03-01-2024, 02:05 PM | #1 |
Rep 342
Drives: G20 330ix M Sport
M Performance Red Tow Strap
Has anyone installed this M Performance red tow strap on their g20? I'm planning on doing some track events with the BMWCCA this season. I'm curious if this will fit both front and rear tow points? I can only find photos of the front on LCI not pre LCI.
03-08-2024, 03:19 AM | #2 |
Rep 562
There are two different versions... long and short.
long: https://ind-distribution.com/product...p-long-version short: https://ind-distribution.com/product...-short-version Check the suggested fitment and order accordingly I guess. Maybe your local shop would let you test fit? I can't imagine the threading is the issue - it's probably the length of the peg and fitting behind the cover. Shouldn't be an issue if you're only using at a track day. |
03-08-2024, 07:49 AM | #3 |
No 55mph
1622
Rep 8,476
From IND
*LIMITED INVENTORY* Genuine BMW M Performance Tow Strap in red with ///M Logo. Kit includes templates for trimming tow covers. Application Guide: G80 M3 Front and Rear G82 / G83 M4 Front and Rear G20 / G21 / G28 3-Series LCI ONLY Front and Rear G22 / G23 / G26 4-Series Front @ $271 pricetag you definitely want to make sure
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
03-08-2024, 08:14 AM | #4 |
Rep 1,114
Nice! Where are you planning to go with the CCA? Here in the Bay Area, the GGC CCA is going to Button Willow and Sonoma this season, possibly thunderhill sometime in fall.
03-08-2024, 02:54 PM | #5 | |||
Rep 342
https://www.ecstuning.com/b-genuine-...p/72155a709f6/ Quote:
helmet91297.50 |
03-15-2024, 03:46 PM | #6 |
Rep 185
I have some information on this. I bought two of the "long" ones for my Pre-LCI M340i (72155A57B31). I did this by mistake, because I didn't know there was a shorter versus for the pre-LCI (72155A709F6) and the "long" version I bought is for LCI. My results for the pre-LCI M340:
Front: "long" version fits and is basically flush with the bumper cover. While I doubt I would be able to fit my tow cover back over and cut a slit, this is perfect for my use with track days, since I'll just take the tow hook cover off. Rear: this is where it gets interesting, since I thought I'd have no issues here. I screwed the "long one" in, but I only got about 3 threads in until I hit resistance. The tow hook eye was running into the rear bumper metal. I was not comfortable with only 3 of 7 threads engaging in a towing situation, so I ended up grinding 2-3 mm around the tow hook eye, and I was able to fully screw in. I do not believe the pre-lci tow hook (short one) would be able to fit in the rear at all, since it's too short. So in summary, either will work for the front (with caveats) and the LCI one will work for the rear, but you'll need to modify it if you want all threads engaged. I bought from https://paddleshifterz.com/ for around $140 each, plus shipping from Germany. The $270 some places are charging are not worth it at all. Last edited by prostcfc; 03-15-2024 at 03:52 PM.. |
03-18-2024, 09:26 AM | #7 | |
Rep 342
03-18-2024, 10:58 AM | #8 |
Rep 185
