03-26-2023, 08:27 AM | #1 |
Rep 589
Rec a big brake kit for m340?
I have the standard 340mm rotors. What is cost effective way to upgrade braking power?
Any recommendations are appreciated. Thanks |
03-26-2023, 10:00 AM | #2 | |
Rep 1,521
1. M-Performance kit - easiest plug and play option. 2. Utilize a set of front calipers from a G05 series X5M, a set of front rotors and full rear setup from a G01 X3M - most difficult and time consuming option. |
03-26-2023, 10:06 AM | #3 | |
Rep 589
What about a 3rd party like stoptech or brembo? |
03-26-2023, 10:08 AM | #4 |
Rep 1,521
03-26-2023, 05:47 PM | #5 | |
Rep 1,115
There are many aggressive brake pads available that work well with stock rotor/caliper.
Chubbiejones891.00 |
03-26-2023, 10:45 PM | #6 |
Rep 235
Infinite Autowerks is working on a G80 conversion. I am first in line to get it. I was originally going to do the G05 setup but did not want the extra weight of the 395 rotors and was worried about them fitting under my 19" wheels. So I am in line for the first set of brackets and lines for the G80 brake conversion.
2024 G87 Zandvoort Blue M2 w/ Buckets - Stock 93| 0-60 TBD | 1/4 TBD | 60-130 TBD
2020 G20 Tanzanite Blue II M340 xDrive - E30 BM3| 0-60 3.28 | 1/4 11.39@123 | 60-130 9.56 Past: 2017 W205 Black C43 AMG - E40 FBO No Turbo | 0-60 3.21 | 1/4 11.18@124 | 60-130 9.17 |
03-27-2023, 08:40 AM | #7 |
Rep 589
I would like to have brakes that are at least as strong as the 2016 340i with Track Handling Package. But if I have to spend more then I want to get as good a set of track brakes as I can fit.
03-27-2023, 10:08 AM | #8 |
Rep 1,115
I think the OEM m performance brake kit would suffice if that’s the case. Are you tracking your car? If so, just an FYI I have not had any issues with stock rotor and more aggressive pads. I’m also not advanced, I am a novice/intermediate.
03-27-2023, 11:24 AM | #9 |
Rep 351
Drives: 2023 M340i
You can get the M Performance one of you didn't get the ZTK package. But it is pricier. On the plus side, the rotors come slotted.
04-11-2023, 04:25 AM | #11 | |
Rep 12
I'm also thinking about changing my brakes to something better than 374mm M Performance brakes... I investigate currently if BMW M3 G80 brake caliper and rotors can be fitted to BMW M340i at all. There's some adapter that should fit the bolts to 3 series caliper mount but I'm not sure. Best info I found so far is only this picture of caliper with adapter. Last edited by jaworq; 04-11-2023 at 04:31 AM.. |
04-13-2023, 10:50 AM | #13 | |
Rep 353
Drives: 2021 M340i xDrive
04-14-2023, 02:52 AM | #14 | |
Rep 12
Even BMW uses such adapters. Look at 8min 55 sec - I think it's the same adapter. He is swapping the original brakes: Last edited by jaworq; 04-14-2023 at 03:00 AM.. |
04-17-2023, 05:05 AM | #15 |
Rep 562
I checked out some 330i VT2 class race cars and NLS practice in Nürburg last Friday… They were running AP Racing fronts and either M Performance or M Sport rears.
Are you tracking the car? |
04-23-2023, 07:18 AM | #16 |
Rep 589
Thanks. I am not tracking the car except occasionally. But if I’m adding 200hp, wider tires, etc. i want to help out the braking department to keep up with the new performance.
04-23-2023, 03:59 PM | #17 | |
Rep 1,521
Lol, so you think the engineers at BMW would toss a “flimsy aluminum adapter” on a competition model vehicle just for giggles…. |
04-24-2023, 09:15 AM | #18 |
Rep 589
From an engineering perspective direct fit is almost always superior. When you add In the adapter you 1) require longer screws 2) introduce a static stress riser such that a lot more of the braking stress impacts the screw as opposed to the caliper.
