01-16-2024, 05:39 PM | #1 |
Rep 111
Drives: M2C|340|M340
Need help with fitment - 791M
I currently have the square set up with the 791M wheels - 19" 225/40 (8 inch wide)
I would like to: 1) Lower the car with H&R Sport Springs 2) 15mm wheel spacers all around 3) Run 265 in back and 245 in the front with wider rims How do I ensure that with all these modifications: 1) There is no rubbing 2) xDrive is not affected and won't throw a code (front and back within 1%) Also where can I find OEM BMW rims that are wider, like 8.5inches-10inches? |
01-16-2024, 09:49 PM | #2 |
Rep 3,226
Can’t help you with where to buy wider OEM wheels with the exception of the Supra wheels?
I would suggest though buying a set of correct ET wheels so you don’t have to use spacers. For instance, you can put 9 inch with 22ET on the front and 10 inch with 35ET on the rear. Tyres would then be 245/40’s and 275/35’s. Job done. Last edited by HFW003; 01-16-2024 at 09:56 PM.. |
drac116.50 |
