Technical Topics DIYs and Coding Discussions Your BMW Might Have A Hidden TESLA Mode?
      11-26-2020, 06:50 AM   #133
ifr
ifr's Avatar
1198
Drives: Tesla MY LR AWD
Originally Posted by phayze View Post
Do you have any idea if BMW is more particular on VO coding or FDL coding? Or they are the same to BMW?
I'm not sure I understand the question?
What are you trying to achieve? Buy esysx and FDL code the values, or VO Code with esys. As long as you don't write the FA to the car the end result is the same.
      11-26-2020, 07:15 AM   #134
phayze
Drives: BMW
What is the different between FA and VO coding?
      11-26-2020, 07:46 AM   #135
ifr
ifr's Avatar
1198
I think you need to do a lot more research on coding. Start here:
https://www.bimmerfest.com/threads/c...sheets.983245/
      11-26-2020, 08:02 AM   #136
phayze
Drives: BMW
Ok. Thanks for the link.
      11-28-2020, 10:09 AM   #137
phayze
Drives: BMW
I had tried using e-sys to read and and activate FA. After read the cafd, i cant edit anything and i get “No EST file chosen. [C155]” error. Any idea what i’m missing out?
If you have 8TR in your FA/VO then it is being used by BMW to decode the auto Lane Change in coding. This can be checked in esys, or even via a VIN decoder.
Removing it from your FA and VO Coding the specific ECU(s) that it impacts, will revert the coding and activate the decoded feature. If you save the modified FA back to the car then the feature will remain active even after full-car i-step upgrades.
      11-28-2020, 12:13 PM   #138
ifr
ifr's Avatar
1198
I had tried using e-sys to read and and activate FA. After read the cafd, i cant edit anything and i get "No EST file chosen. [C155]" error. Any idea what i'm missing out?
You can't use esys to fdl code without a launcher
      11-28-2020, 08:10 PM   #139
phayze
Drives: BMW
Any idea how do i VO code the below using E-sys?
BDC_Body3 > CAFD_7083 > SPURWECHSEL_ASSISTENT
Default: nicht_activ
Change to: activ
HU_MGU > CAFD_3E52 > SPURWECHSELASSISTENT
Change to: gen_1
SAS2 > CAFD_42C1 > C_SWA_VORHANDEN
Default: Nr000_nicht_vorhanden
Change to: NR001_VORHANDEN
      11-29-2020, 07:36 AM   #140
Heliot077
Drives: BMW G21
Thats FDL. You need a launcher!
      11-30-2020, 10:52 AM   #141
phayze
Drives: BMW
Hi,
Any idea how do i VO code the below using esys?
In theory that should work fine, but you would also need to VO Code:
HU_MGU (that controls the menu item)
SAS2 (or SAS3 if on i-step 07/2020 and later) - this sets and enables the type of lane change used. USA version works much better than the non-US version, but youd need to FDL code to change it. If you find the lane change slow/cautious in changing lanes then you probably have the non-US version set.
BDC (7083) - that makes the menu item active
You can do all of this from esys without a launcher needed
      12-08-2020, 02:11 PM   #142
gannys
Drives: BMW 330i
Wanna do this on my 2019 330i. But I wonder if the assisted driving view requires the 360 degree surround cameras to make it work. My 2019 330i has DAP Pro but no 360 cameras
      12-08-2020, 04:25 PM   #143
ifr
ifr's Avatar
1198
You just need 5AU DAP and istep 07/2019 and later
      12-13-2020, 02:46 PM   #144
anri1
Drives: BMW E46 Facelift
Hi,
Is there possible to code Assistance Drive View on my car and how?
I have g20 produced 6.2019. Software 11.20.36
My car owns S5AU Driving Assistant Professional
My friend has a bimmercode and we want to enable this feature if is it possible. So, we need step by step how to activate it.
Thanks in advance.
      12-14-2020, 05:08 AM   #145
farukdanis
Drives: 320
If you have 8TR or 8TU or 8LS or in your FA, and you remove it, then VO Coding BDC, SAS and HU, will automatically set those FDL settings.
