Technical Topics DIYs and Coding Discussions M340 Mud Flaps
      09-19-2019, 10:10 AM   #1
RSnic
RSnic's Avatar
Drives: 2020 M340Xi (G20)
2020 BMW M340  [0.00]
M340 Mud Flaps
Hi,
I ordered front & rear Mud Flaps (or whatever they are called) for my 2020 M340XI, but my local dealer can't find parts number.
Would appreciate it if anyone can provide me with the part numbers for these
Thank you very much!
Al
Retired: 2014 328i
BMW CCA
      09-22-2019, 05:38 AM   #2
Don Mico
My First Bimmer
Don Mico's Avatar
Need Mud guards too
Hi,
Hi RSinc- I have asked Crevier BMW and Was informed that currently there is no part specific for the M340.
I was able to find a seller from EBay that BMW OEM PN 82162218983 and 82162218984 will fit our M340. BMW Crevier part advisor mentioned that base on the description of the two OEM part number listed above, they can’t guarantee if it will fit.
I’m giving it another week, I may end up buying the one on EBay and try it.
      09-22-2019, 11:20 AM   #3
Asterix
Asterix's Avatar
21
Drives: BMW 330i G20 Msport
100% sure mud flaps from F30 won't fit G20 with sport package. I kept those from my former F30 - non sport package- and tried on the G20 - requires a lot mods to fit and anyway not perfect at the end .
      09-22-2019, 06:06 PM   #4
RSnic
RSnic's Avatar
Hi,
Hi,
[@Don Mico,
Thank you very much.
I looked at a M340 & 330 side by side & it sure looks like they identical front & rear wheel wells. Having said that, however, I still can't find part numbers for mud flaps
Appreciate any further help
Al
Retired: 2014 328i
BMW CCA
      10-01-2019, 01:11 PM   #5
Don Mico
My First Bimmer
Don Mico's Avatar
[@Don Mico,
Finally pulled the trigger on buying the mud flaps from EBay. Target delivery by Dec 02. Will let you know how it works.
The seller is from HK and he confirmed that the photos of the front and back should work.
      10-02-2019, 11:12 AM   #6
RSnic
RSnic's Avatar
[@Don Mico,
Finally pulled the trigger on buying the mud flaps from EBay. Target delivery byvDec 02. Will let you know how it works.
[@Don Mico,
Thanks
Al
Retired: 2014 328i
BMW CCA
      10-23-2019, 10:15 PM   #7
Don Mico
My First Bimmer
Don Mico's Avatar
Its official... I have installed the mud flaps and it's very easy.
      10-23-2019, 10:22 PM   #8
Don Mico
My First Bimmer
Don Mico's Avatar
The OEM part number matches with the previous 3 series. If you want to buy from ebay Seller: lamautopartstore. Look for Genuine OEM Splash Guards Mud Flaps for 2019-2020 BMW 3 series M sport sedan G20
      10-23-2019, 10:43 PM   #9
Don Mico
My First Bimmer
Don Mico's Avatar
I forgot to mention that I bought four of the plastic rivet for the front mud flaps. It’s like $1.10 each. About $6 including tax. Good luck.
      10-24-2019, 08:25 AM   #10
laparka
Drives: M340i
Can you post pictures of the whole car with them installed?
Thanks!
      10-24-2019, 11:11 AM   #11
TTG
TTG's Avatar
Drives: M340
Thanks for the update. These little guys do a very good job of keeping dirt off the car. I might consider them for sure.
      10-25-2019, 10:45 AM   #12
Don Mico
My First Bimmer
Don Mico's Avatar
Thanks!
See photos below...pardon the dusty wheel.
RSnic657.50
      10-26-2019, 08:38 AM   #13
laparka
Drives: M340i
Nice!!!!
Thanks!
      10-26-2019, 02:41 PM   #14
phillyd2
Drives: 2020 M340i XDrive
Do you have the details for these?
      10-28-2019, 09:04 PM   #15
Don Mico
My First Bimmer
Don Mico's Avatar
Part number 4A21551-16-1-881-149 about $1.35 each. Qty 4 used
phillyd2219.00
      10-29-2019, 05:10 AM   #16
phillyd2
Thanks!
Looks like the BMW Part Number is 51161881149.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
      10-30-2019, 02:33 PM   #17
Don Mico
My First Bimmer
Don Mico's Avatar
Thanks!
Phillyd2, that's the right part... I was in a hurry at that time so had to bite the bullet and pay premium... needed 4... some extras would have been nice.
2020 G20 M340i
First Bimmer in the family
phillyd2219.00
      11-01-2019, 08:00 AM   #18
RSnic
RSnic's Avatar
@Don Mico,
Really appreciate your post. Is the eBay listing the one with the blue series & not the black 3 series?
Thanks
Al
Retired: 2014 328i
BMW CCA
      11-01-2019, 08:29 AM   #19
phillyd2
I ordered the one with the blue car but haven't received it yet - didn't realize that there may be two versions.
BTW, are those plastic rivets only for the front? Do the rears use the existing screws?
      11-01-2019, 04:37 PM   #20
Don Mico
My First Bimmer
Don Mico's Avatar
The version for the M340 should be the one with the M sport package. The photos on the ebay item is clear...but I ended up sending my photo and measurements just to be sure.
4 rivets used for the front. The back splash guards I used the screw that was provided.
Very easy install... could be easier of I removed the two rear tires.
phillyd2219.00
      11-10-2019, 03:45 PM   #21
phillyd2
How do the existing ones come off?
Edit: Figured it out. Push the center part in with something sharp and it pops off.
Mine came with hardware which I didn't use as I just reused the original 10 mm screws. Install took about 3 minutes. Rears were a slight PIA but no real biggie if you have a small ratchet.
My car is black so they look great. Thanks for finding these.
      11-10-2019, 08:49 PM   #22
Don Mico
My First Bimmer
Don Mico's Avatar
You are welcome.
