09-27-2019, 01:05 PM | #67 |
Rep 4,210
I only play with it occasionally but thanks to another poster, the trick to making it mostly behave is to turn off the lane intervention on the lane departure warning.
GrannyShiftG801290.50 |
09-27-2019, 01:37 PM | #68 |
X3M Comp is a beast
89
Rep 171
I was using it for the first 3000 miles but finally had to turn it off. Many Reason.
Trying to avoid a pot hole or manhole cover (wait can i say Manhole even these days?) Changing lanes with out turn signal. I will tell you it has trained me to use my turn signals more. Avoiding a puddle or a parked car. But most of all was this. Living in Western PA we have a lot of rolling hills on the road. Many times reaching the top of said hills the car got confused when the front end was higher than the back and will turn the car into oncoming traffic if I was not careful and was not paying attention. not sure what it sees but that is down right scary. I hope they fix this situation quickly. I wonder who i complain too about that one. |
Sedan_Clan25022.00 Eagle Creek139.00 |
09-28-2019, 03:02 PM | #69 |
Rep 12
I have a uk g20 and im not impressed with the function as standard. I love the car overall but the lane departure kicks in when it doesent need to - like when going around cyclists. Or when 2 lanes merge to one on faster roads and indication is not really required.
Not a massive problem though as the strength can be turned right down or the fearure can be turned off alltogether. |
09-29-2019, 06:01 PM | #70 | |
Law Enforcer
25022
Rep 22,269
Drives: '22 Chalk Gray Porsche C2S
09-29-2019, 06:10 PM | #71 | |||
Law Enforcer
25022
Rep 22,269
09-29-2019, 06:13 PM | #72 | ||||
Rep 114
Drives: 2020 M340i xDrive
09-29-2019, 06:30 PM | #73 | |||||
Law Enforcer
25022
Rep 22,269
There's a reason why us cops usually don't start citing people on the freeway until they are traveling at 10+ mph over the posted speed limit. Average travel speeds on a 65mph stretch of highway are between 72-75mph; someone driving 65mph in the #1-3 lanes is almost a safety hazard. Even #4 slow lane drivers are traveling around 68-70mph. |
09-30-2019, 05:25 AM | #74 |
Rep 310
I switched off both Lane-Keep Asistant and also disabled the steering wheel vibration in the first week of use.
Both of these options turned out to be totally useless for me, despite the fact I gave them a chance and played with different sensitivity settings. Not only that I find them annoying and distracting, but also dangerous as the car occasionally decides to intervene when I don't expected it to. I want to keep a healthy level of driving involvement even in relaxed driving because I want to keep the full control of the car at all moments and I find the current capabilities of driving assistants systems to be nowhere near the level that would allow drivers to drift away while driving. On the other hand, one of the things I thought I would never use is AUTO-HOLD. It's switched off most of the time, but when I find myself in the city stop-and-go traffic jams - i use it all the time and it works like a gem. As soon as the traffic opens up, I switch it off though. I tried exactly that as a last step before I finally turned it off. Last edited by Calamari; 09-30-2019 at 05:31 AM.. |
10-06-2019, 07:25 PM | #75 | ||||||
Rep 114
As a cop, you have a much higher chance of not getting a ticket if you were stopped for speeding. As a regular citizen, I don't want a cop to stop me and tell me I did something wrong. Also cops in Canada are stricter than in the US. |
11-09-2019, 10:56 PM | #76 |
Rep 89
Lane keep vs lane departure mitigation
I am surprised and disappointed (especially considering the cost) that my M340 does not have a lane keep assist feature that is independent of cruise control. My wife's X3 has this but I do not? Please correct me if I'm wrong. In the X3 you can drive semi-autonomously without cruise control on. In my car this only works with cruise on. I get that the M340 is designed for actively engaged drivers but when commuting it is helpful to have lane keep assist keeping you on the lanes if I'm tired.
