04-03-2023, 03:05 PM | #1 |
Rep 12
G20/21 330d vs m340d engine differences
Hi all,
Long time viewer of the forum, first time posting as I cannot find the answer anywhere. Hoping someone can help me confirm. I own a May-21 registered G21 330d Bought it as a long term family do anything fun car, with the intention of getting it remapped and potentially turbo upgraded by Darkside developments. I had my first proper poke around under the bonnet at the weekend and noted it has 2 turbos? I specifically chose the 330d non xdrive for the simpler turbo/drivetrain setup for a “hopefully” lower cost of ownership over the long term. I plan to keep the car indefinitely and maintain it myself. Having searched around the internet, I cannot find the 282bhp B57D30O0 referenced. So my question is, did the later 330d’s with MHEV get the m340d engine in a detuned state? Appreciate anyone who can shed light on this. As noted, I’m pleased I managed to bag one of the last RWD 330d’s sold into the UK market. Thanks |
04-03-2023, 03:40 PM | #3 |
Rep 12
Im pretty certain I can see the 2 compressor housings?
I compared the setup to the Garrett Tech article on the twin turbo setup and it matched. Also cross referenced the top(sml) turbo part no. https://www.bmwblog.com/2020/05/27/b...diesel-engine/ This article cites the 210 kW / 286 PS (282 hp) and 250 kW / 340 PS (335 hp). Assuming this is the engine in my car, are there any mechanical differences or is if just mapping? Il post photos of my engine tomorrow |
04-04-2023, 05:43 AM | #4 |
Rep 823
I thought the 330d lump was single twin scroll turbo. Im not 100% sure on the M340d, I think it may be bi-turbo (one small/one large) possibly, but will still be a variant on the 57D30 lump
04-04-2023, 06:01 AM | #5 |
Rep 1,244
From the wiki B57 page showing 330d as single and M340d as twin turbo
04-04-2023, 06:14 AM | #6 |
Rep 118
I have an M340D and my engine is designated twinpower not twin turbo. The difference I believe is twinpower is a single turbo but with two intakes?
04-04-2023, 06:44 AM | #7 |
Rep 8,114
Yes it's a single, dual-scroll turbo. I thought they all were, tbh
Ian
04-04-2023, 07:07 AM | #8 |
Rep 12
Thanks for the feedback,
Il get some photos shortly and post those. It certainly looks like a compound”twin” turbo setup. I’m pretty certain the m340d is twin turbo |
04-04-2023, 07:10 AM | #9 |
Rep 8,114
Yes it is, I meant all the turbos (whether there is one or two) are all twin-scroll.
Ian
04-04-2023, 07:27 AM | #10 |
Rep 12
Top sml turbo is clearly visible, bottom larger turbo; difficult to get good photos of.
A comparison set of photos of a m340d engine bay would be ideal if any can support |
04-04-2023, 08:43 AM | #11 | |
Rep 15,858
320d and 330d, only one of the turbos is of the variable inlet design, the low pressure turbo. The M34d has both turbos of the variable inlet design. |
04-04-2023, 11:13 AM | #15 | |
Rep 15,858
Diesels are two stage, (high and low pressure), often refered to as sequential turbos. Sometimes we get confused by BMW's use of "Twin Power Turbo". |
04-04-2023, 11:22 AM | #16 |
Rep 15,858
This image illustrates the Twin-Scroll principle, (N55 in this case). The use of two separate exhaust inlet tracts, one to each of the "scrolls" on the exhaust turbine.
04-04-2023, 12:27 PM | #17 |
Rep 12
Hi Stuart,
Can you cross reference the turbo part numbers please. I googled the part no. On my small turbo and it returned a bmw per no. for a 340hp turbo setup. Suggesting the sml turbo is compatible, but I’ve got too assume the larger unit? Other than this, are there any other potential hardware changes BMW make to send the engine out with another 58bhp from factory? |
04-04-2023, 12:32 PM | #18 | |
Rep 12
04-04-2023, 12:46 PM | #19 |
Rep 15,858
From the technical data for the pre MHEV, was the single turbo with variable inlet geometry. RealOEM supports that as well, illustrating the single turbo.
04-04-2023, 01:44 PM | #21 | |
Rep 4,250
it's two turbos |
