BMW M3 and M4 - The Icons
home
      06-03-2020, 11:34 AM   #45
xlover
Drives: 2023 X7 40i
Originally Posted by seis-speed View Post
Some numbers that stood out to me....
Size
5.2" longer, 1" wider, .5" taller (only 2" longer than 3 series)
Weight
430i 3,578lbs, 430Xdrive 3,708lbs, M440 Xdrive 3,977 lbs
Quick thoughts
A manual will weigh ~ 70-100lbs less.
Xdrive is going to add a lot of weight.
The 4 door version looks better in the new dimensions.
The weight is not as drastic as 991.2 vs 992.
Added size is not as drastic when comparing to former 3series, but we need to see how the G80 dimension come in.
3 series has grown, so Mcar derivitive will grow, if you want a smaller car get an M2.
Can't wait to get specs on the G80 lineup.
A reminder too when using the US press release curb weights that the weights for the different versions (430, 430x, m440x) are probably not perfectly apples to apples.
US curb weight rules require manufacturers to include in the listed curb weight options that are expected to be ordered often.... there are going to be many more loaded exec pack m440s than 430 rwd. So the m440 curb weight is probably closer to the heaviest possible iteration for that version than the 430
mkoesel7511.50
solstice5456.50
      06-03-2020, 12:04 PM   #46
solstice
Drives: 2015 M3 6MT
@mkoesel
F32 430i RWD listed at 3574 lbs
F32 440i RWD listed at: 3704 lbs
F32 440i xDrive listed at 3827 lbs
F82 listed at 3625 lbs
- F82 is listed 51 lbs above F32 430i, 79 lbs below F32 440i and 202 lbs below 440i Xdrive.
- F32 440i Xdrive is 150lbs lighter than G22 M440i. Is that all mild hybrid system? I don’t know, some could be a fatter standard feature content of the M performance model. As noted as a caveat in my op and detailed by xlover there is also a question mark of apples to apples when using different sources for weight. (All F series weight listed are sourced from bmwusa.com while G22 is from press release). I.e. the M440i G22 could show up as 4K+ lbs when added to bmwusa.com which is eye watering but not necessarily an indication of the G82 doing the same.
ZF AT and M-DCT weight is within a few kg.
mkoesel7511.50
      06-03-2020, 12:18 PM   #47
mkoesel
Moderator
Drives: No BMW for now
Thanks for providing that data, solstice.
One other thing to be aware of: F32 430i/440i have a standard 8AT while the F82 has a standard 6MT. That accounts for part of the difference in the listed weights. While, as xlover points out, there are regulations governing automotive weights and measures, F8x 6MT sell-through was likely high enough to warrant its inclusion in the advertised weight. For the F3x, likely not. Hence the 8AT was standard on those cars (and for the new generation is no longer offered at all) and surely included in their weight figures.
We'll see how it all shakes out but I believe that even the RWD 6MT G82 is going to gain at least 50 lb. over a 6MT F82. The AWD 8AT Competition model is almost sure to touch 3900 lb.
solstice5456.50
JTO245274.50
      06-03-2020, 12:36 PM   #48
solstice
Drives: 2015 M3 6MT
Agreed and I think most including me will be happy with a 50 lbs or less gain and I would count that as within “good indication”
Note: I intentionally used the AT numbers for F32 due to the exclusion of MT in G22. The op was a comparison of F32 vs G22 platform as indication of 4 series platform weight gain.
      06-03-2020, 06:28 PM   #49
Hegge
Drives: 2020 BMW M2 CS
The AWD M4 approaching 3,900 pounds is one of the problems I have. Although I am intrigued by the AWD M4 and it's performance, I fear that I would have remorse not stretching for a 911.
Too many negatives about the M4: the grille, the car is huge, the weight of a nearly 4,000 pound car, no DCT. All those negatives while costing $80k plus would make me regret not stretching for a 911.
solstice5456.50
      06-03-2020, 08:01 PM   #50
solstice
Drives: 2015 M3 6MT
The AWD in itself will make the G82 M-Xdrive offer a very different and new experience for the M4. Performance will be blistering but more than likely at the expense of some traditional M3 “feel” when you add weight and new forces pulling on the front wheels.
It’s a cool and intriguing option to have. More options is better than less. The 992 is lovely btw. I drove a base a few months back. Superb car but less practical of course due to space. I’m still not 100+ sure which which way I will go. I will need the M4 to be launched so I can compare personal builds and specifications.
