12-21-2023, 09:46 AM | #1 |
Rep 570
Drives: 2023 BMW M340i
Bm3 flex fuel vs OTS e50
So recently I had a bm3 flex fuel sensor installed into my car and started to use the bm3 stage 2 multi map to take advantage of flex fuel. My first fill up on flex fuel I filled without any measuring and it ended up at e46. It most definitely felt faster, but in my head I thought it felt slower than I remember the e50 map feeling, but I chalked it up to it being e46 not e50. Now I filled an e50 tank the other day and it still felt sluggish using flex fuel, so I flashed the e50 map to see if it was in my head or not. It wasn’t in my head, anyone else know why the flex fuel map would be slower even though it has the same level of e in the tank? Also, I did confirm with bm3 that the sensor was indeed functioning correctly by sending them a log and they confirmed it was ok.
12-21-2023, 10:29 AM | #2 |
Joint Chiefs of Staff
24198
Rep 190,807
Its probably all in your head and its not slower, but to be 100% sure, datalog both mixes
12-21-2023, 09:05 PM | #3 | |
Rep 308
12-21-2023, 09:28 PM | #4 |
Rep 570
Idk, I was kinda ruling it out as that in the first place, but I literally did a pull, parked and reflashed, did another pull and I noticed immediately. Its just not as jumpy, like the low end is sluggish, but the top end is about right.
12-21-2023, 10:37 PM | #5 |
Rep 570
Not really sure if there is a “solution” for this. Might just be how flex fuel is and I’m just retarded, but since bm3 already confirmed everything looks ok my only options for help are here and the fb group so we’ll see. In the mean time I just been using the sensor to confirm my mixes and just running the e50 map.
12-22-2023, 02:10 PM | #6 |
Rep 30
Have you been able to get into contact with BM3/protuning freaks at all this week? I sent them an email with my unlock file from Femto on Monday and haven't heard back from them. I'm thinking they're out for the holidays since they have always been super responsive. I installed the flex fuel sensor and have the same maps set to download. I'll let you guys know if I experience anything different.
12-22-2023, 02:40 PM | #7 | |
Rep 570
12-23-2023, 08:50 PM | #8 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
Should make similar power, actually make a log on both and send it to support@protuningfreaks.com Tech Support team usually responds within 48-72hrs
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
12-24-2023, 05:18 AM | #9 |
Rep 1,004
only way to tell for sure is log both, check boost pressure, timing, and load. Numbers don't lie.
Jnasratyar359.00 |
12-24-2023, 06:21 AM | #10 |
Rep 121
Compare Dragy 60-130 on both maps maybe
Jnasratyar359.00 |
12-24-2023, 11:34 AM | #11 |
Rep 570
I’ll run logs on both today possibly and see.
12-24-2023, 11:37 AM | #12 |
Rep 570
03-21-2024, 11:57 AM | #15 |
Rep 25
Drives: 2020 BMW M340
03-22-2024, 12:22 AM | #16 | |
Rep 238
RNigel21.00 |
03-22-2024, 12:42 AM | #17 | |
Rep 570
RNigel21.00 |
03-22-2024, 11:02 AM | #18 | |
24198
Rep 190,807
if you are not changing fuel octane, you are better off selecting the dedicated map for that fuel instead of the multimap
03-22-2024, 11:04 AM | #19 | |
Rep 25
03-22-2024, 11:30 AM | #20 |
Rep 102
Actually… what you need to be doing is looking at the interpolation values when you’re running the multimap. The multimap can and does provide more power, provided you’re at the correct ethanol content for it. It will vary from map to map, however on the ACN91 ST2 multimap, roughly E60-62 gets you 1.0 for all of the different interpolation values. The car is noticeably faster than the E50 OTS map.
03-22-2024, 11:32 AM | #21 | |
Rep 570
03-22-2024, 11:33 AM | #22 |
Rep 102
