Technical Topics Suspension / Chassis / Brakes 330i Brake Pads Parts number
      07-30-2022, 02:50 PM   #1
BTC Maxi
BTC Maxi's Avatar
Drives: Bmw M3
Hello, I have a 2019 330i xdrive and both the front and rear brake pads need to be replaced. I'm just curious as what the part numbers are for both front and rear to know which ones to order. Thanks for the help!
      08-04-2022, 04:26 PM   #2
Thundernight
Thundernight's Avatar
Drives: 2022 M240xi
Do you have the high performance cooling and tire package? If so, you should have the same brake pads as the G42 M240. I looked up the part numbers and this is what you would need:
Front Brake Pad (Set): 34-11-6-889-585
Rear Brake Pad (Set): 34-20-6-888-345
Front Brake Rotor: 34-10-6-895-647 (left), 34-10-6-895-648 (right)
Rear Brake Rotor: 34-20-6-880-079 (need two)
Front Sensor: 34-35-6-870-353 (need two)
Rear Sensor: 34-35-6-870-354 (need two)
I am actually looking for an aftermarket, high performance option that will outperform the OEM pads, but there doesn't seem to be any support yet (unless you have any leads).
      08-04-2022, 05:51 PM   #3
bquatt
Drives: 2020 330xi m-sport
Brembo makes pads
      08-05-2022, 11:18 AM   #4
Thundernight
Drives: 2022 M240xi
Originally Posted by bquatt View Post
Brembo makes pads
Thanks. I do see that, although these are OE equivalent only. Still looking for a compatible brake pad that will be on par with PFC or Hawk DTC compounds.
