01-29-2024, 10:29 AM | #2 |
Rep 385
No. First you need to "compensate" a different tire width by using another profile number. Then, the nominal size and profile designation on the tire is no guaranty that the actual rolling circumference difference is within 1%.
What you need to now about the designation: www/pp/dd: www: tire width in mm pp: profile in % (i.e. tire sidewall is www*pp/100 [mm]) dd: rim diameter in inch Theoretical diameter would then be dd*25.4+2*(www*pp/100) [mm]. |
01-29-2024, 02:13 PM | #3 |
Rep 3,227
Just use this, https://tiresize.com/comparison and no, it doesnt work.