I refer to the feature we have that sends you back into the lane if you actually cross the line at the side )or get too close) as Lane Departure Mitigation... but that may be Acura speak. My TLX lane keep assist (semi-autonomous driving... without cruise) was so smooth and seamless it was quite pleasant. Not so in our X3. The most dangerous thing in my opinion is in the X3... sometimes on major highways occasionally when the car detects an off-ramp it will suddenly pull the vehicle against the drivers will into the offramp. That is nuts! And it never happened in the Acura. Haven't been in the M340 long enough to have that happen in that car. |
11-23-2019, 07:48 AM | #77 | |
Rep 804
If you have Driving Assistant Professional, then I read in a different forum that either slightly breaking or (more likely) slightly accelerating would turn off ACC while keeping the active steering on, did you try that? |
M340Mike70.00 |
11-23-2019, 09:56 AM | #78 |
Rep 157
It's a royal PITA. I think the wheel vibration is a nice feature, but the intervention at the wheel is not. Encountered it first on an X5 loaner, then wife's 330i. Although it does a remarkable job of getting the car back in lane with a correction and counter-correction, it's obtrusive cubed and we immediately disabled the feature.
11-23-2019, 10:28 AM | #79 | |
Rep 89
But I'll try modulating the speed as you have suggested and see if that works. Thanks! Edit: Nope. Of course touching the brakes cancels cruise so no LKA. |
11-23-2019, 12:29 PM | #80 | |
Rep 179
11-23-2019, 01:33 PM | #81 | ||
Rep 2,499
09-04-2020, 03:29 AM | #82 |
Rep 93
I'm pretty sure this is what I have felt, when driving. I thought there was something wrong with my car.
I was driving down a road and because of parked cars on the side of the road, you have to drive over the central line road markers, fairly standard here in London. I was going over 40mph and the steering jolted me back, almost like my car was sliding. Also happened on an A road and felt like I nearly lost control. This must be it. I tried turning it on in idrive but it says the feature will be enabled next timne I start the car. How do I turn it off permanently? |
09-04-2020, 05:28 AM | #83 |
Rep 57
This just occurred happened to me on 31st Aug where I would have hated ANY sort of LKA intervention. Thankfully I had that turned off completely from day 1.
It might look like I sped up on the Scion, but due to the dash cam being fisheye lens, the TC appears much further than it actually is and I wasn't on the throttle very hard besides downshifting to speed up a bit on an open lane. I sped up quite a lot afterwards to just avoid them rather than slowing down. After the Scion TC almost hit me, you could kind of see that the truck also wanted to do something similar but I was too pumped on adrenaline by this point that I was sort of an ass and didn't give them a chance to go in front of me. Last edited by xacoffeemx; 09-04-2020 at 05:52 AM.. |
09-05-2020, 05:31 AM | #84 | |
Rep 63
For you guys who think that you don't need to indicate when "there is noone around you" - one day there will be a bike riding 300 km/h (200 mph) that you will not see and it will crash into you from nowhere. And chances are that you and your passengers will die. This happened before. According to the rules you must indicate when changing lanes, moreover you need to check that manoeuvre is safe! Check mirrors, indicate - then change lane. In this case steering intervention will work for you, not against you. |
VetteGuy845.50 bavarianride1505.00 |
09-05-2020, 05:47 AM | #85 |
Rep 1,526
I disabled this through I-Drive in my X5. I am sure you can do the same in any G20 with the same feature. I have mine set to vibrate the steering wheel. If you’re just speaking about lane keeping assistant only, that can be toggled on and off as mentioned.
2021 M40i Phytonic Blue / Black Vernasca
2020 X5 xDrive 40i Tanzanite Blue / Coffee Vernasca 2011 328xi. Space Grey - Sold 188,925 great miles |
09-05-2020, 06:20 AM | #86 | ||
Rep 57
The latter part of the video, I admit I was going a bit fast. Although this might not directly relate to where I was positioned in the video, I have one note for you.. going 70-80mph in 65mph zone in Southern California is literally the flow of the traffic. This is probably an unpopular opinion, but in my opinion, it's safer to go 70-80mph with the flow of the traffic than going 65mph. But like I said, this doesn't apply to my video |
09-05-2020, 06:48 AM | #87 | |
Rep 265
SportySpice204.00 BmwDriverStockholm45.50 |
09-05-2020, 01:45 PM | #88 | ||
Rep 57
Second, it may seem like I accelerated a lot, but that's an illusion coming from the left lane decelerating. Notice the TC swerving into the lane the moment the car in front of him started to brake? Third, that's not how the laws work here in USA. It's 90% the fault of the person not yielding to the other lane, and I didn't violate anything in this context. You could try to prove me wrong here. |