      06-03-2020, 09:01 PM   #51
Aaaaaaaaa
Drives: The other M3
The X3M weighs like 300 lbs more than the M40i so no I don't have high hopes for a lightweight G8X.
kyrix1st2361.50
      06-05-2020, 02:55 AM   #52
brad850csi
Drives: 16 F13 M6 Comp
I'm going 3700lbs for the 6MT RWD and 3950lbs for the 8AT AWD, +/- 50lbs on each. I would be really surprised if they are far away from that
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      06-05-2020, 06:43 AM   #53
spool twice
Rainbow Racer
spool twice's Avatar
Drives: BMW M4cs
2019 M4cs  [0.00]
Seeing as how the latest M5 kept weight in check with the addition of AWD over the previous gen, I suspect the G80/G82 will end up being more trim and closer to 3,750lbs, but who knows? Maybe wishful thinking.
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ]
Current Car: F82 M4cs | TT-RS | On Order: i4 M50
      06-06-2020, 02:32 AM   #54
kyrix1st
kyrix1st's Avatar
2362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
2004 BMW Z4  [0.00]
Only way to save the underwhelming design is to come out with a lightweight base car that drives phenomenally compared to the high standards that F8x M3/4 have set.
From the information "leaked" so far however, I doubt we'll see any M4 under 1600kg.
Pass me if you can.
steker155.00
      08-19-2020, 12:43 PM   #55
R N M
R N M's Avatar
3633
Drives: F80 M3
2016 BMW M3  [0.00]
It looks massive lol
Same size as previous 6series coupe i think.
DML967.50
low1352213.00
      08-20-2020, 01:03 PM   #56
FLOSS M
///M3
FLOSS M's Avatar
Drives: 22 M3 X-Drive
The M4 is huge, like a smaller M8 (saw the car in Monticello).
JSP///M4C103.00
      08-20-2020, 01:26 PM   #57
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Originally Posted by FLOSS M View Post
The M4 is huge, like a smaller M8.
Don't you mean bigger M8?
G82 is nearly identical in dimensions to the F13 M6.
CanAutM321116.50
      08-20-2020, 01:29 PM   #58
FinalRenegade
FinalRenegade's Avatar
Drives: M6 GranCoupe | Last Model Year
^That is hard to believe, the outgoing M6 is longer than the M8, I can't imagine the M4 longer than the M8
      08-20-2020, 02:38 PM   #59
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
You'd be surprised. Rear overhang is within 5mm of M8, wheelbase longer than M8/same as F13, front overhang is much shorter than M8/close to F13 without the front plate bracket included in the measurement.
CanAutM321116.50
      08-20-2020, 02:57 PM   #60
OriginalFake
Drives: 2023 M240i
Everyone saying how big it is...have you seen a G20? It's not exactly small so I don't know what people are expecting.
seis-speed2430.50
      08-20-2020, 03:08 PM   #61
tallshortguy
Drives: F30 328i
According to what M4 dimensions are you referring to? I haven't seen any released specs.
      08-20-2020, 04:43 PM   #62
hellrotm
Drives: F80
That is nuts. Especially considering your info is usually spot on.
      08-20-2020, 05:15 PM   #63
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Is it really though? F12/3 wasn't a good example of spatial efficiency. Occupant space was odd, the flying buttresses that had to be accommodated for the Conv made for a very long rear overhang, and the pronounced taper at the front caused the plate bracket to sit very proud. Of course all of that made for a clean aesthetic.
The Gxx 4er Coupé is bigger than its predecessor, but I don't think that's necessarily a bad thing.
      08-20-2020, 05:44 PM   #64
Al Pinã
Al Pinã's Avatar
Drives: Alpina XB7
There's no point of reference to determine the size...
Blessed Beyond Measure
      08-20-2020, 05:51 PM   #65
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Hint...
It sure as shit isn't smaller than a G22 M440i
CanAutM321116.50
Dinh335713.00
Jockey3449.50
mkoesel7511.50
Transfer5254.00
      08-20-2020, 05:56 PM   #66
kyrix1st
kyrix1st's Avatar
2362
2004 BMW Z4  [0.00]
At least F12 M6 Coupe had a usable back seat. M8 Coupe is impossible to seat in the back and while the trunk is longitudinally long it doesn't really hold a lot of carriers.
Pass me if you can.
g80
