2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Crystal shifter
      01-07-2024, 07:11 PM   #1
mczite
Drives: m440i convertible
Crystal shifter
Hi Everyone,
I have a bmw m440i 2023 convertible and just purchased a crystal shifter. I’ve heard a lot of people frying their console when putting it in so i really need to disconnect the battery first. I have found the battery at the back of the trunk under the carpet and will take off the negative one, however i saw there is another battery under the hood. Do i need to disconnect this one too and if so, how do i do so and is it negative too? Thanks so much
Pic attached
      01-08-2024, 01:37 AM   #2
HFW003
HFW003's Avatar
Drives: 2024 M340i xdrive
Just the main battery in the boot.
totalone275.50
      01-08-2024, 11:21 AM   #3
JimmyJazz
Drives: 2020 M340i, 2009 PontiaG8GT,
Let us know if the installation goes ok!
      01-08-2024, 12:03 PM   #4
rico25
rico25's Avatar
Drives: #G20
Just the battery is the boot and give the car sometime/ couple minutes and all power will be gone, then you can start your installation
      01-12-2024, 11:51 PM   #5
M440iXGuy
M440iXGuy's Avatar
Drives: 2021 BMW M440iX
2021 BMW M440IX  [0.00]
Please send some pictures of the installation when completed. Thanks.
      01-16-2024, 06:01 AM   #6
Assassin
Drives: M340d MHT xDrive
If you pop the hood, the 48v battery becomes disconnected. When you disconnect the battery in the trunk, put something over the latch to stop it being closed accidentally as you will have no power to open it again.
F31 335d Xdrive Shadow Edition M Performance, Individual Tanzanite Blue, HUD, Adaptive Susp, Evolve-R Map, Xhp Stage 3
E60 535d Msport Carbon Black/E39 530d MSport, Black Sapphire/E34 525i MSport, Avus Blue/E34 520i MSport, Briliant Red
      01-16-2024, 09:17 AM   #7
Datboireal
Datboireal's Avatar
Drives: 2021 G20 M340i
2021 BMW   [0.00]
I've installed the crystal shifter and crystal idrive multimedia cover.
I've got MHB M340i and I can confirm if you open the bonnet (hood) and disconnect the rear main battery it cuts all electrical power to the vehicle.
After disconnecting the battery I left the car door open and put the key inside my house, waited 5-10 minutes before testing electrics.
From there I removed the shifter module and attached the new crystal shifter and multimedia cover. Many videos on YouTube to follow it took me approx 45 minutes to an hour taking my time.
After reconnecting the shifter module I reconnected the battery then closed the bonnet. All data from idrive remained too.
Definitely a worthy upgrade!
Also added crystal start/stop button and volume button previously to complete the look 😁😎
MoeTE87656.00
wangyex39.00
JimmyJazz247.00
      01-29-2024, 03:29 AM   #8
Laddy
Drives: BMW M340i
Where did you guys buy the crystal set from?
      01-29-2024, 09:47 AM   #9
lebaaron
lebaaron's Avatar
336
Drives: 2013 BMW 335i xdrive
Lots of choices on aliexpress or from BMW if you feel motivated -
      01-29-2024, 11:26 AM   #10
panki_86
Slovenia
112
Drives: G20 M340i xDrive Individual
I have oem BMW glass
You can see the difference in idrive knob, OEM is thicker with thinner edge on the top.
But it is a lot of work with original parts. You need to change start/stop button support, so you need to take whole console apart. Also for iDrive knob you need to change whole knob.
I don't want to have fake stuffs in my car.
Now is four year old and everything on it is OEM BMW, even windshield wipers
zlatko117.50
      01-29-2024, 07:10 PM   #11
pkash2097
Drives: 2020 m340i xdrive
You can also remove the shifter console entirely and not have to worry about frying anything
