04-01-2023, 03:51 PM | #1 |
Rep 27
What is the g20 made of?
Hey guys, I just came from a VW and bought me a g20 2020 BMW m340. I wanted to know what type of metal does BMW use on fenders, hood, doors. I can't find a graph for the 2020 model
04-01-2023, 04:00 PM | #2 |
Rep 351
Drives: 2023 M340i
04-01-2023, 04:08 PM | #3 |
Rep 27
04-01-2023, 09:34 PM | #4 |
Rep 6,241
Drives: 2018 340i M Sport
https://g20.bimmerpost.com/forums/sh....php?t=1540476
CHASSIS / SUSPENSION / AERO Body-in-white lighter by 44 lbs. Body structure lighter by 16.5 lbs. Aluminum hood and front fenders saves another 33 lbs. Overall body rigidity up 25%; as much as 50% in certain areas Suspension spring rates increased by 20 percent without loss of comfort Lift-related dampers use for first time in a BMW model (featured on both regular and M Performance suspension) Reduces body movement perceptibly smoothing out vibrations caused by bumpy road surfaces and dynamic cornering. The system adds extra hydraulic damping at the front axle and a compression limiting system at the rear. It is continuously variable and adjusts the damper firmness progressively according to the changing spring travel. This prevents excessive body dive when driving over large bumps and so avoids uncomfortable, nervous damping response. Ride comfort and acoustics both improved Aluminum swivel bearings and control arms for the front axle, aluminum wheel mounts and a new generation of wheel bearings for the rear axle significantly reduce unsprung mass Front spring struts and engine sub-frame now made of aluminum Drag coefficient (Cd) of 0.26, a reduction of .03 Cd over F30 3 Series
