08-28-2020, 02:53 AM | #23 |
Rep 2,499
Imagine caring about such a minor detail. The rear brakes do not need fixed piston brakes. I understand they don't look as nice, but you would have to sacrifice weight by adding another fixed caliper in the back to "match" the front or a large solenoid on a fixed caliper. Some carmakers do those things but it's extra unnecessary weight (and cost). I'm not sticking up for BMW here, but does it really matter? I'd personally prefer a normal parking brake but there's no chance of that happening.
08-28-2020, 03:25 AM | #24 | |
Rep 2,499
BMW did away with the bulky and heavy drum parking brake setup so that's no longer an option either. This is why up until recently, a lot of high end cars had TWO rear calipers. A floating caliper for the parking brake and a fixed caliper for the main brakes (basically for show). Technically even BMW had two calipers, you just couldn't see the drum brakes. Even some of the new fixed calipers that now support electronic parking brakes are just a fixed caliper brake and floating caliper welded together. They look kinda goofy, are heavy, and it's purely for aesthetics. They are not necessary on an M car essentially so BMW did not put one in. So it is a cost cutting measure in that sense that they could put some exotic bit in. But it's not a cost cutting measure in that if they could just put a traditional fixed caliper brake they would, but they can't without adding a lot more cost. |
08-28-2020, 09:02 AM | #25 | |
Rep 1,109
Drives: 2015 BMW 435i Xdrive MSport
2015 435i Xdrive (Klaus)
Stanced 8th Gen Honda Civic (The daily) |
08-28-2020, 10:18 AM | #26 | |
Blocked from G80/G82 for having an opinion
3497
Rep 3,729
08-28-2020, 12:07 PM | #27 |
Rep 1,109
There are electronic parking brake fixed calipers, BMW just doesn't want to pay for it. Big rear brakes help with making the car squat more under load, instead of noise diving.
AtlasF803.00 |
08-28-2020, 01:59 PM | #28 |
Rep 2,359
Drives: G87 M2; E92M3 MT&DCT; M3 euro
Nose diving has to do with front&rear brake bias (stopping force based on sum of surface area of piston(s)) rather than the size of the brake caliper. What multi-piston calipers excel in is stress management from heat. It is clearly a cost cutting measure nonetheless.
Pass me if you can.
Boostedphil698432.00 |
08-28-2020, 02:58 PM | #30 |
Rep 1,109
I totally agree. It's all about minor details too.
08-28-2020, 03:20 PM | #31 |
Rep 7,037
I’ll be disappointed if any of the following is true vs the F8X brakes:
- Longer stopping distance. - Earlier onset and/or increased brake fade. - Longer cool down time. - Significantly shorter life span. Aesthetically I don’t care about the calipers size or number of pistons. I do care about the rotors aesthetically though, small rotors inside large wheels is an eye sore and I like the look of drilled rotors. |
08-28-2020, 03:28 PM | #32 |
Rep 4,106
Why everyone is just about numbers? Most HP, biggest brakes etc.
With less HP and smaller brakes the Gx will still faster and stop better as any 800hp red eye hellcat with big ass brakes. I don't care about the pistons on my rear calipers and I will buy the G8x, just sold my F82 ZCP. |
08-28-2020, 04:52 PM | #33 | |
3497
Rep 3,729
08-28-2020, 09:52 PM | #34 | ||
Rep 1,109
08-31-2020, 03:50 PM | #35 |
Rep 212
Porsche went w/ electronic parking brakes years ago
And, yet still continues to install beautiful Brembos on the rear axles of Boxsters, Caymans, 911s, etc.
BMW's decision to decontent the M3/M4 (with no better rear brakes than an an econo box) is a real disappointment to me. It is visually unappealing and just looks cheap. Aesthetics are important. If they weren't, there wouldn't be so many outcrys about the grille. |
MFNATIK3497.00 |
08-31-2020, 08:00 PM | #36 | |
Rep 1,109
MFNATIK3497.00 |
09-01-2020, 12:20 AM | #37 |
Rep 3,726
BMW's electronic brake implementation has been horrendous. My wife's car has them and it's probably the most annoying feature of the car. The button works half the time and it usually takes me two tries to get the brake to engage or disengage. A manual hand brake is so much better.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
09-01-2020, 01:09 AM | #38 | |
Rep 2,349
I've never driven a manual with a push button handbrake though and I must admit I'm worried about that a bit
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
09-01-2020, 06:25 AM | #39 |
Rep 1,109
I don't understand why electronic parking brakes are even a thing.
09-01-2020, 08:09 AM | #40 |
Rep 253
Don’t understand what people are discussing here to be honest but I will still add my thoughts on this very important subject. 😅 I have a habit of engaging the parking brake every time I park my car and I have never had any problems turning the electronic parking brake on or off. When bmw came up with it I thought or felt absolutely nothing about it... it works good, saves space, reduces weight and maintenance so in the end, who cares! As for the rear brake calipers, they are small, excellent! It’s a huge weight saving and they work better then they need to! Have you seen those huge unnecessary brakes on an M2 Comp. that add like half the M2’s weight? They just about add enough braking effect to compensate for their own weight gain and makes M2 overall heavier than M4. Porsche has better brakes? So go and buy a Porsche! I would anyways, if I would be slightly richer! Wouldn’t need to save money on a Bimmer... 😁
09-01-2020, 08:23 AM | #41 |
Plenipotentiary
2614
Rep 3,046
Does that usually happen with the beast sitting at an incline?
09-01-2020, 10:20 AM | #42 |
Rep 7,037
We have eBrake on our Cayenne and this is the only time it fail to work like clockwork. Parking in an incline and then reversing out of of the there. The eBrake on the Cayenne does in this scenario often get confused and applies the brakes again after the initial release on throttle. It takes a little wiggling to get going.
09-01-2020, 10:43 AM | #43 | |
Rep 241
Drives: BMW M4 DCT Coupe
I also cringe when I see people parking their automatic tranmission car on TV/films, then they get out and I see the car rocking against the P-lock - no wonder people are always talking about getting a trans rebuild!! My two cents on the nub of this debate; I'm not really too fussed, never tracked any of my cars and so I've found ABS (or ice!) to be the limiting factor in any hard braking I've ever done on the road |
JTO245271.50 |
09-01-2020, 10:56 AM | #44 | |
Plenipotentiary
2614
Rep 3,046
