07-21-2007, 01:01 PM | #23 | |
Rep 16,407
The main reason I got it was it really makes the center area look alot better than just having the standard radio there. |
07-21-2007, 01:21 PM | #24 |
Ironchef
92
Rep 495
I almost bought a C6 after my M3 as well. The only thing that prevented the purchase was the need for a back seat. Those motors are just waiting to be modded and it is just crazy the amount of power that can be had with just bolt ons and relatively minor head work.
20 X3MC AW
15 F80 BSM M3, BM3 09 C63 AMG, Eurocharged Flash, Klassen Monoblocks - sold 07 E90 335, UR Exh, Helix IC, Bav Sport Coils, iForged Swift- sold E46 M3 - gone and always missed |
07-21-2007, 01:29 PM | #25 | |
Rep 16,407
07-22-2007, 04:42 AM | #29 |
Rep 14,401
I don't know where you are in Texas but if you see the car in my sig, wave me off please. I don't like to get humiliated.
Crazy Diamond
07-22-2007, 09:50 AM | #30 |
Expert Road Racer
59
Rep 1,329
One thing to keep in mind for those on the fence about 'Vette like me due to the interior, the '08+ offer a high end interior package
07-22-2007, 10:47 AM | #31 | |
Rep 16,407
Little by little all the old baises against the Vette are disappearing. Last edited by Carnage; 07-22-2007 at 11:04 AM.. |
07-22-2007, 11:28 AM | #32 | |
Ironchef
92
Rep 495
I rarely have more than 2 people in my car, but that second person is my daughter (toddler). Trust me man...I really wanted the C6...sigh...Like yourself, I don't fit the typical Vette demographics but seeing the prices with the GMSD prices made it really hard to pass it up. To me the 07 interior is not as bad as people make it out to be, and I'd even say it is better than the previous gen G35(infiniti). I'm guessing the 08 must be really sharp and it is good to see that GM is really making the vette a better all-around-marque sports car.
20 X3MC AW
07-22-2007, 12:03 PM | #33 | |
Rep 16,407
The C6 interior is not that bad. Could it be better, sure and there are some nice upgrades available if you want to spruce it up a bit. Hell, it's not like the E90 interior is the lap of luxury either. |
07-22-2007, 04:32 PM | #35 |
Rep 14,401
I saw an ad in the Dallas paper the other day.."7 Z06's 6,000 OFF"
Crazy Diamond
07-22-2007, 05:24 PM | #37 | |
Rep 16,407
Not having chrome wheels was one of the reasons I ordered the car, much better ways to spend that $1,800 IMO. |
07-22-2007, 05:29 PM | #38 |
Rep 2,916
so is the LS3 much more capable of modding than the LS2 carnage?? or it's only the extra hp it has as stock??
btw your car is an eye candy
19" velocity CSL replicas staggured // Continental sport contact 2: rear: 255/35/19, Front: 235/35/19 // Blacklines // rear OEM spoiler // y-connector // 30% v-kool tint all around // Black Roof/Mirrors // H&R Sport springs // H&R TRAK+ 15mm spacers // BMW never makes ordinary cars . . . |
07-22-2007, 05:38 PM | #39 | |
Rep 16,407
The LS3 has a larger displacement then the LS2 (6.2L v. 6.0L) and it appears to be getting more gains from similar mods. Based on some early dynos, it looks like the stock 430HP quoted from GM is under rated too. Looks to be more in the 450 range. Here's some good info on it from corvetteforum...cliff notes version, .2 liters larger, L92 heads based on the Z06's LS7 motor, improved intake (similar to the L76), slightly better cam (more lift on the intake side), better oil galleys, different inlet with integral maf, inlet silencer. The LS3 features an aluminum cylinder block with cast iron cylinder liners. In addition to its larger bores, which help create a 376-cubic-inch displacement, the block casting also features revisions and machining in the bulkheads that enhance its strength and improved bay to bay breathing. But while the bore of the 6.2L engine is increased when compared with the previous 6.0L engine, the engine's stroke remains at 3.62 inches (92 mm). The pistons for the larger 6.2L engine also are new and are designed for its high-rpm performance capability. Breathing for the new 6.2L engine is accomplished via new, high-flow cylinder heads. They're based on the large port/large valve design found on the LS7 engine and other GM L92 engines, with larger-capacity, straighter intake ports. The design optimizes intake flow to the combustion chamber and the exhaust ports are also designed for better flow. Complementing the larger-port design of the heads are commensurately sized valves. The intake valve size alone increases from 2.00 inches (50.8 mm) to 2.16 inches (55 mm) – an increase of nearly 9 percent. The intake valves feature lightweight hollow stems, which enable the engine's 6,600-rpm capability. The exhaust valves also are large, measuring 1.60 inches (40.4 mm) in diameter. To accommodate the engine's large valves and enable more direct intake port flow, the intake-side rocker arms are offset 6 mm between the valve tip and the push rod. Actuating the valves is a new camshaft, with intake-side lobes providing more than a 5-percent percent in increase in lift, from 0.521-inch to 0.551-inch (13.25 mm to 14 mm). Exhaust-valve lift remains unchanged from the LS2. The camshaft timing was revised to optimize performance with the higher-lift intake cam profile. Ensuring the cylinder heads receive all the air they can handles falls to a new, acoustically tuned intake manifold. The composite design is manufactured with a "lost core" process that improves runner to runner variation and reduces airflow losses. An acoustic foam material is used to reduce radiated engine noise; it is sandwiched between the outer top of the manifold and an additional "skull cap" acoustic shell. Also new beauty covers atop the engine shield the rocker covers and also feature a noise-reducing, acoustically tuned insert to provide a more refined engine sound. |
07-22-2007, 05:43 PM | #40 |
Rep 16,407
as far as the under rating on the stock HP goes, here's a dyno sheet on a bone stock 2008 vert' with 800 miles on it, same shop...most stock 06/07 6 spd. pulled around 345-350HP on a DynoJet so the LS3 looks to be putting out about 50 more HP to the wheels but they are only rated 36 HP higher than the LS2.
07-22-2007, 07:49 PM | #41 |
Rep 957
Drives: 2022 X3 M40i
Are there any driveline changes to the '08 model that may account for the gains as well? That's a nice jump in HP for a refresh of a model line.
Only problem I see is that the demographic driving the cars don't use more than 100 of all of those HP. |
07-22-2007, 08:50 PM | #42 | |
Rep 16,407
The TR-6060 has about double the amount of syncros for smoother gear engagement and has a higher torque capacity. Smoother, easier, and shorter shifts...less notchy. The change shouldn't be doing much of anything in terms of gains. The big change is the motor itself. The guy I bought my '07 from has good info on the '08's on his website. http://www.corvettesbyrickdaniel.com/models_2008.html |
07-22-2007, 11:09 PM | #43 | |
Rep 2,916
wow thanks for the info Carnage, that was a good read
