustments, and electric window buttons all stopped working. Basically, entire control cluster on driver side doors stopped working, except of the lock/unlock button. At the same time, electric windows were fully functional if operated from the button on other doors. Also, remote key fob function that makes all windows go up or down on long press was fully operational. A few days after driver-side electric window buttons became functional. Then, a day later, side-mirror angle controller was also back. Eventually, mirror folding was fully restored probably 5 days after they stopped working. Error code history showed that driver side (Left-hand drive) mirror folding electronics were broken, and the root cause was probably a moisture related short-circuit that took out the entire driver-door button cluster. BMW authorized service shop diagnosed that the driver-side mirror electronics are faulted (despite everything is working right now) and confirmed this is a common problem on G20 cars. They confirmed that new part is updated to address the moisture issue, but also noted that the problem still occurs even with the updated part. The shop does not have the replacement part available on stock. They ordered it today, and will be calling me back when they receive it. My question is: Did anyone experience the same issue AFTER the original electronics module was replaced with the revised one? |
02-07-2023, 10:42 AM | #106 | |
Rep 310
First: While I was waiting for my repair appointment my mirrors started working again. Nevertheless, BMW dealership replaced the Electronic module in my left (driver-side) rearview mirror on December 16. Since error codes stored in the car showed that the module in the left mirror failed. Less than 2 months later, both rearview mirrors and power window switches stopped working again. It happened exactly one day after I washed the car, being especially careful not to hit mirror housing directly with water jet. It's absolutely ridiculous that this car cannot be washed normally without breaking the mirrors and power window switches. Error codes are almost the same as the first time. Could be that right mirror now failed. I'll go to the dealership this week to get it booked again. Has anyone had any luck with repairs? Did the new revised control module permanently fix the issue Is this issue happening on 2021 or 2022 cars that supposedly have updated version of mirror control modules? Last edited by Calamari; 02-07-2023 at 03:56 PM.. |
02-07-2023, 12:25 PM | #107 |
Rep 187
Mine is 2020 model with full option mirrors (Driving Assist Pro, Parking Assit plus, Active guard plus, electricaly foldable, self dimming, heated, shadowline and with memory).
Both are changed last year under warranty with updated product number. On electronic was before transparent cover (you can see motherboard), on new one is black cover. First i had problems with right one (only 360' camera was working and blind spot monitor) and few months ago i had problem with left one (heating was not working). No problems with them since they changed both. Here i have photo of my new left one with black cover on electronic: |
02-08-2023, 05:36 AM | #108 | |
Rep 310
I'm visiting the dealership tomorrow so hopefully replacement of the other control module will fix the issue. |
02-08-2023, 03:14 PM | #109 |
Rep 13
Keep us posted please, going through the same thing. Is there a way that the water gets on the connectors on the back side of the mirror glass itself and shorts it?
02-08-2023, 03:18 PM | #110 |
Rep 13
In my case all window buttons and ambient lights work fine. The mirror adjustment, folding and blind spot monitor are completely dead though. On the right side. Had happened before once, it fixed itself, now it's been more than 2 weeks that passenger side one is dead again. And the car is out of warranty.