Alternatively you can FDL code the above, but will need a launcher for esys, and you will need to recode after each i-step upgrade where any of the target ECU are upgraded.
Hello
Thank you very much for this information.
I want to open this feature as you mentioned. I'm more amateur on this.
So could you write something a little more descriptive? about how to do it?
If there is a video of a similar operation, it would be great if you could post it?
      12-14-2020, 05:58 AM   #146
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
anri1 ,
From what information you provided, it should be able to be coded in your car.
HOWEVER, Lane Change Assistant can NOT be coded with Bimmercode because Bimmercode can NOT code the SAS module
Al
Retired: 2014 328i
BMW CCA
      12-14-2020, 06:57 AM   #147
anri1
Hi.
Thank you for replay.
I don't need Lane Change Assistant. I just want Assistance Drive View and Remote Engine Start.
      12-15-2020, 05:06 PM   #148
Aero7000
Aero7000's Avatar
246
Drives: M340i DravitGrau / Cognac
Have a question???
Just got my first OTA software update notification....07/2020.80 ready to be installed.
Will it override the coding done on the car?
I have coded Anti-dazzle high beams, AS/S-Off, Assisted driving view, bunch of other stuff.
I used Code my bimmer guy's and don't want to lose it.
Anybody has experience with it?
      12-15-2020, 05:12 PM   #149
ifr
ifr's Avatar
1198
Originally Posted by Aero7000 View Post
Have a question???
Yes, most if not all of it depending on what istep you were on previously.
The bigger the jump in software version the more ECU that are likely to be programmed and recoded to your car baseline VO.
Kombi, KAFAS, bdc, hu_mgu, will all be wiped. Not sure about DME
      12-15-2020, 05:13 PM   #150
RSnic
RSnic's Avatar
Aero7000 ,
When my car got its first OTA several weeks ago, almost all of my custom coding was gone. Having said that, however, that wasn't a surprise since anytime my car got an update, it meant that I had to re-code the custom coding
Al
Retired: 2014 328i
BMW CCA
      12-15-2020, 05:18 PM   #151
Aero7000
Aero7000's Avatar
246
Thanks ifr and RSnic,
I checked the upgrade list and there is nothing really worth the hassle.
I will just cancel it.
Cheers
      12-21-2020, 04:30 AM   #152
bimmerelectric
Drives: Bmw 330e 2019
There is no single answer for this, but for esys coding the gold standard is diag mode with a voltage regulator connected.
Never code DME ECU with the engine running.
SAS etc won't appear except in diagnostic mode/engine running
VIP2 cannot be coded on later I-step except in diag mode
So the best approach is diag mode but then there is increased risk of battery drain and shutoff hence using the voltage regulator/battery charger to be minimise risk.
if I do coding on a 330e should I code with engine running or in diagnostic mode (w/o charger but vehicle fully charged) ?
is diagnostic mode using the high voltage battery ?
      12-21-2020, 04:46 AM   #153
ifr
ifr's Avatar
1198
I do most of my coding in diag mode without the engine running, but with a full(ish) battery.
I do programming with a voltage regulator attached.
Best practice would be diag mode with a battery charger connected, but in reality, as long as your battery has decent charge, you turn off HAVC, lights and media, and don't spend hours at it, coding without a charger should be fine. You get warnings when the battery is running low.
The lowest risk approach is to keep the engine running for all ECU coding except VIP and DME. I expect the same principles to apply with a plug-in hybrid, but I don't have one.
      12-26-2020, 12:07 PM   #154
bimmerelectric
Hi,
Can i say by removing 8TR, lane change assistant will automatically shows?
Or i still need to code the below?
Change to: activ
Change to: gen_1
I don't have any of these in my FA ?
Only 801,851,879,8EK,8KA,8R9,8TF
edit: I did some research on another discussion and 801,851,879 are language settings and 8TF is pedestrian protection
And is there a database where i can find out the meaning of each of these ? (I only found 1 posting and it was for F30)
Sorry for bothering u again. I hope u have a wonderful Christmas time
