Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Wireless Charge Pad Overheating iPhone X
      04-23-2019, 01:43 PM   #1
vicfalc09
vicfalc09's Avatar
211
Drives: M340i xDrive
I have a brand new M340i and my wireless charge pad yesterday overheated my iPhone. I actually got the same overheating message you get when you leave the phone in the sun. Anyone else have this happen? I had no case on the phone.
      04-23-2019, 01:58 PM   #2
ThatKrazyPolak
Drives: 228xi (SOLD)
Did anything happen to the phone? This is exactly what I meant by generation 1 tech in its beta phase; all these things are not nearly as refined as they should be.
MT4life575.50
      04-23-2019, 02:01 PM   #3
wknddrivr
Drives: E36 M3/E39 M5
There are posts on the 5 series forum about the same issue. I’ve had my 5 for almost 2 years and no problems with my iPhone Xs
      04-23-2019, 02:04 PM   #4
stein_325i
Ring Leader of G8X Haters
stein_325i's Avatar
Drives: A Car
Seems to be an issue on not just the 3 series, I've seen similar posts on the 5, X5, and X7 forums, I would avoid using it, I remember one guy on the X5 forums said his phone overheated so bad he had to replace it
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300
      04-23-2019, 02:31 PM   #5
phillyd2
Drives: 2020 M340i XDrive
Do you use a wireless charger at home?
      04-23-2019, 02:34 PM   #6
vicfalc09
vicfalc09's Avatar
211
Yes, every night no issues.
      04-23-2019, 03:09 PM   #7
upsidedownfunnel
Drives: 2014 335i
2014 BMW 335i  [0.00]
Are you using Carplay while the phone is charging? Wireless charging can make phones a little warmer than wired charging and using something like CarPlay will also increase the phone's temperature. Typically when you charge at home, you're not using the phone so it can charge without issues.
Also, make sure you are centered on the charging pad. I believe iPhone charging coils are centered on the phone as are the coils in the charging tray in the car.
      04-23-2019, 03:10 PM   #8
vicfalc09
vicfalc09's Avatar
211
Yes CarPlay
      04-23-2019, 03:18 PM   #9
xraymd
xraymd's Avatar
Drives: 23 M2, 22 Lincoln Navigator
Mine gets a little warm but doesn’t overheat. This is on a 45 minute trip. And phone is in a case.
I have noticed sometimes the phone’s screen is on and then it’s hotter. Was your screen on ?
I also leave the cover open.
      04-23-2019, 03:54 PM   #10
Noeh
Drives: 2019 BMW X3 xDrive30i
You sure is the charging pad? I noticed using navigation through CarPlay for an extended period of time was the problem in my case.
      04-23-2019, 03:57 PM   #11
vicfalc09
vicfalc09's Avatar
211
Not sure but shouldn't overheat either way.
      04-23-2019, 06:32 PM   #12
MT4life
MT4life's Avatar
576
Drives: 2018 340i: Last MT 3er in US
Car Play was my first guess
Also what case are you using? Something super bulky protective like Defender?
      04-23-2019, 06:46 PM   #13
vicfalc09
vicfalc09's Avatar
211
No case
      04-23-2019, 10:50 PM   #14
BEK46
BEK46's Avatar
Drives: 2019 BMW 330 x-drive
I don't have wireless charging (6NW) but when I lay my iPhone on the pad, the NFC automatically brings up Apple Pay Wallet (and it never closes) and the phone does heat up, although not to the point of overheating. Not sure why this is happening on a consistent basis or what the impact is on my battery but it is disconcerting and not apparently related to charging.
      04-25-2019, 08:19 AM   #15
DomiGijzen
DomiGijzen's Avatar
Netherlands
70
Drives: BMW iX3 MSport High Exec (G08)
I tried it yesterday. Charging itself doesn't heat it up. But using carplay does. Also, carplay drains more power than the wireless pad can deliver
iPhone Xs
Grz D.!
      04-29-2019, 03:59 PM   #16
vicfalc09
vicfalc09's Avatar
211
Ok so the latest on this...when using CarPlay and Apple Maps navigaton the phone overheats wether it is in the wireless charging tray or not. This seem to be pointing the overheating to the CarPlay side of the house.
The other thing that is happening is that half way through my phone calls the call audio begins to lag. The person on the other end hears me a few seconds after i complete my sentence.
In addition to all that i have intermittent connectivity and streaming issues with Pandora Radio through CarPlay. Seems like the phone wants to use the cars wifi network then realizes it needs to use LTE instead.
Lots of quirks I must say...I think an update is needed but not sure if its from Apple or BMW or if we have a hardware/software incompatibility issue. Not to happy right now...
      04-29-2019, 04:03 PM   #17
stein_325i
stein_325i's Avatar
Drives: A Car
As cool as wireless carplay is, I feel like just letting us plug it in as an option would help solve a few of the issues.
vicfalc09211.00
      04-29-2019, 04:16 PM   #18
vicfalc09
vicfalc09's Avatar
211
Agree
      11-08-2019, 03:06 PM   #19
hockeymen14
Drives: 2020 m340i
Brough my m340i in today for some warranty work and asked about the overheating issue. Was given this SIB bulletin as their answer. Basically we need to center the phone and minimize use when wirelessly charging. Seems like a complete waste of equipment if you can't fully utilize the phone while it's wirelessly charging. Going to start using the USB-C charging port in the center console.
Has anyone noticed improved connectivity, fewer crashes and less overheating when using the USB-C charger instead of the wireless charger? I kinda want my $500 bucks back.
vicfalc09211.00
Nath4n34.00
      11-09-2019, 11:42 AM   #20
phillyd2
In a couple of months my X has overheated just once on a long trip using a couple of CarPlay apps at the same time - Waze, Spotify, Messaging, etc.
      11-09-2019, 12:25 PM   #21
Eagle Creek
Part of the bimmer family!
Eagle Creek's Avatar
Netherlands
139
Drives: BMWG20; BMW E90
2019 G20 330e  [0.00]
'Seems legit' though... I also find my Apple Watch to be quit warm when I take it of my wireless charging cradle.
      11-09-2019, 01:13 PM   #22
hockeymen14
Drives: 2020 m340i
This is my daily. Pandora...Waze....maybe a phone call with obvious delay...throw in a text message and forget about it. Crash city.....
