09-13-2019, 08:29 PM | #45 | ||
Rep 92
09-13-2019, 11:25 PM | #46 |
Rep 387
No problem! Thank VW, these are some great hooks!
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive WE ARE! |
09-15-2019, 11:25 AM | #47 |
Grumpy Old Git
443
Rep 923
After following this discussion I’ve dived in and ordered two of the VW/Audi type bag hooks from eBay. Seller is in China but at (£2.99) $3.50 each (including delivery) it’s worth a shot.
Time will tell .......
Retired:
09-17-2019, 11:15 AM | #49 |
Grumpy Old Git
443
Rep 923
This was explained on page 1 of this thread. Extract below.
“Here is your pro tip for this one.. I bought a couple grocery bag hooks from a VW Passat and have been moving them to each new 3-series I have gotten. They are spring loaded and fold up automatically when not in use and work perfectly to secure a bunch of bags. I have 2 of them installed in my trunk. https://www.amazon.com/Cargo-Trunk-P...R3B2HJYBP05EZZ I use a small self tapping sheet metal screw to secure it to the top of the trunk. If you do this, please make sure that there is nothing on the other side of the body panel you drill into, look for wires, and make sure you don't drill through to the outside, be very careful. Also be sure to leave clearance for the trunk floor to swing up to the holder clip thing.”
Retired:
09-17-2019, 11:17 AM | #50 | |
Rep 490
09-17-2019, 10:14 PM | #52 |
Rep 387
That makes me upset, I have to go through the asspain of installing them myself and somehow you got them? I want the net!
09-19-2019, 05:42 PM | #53 |
Rep 395
Yeah wth my F30 330e had both the net and the hooks and just picked up the G20 330e today and it has neither, not cool
I still have my F30 boo tnet, did anyone find out if it is possible to retrofit the plastic holders for the net in the trunk floor? Any idea on part numbers? Seem to me like parts 10/11 here: http://bmwfans.info/parts-catalog/F3...loor#7248530_2 Last edited by sd_dracula; 09-19-2019 at 06:12 PM.. |
09-20-2019, 03:59 PM | #54 | |
Rep 387
09-21-2019, 09:41 AM | #55 |
Rep 490
09-21-2019, 10:04 AM | #56 |
Grumpy Old Git
443
Rep 923
Interested on how the tape works.
Retired:
09-21-2019, 12:58 PM | #57 |
Rep 500
Just drill those holes. It really is no big deal at all. There are even other holes already there - you can put your finger in to see how much clearance you actually have.
09-25-2019, 05:50 AM | #58 |
Grumpy Old Git
443
Rep 923
Hooks from China arrived..... only 10 days after ordering 9n eBay.
Just need the car so I can fit them. Car should be with me by the weekend.
Retired:
10-02-2019, 08:12 PM | #59 |
Rep 387
I finally got around to putting the VW hooks in my car and figured I would share the location of my holes. I previously ground the mounting face of the hook flat on a belt sander, 6 years ago I think, I have been moving these hooks to every new car. To make the holes I used a #2 center drill to pilot the holes which was very controlled and only went through the sheet metal about 2mm. I then stuck a thin drill bit into the holes to probe around and make sure nothing was above the panel, the 4 holes I drilled were all clear. I then used a sheet metal screw through the pilot hole to secure the hooks in place. Again.. your car might be different, please be careful, I take no responsibility for anything that happens to your car.
FlyingScot105019.00 |
10-04-2019, 07:21 PM | #60 |
Rep 751
I have a net on each side and 1 hook on the driver's side. US M340
10-05-2019, 01:51 PM | #62 |
Rep 387
I have this setup with no spare tire.
10-05-2019, 07:18 PM | #63 |
Rep 751
10-07-2019, 07:49 AM | #64 |
Grumpy Old Git
443
Rep 923
Azwllnj
What size/length & type of self tapping screw did you use? Looking at doing the same as you.
Retired:
Hysnbrg192.50 |
10-08-2019, 01:09 PM | #65 |
Rep 387
A #6 or #8 would likely work fine. Length depends on whether you use a self tapping and if you plan on removing the raised cylinders on the mounting face of the hooks. I removed the cylinders and did not use self tapping screws, mine were about 1/2" long, the amount of screw protruding out of the bottom of the hooks was about 1/4 inch, just enough to grip the sheet metal at full screw diameter.
10-08-2019, 02:15 PM | #66 |
Grumpy Old Git
443
Rep 923
I appreciate the response. Thanks
Any chance of a picture showing the screws in situ?
Retired:
