12-12-2023, 11:04 PM | #1 |
Rep 3,227
Audio volume issue
Hello folks,
After many months waiting I finally traded the M2C and picked up the M340. I’m having a couple of issues which are quite frustrating. The stereo volume changes randomly and I don’t now how to fix it. I assume it has something to do with the speed volume but I can’t find where/if I can turn it off. I’ve found where you can set it to low but not off. Any clues? The second thing is the stereo turns on if I open the door. Can this be disabled? The other thing is where do I change the start up animation? Thanks in advance! |
12-14-2023, 01:29 PM | #2 |
Rep 389
Sounds like you have an LCI. (Many reports on irritating audio design choices on those.) Maybe you can confirm your suspicion on speed compensation if it gets worse when you set the speed compensation on High?
I assume the volume change without showing the volume bar on the display? There are (in iDrive 7) settings for limiting the music volume when other sources "have something to say". Could it be that the computer thinks another source wants to activate? Maybe toggling through those choices can give clues. (I have my M440 iDrive 7 with HK set on High which works for me.) |
12-15-2023, 02:56 PM | #3 | |
Rep 3,227
I’ve coded out the volume bar. I checked the other sources thing before posting so I knew it wasn’t that. There is a setting called “surround sound experience” or something like that which was on the highest level. I have put that toward the middle and it seems to have fixed it? Do you happen to know how I stop the idrive booting up when I just open the door? Thanks again |
12-23-2023, 03:45 PM | #4 |
Rep 204
Why exactly would you want to do this? This factory programming assumes the driver is ready to drive. Do you not intend to drive the car each time when you get in?
12-24-2023, 01:43 AM | #5 |
Rep 389
I have iDrive 7, that resumes playing music when I start the car. To me, a much better design choice. Reports on the LCI says it resumes when just opening the trunk also (only G21 maybe). I'm convinced that is not what most users want.
12-24-2023, 03:15 AM | #6 |
Rep 3,227
Opening a door or the boot doesn’t necessarily mean I am going to drive the car.
Let’s say I inadvertently leave my mobile phone in the car and I go to get it. Why the devil does the car need to boot up just because I open the door? |
