2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Driver assistant failure/instrument cluster blank
      10-09-2019, 06:58 AM   #1
tricky6
Drives: G20 330e M Sport+
On the way to the train station this morning I was on cruise control, running on electric, suddenly the instrument cluster when black/blank and the cruise shut off. I initially thought the car was doing a reboot as it started slowing down. It then popped up with an error on the central screen saying driver assistant fault, driver assistant no longer available.
Anyone seen this before?
      10-09-2019, 07:11 AM   #2
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Not so good.... thankfully not had any issues yet.
Did you have to do a reboot on Idrive to get the screen back?
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
      10-09-2019, 08:18 AM   #3
tricky6
Yeah, it was slightly scary at the time (given that it was dark). It came back on its own but the cluster display went black for 2-3 seconds. It's into the dealer next Tuesday for the brake fluid fault so hopefully an error will have been logged...
Having worked in IT for 25 years it's not surprising, now that software runs so much of our vehicles...
      10-09-2019, 10:50 AM   #4
KMoore
KMoore's Avatar
19
Drives: G20 320i M Sport
I've had the driver assistant error but it was absolutely hammering it down and assumed it was something to do with rain and spray affecting the sensor. When I restarted the car it disappeared.
Also had the information screen stop working and go blank. Again a restart seemed to resolve it.
Never had the instrument cluster go out though.
      10-09-2019, 02:40 PM   #5
Sussex_G20
Sussex_G20's Avatar
145
Drives: G20 330i M Sport
Plus One on both these and both went after restart. I had a warning about poor camera visibility when the assistant stopped working
      10-09-2019, 03:48 PM   #6
tricky6
So mine was dark (6am) but it wasn't raining or at least not at all hard. It just cut out!?
I've had DA cut out on the motorway in torrential rain when the steering wheel flashes yellow and it disengages because it can't see the lines clearly. It disengages later than I would if I was trying to see the lanes!
This was something else, as if it had had a software crash and did a re-boot...
