2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Do F30 BMW Roof Rails fit on the G20?
      08-17-2019, 08:58 PM   #1
TheObviousChild
TheObviousChild's Avatar
322
Drives: '23 M3 Comp xDrive - '21 X3M40
Already found out my F30 winter wheels have a different lug pattern. Hoping maybe I can at least salvage the rack base system. Not very hopeful.
Current: 2023 G80 ///M3 Competition xDrive in Atlantis / 2021 X3 M40
Previous: 2020 M340 / 2017 X3 / 2016 340xi / 2013 335xi / 2011 X3 / 2010 328i / 2007 328i / 2004 325i
      08-23-2019, 11:16 AM   #2
nlopezesq
Drives: 2020 BMW M340i xDrive
Roof Rails
I too hoped to reuse the rails from my 2017 340i. I noticed they changed the bolt size (M6 to M7), so I thought I could reuse by just swapping out the bolt. However, I just called my local BMW dealer and they informed me the rails changed too. Begrudgingly just ordered a new set…
      08-23-2019, 10:54 PM   #3
TheObviousChild
322
Bummer. Onto Craigslist they go.
Thanks for sharing that info. Appreciate it.
      08-24-2019, 01:18 PM   #4
Jebk
Drives: G20 330e
I've had oem rails the last 2 cars, this time I'll be getting thule ones. At least theres a passing chance I'll be able to reuse them then.
      08-26-2019, 01:18 PM   #5
azwillnj
Drives: 2023 M340i xDrive
I unfortunately don't have my rack here to test it, but I can confirm that are little doors are on the rails just as they were on the E90 and the F30. I used my E90 roof rack on the F30 with no issues, I am assuming the same will be the case for the G20. As I mentioned, I don't have access to the rails at the moment, and it might be a few months until I can test it, but I can take some measurements if anyone wants.. or at least find the correct bolt size.
Current: 2023 G20 LCI M340i xDrive
History: 2005 E90 325i > 2008 E90 328xi > 2011 E90 LCI 335i xDrive > 2013 F30 328i xDrive > 2016 F30 LCI 340i xDrive > 2020 G20 M340i xDrive
WE ARE!
      09-15-2021, 08:50 PM   #6
Curtiswg
Drives: 2019 330i X drive
I‘ve gone from the e90 to f30, no issues. The g20; the fun stops with the roof racks. Same rails but you need an M7 bolt, and I havent found an acceptable solution. Any help?
      02-21-2024, 04:35 AM   #7
Delle123
Drives: bmw f30
Can someone please tell me if a roof bar kit from a bmw g20 fit bmw f30.? Thanks in advance
I see someone has said about from.f30.to a g20 and the bolts where different m6 to m7 but not sure if the g20 will.fit the f30
Asking before I purchase and travel to buy a secondhand set.
