01-09-2023, 12:52 AM | #111 | |
2023 M340i LCI xDrive (on order)
31
Rep 125
BTW: How are you finding the ACE 2.0? |
01-09-2023, 07:21 PM | #112 | |
Rep 681
Video quality is reasonable both front and back (not quite as good as other dashcam manufacturers). However, I have a heavy tint on the back window which reduces the amount of light reaching the rear camera. The cameras work in parking mode for some time after the car is parked, although I have never timed the actual period that they stay functioning. One thing I like is that the cameras activate in parking mode when movement (people or vehicle) is detected in front of the camera, rather than recording continuously in park mode. This saves a lot of battery life and SD card capacity. The camera is sold with only a 32 GB micro-SD card. I bought a 128 GB card to replace it. What I don’t like about the cameras is that they are so large compared to the Blackvue cameras I had before. I understand the rear camera on the ACE 3.0 is now much smaller than the ACE 2.0 rear camera. When you get your cameras installed, make sure the front camera, in particular, is installed in such a way that the front A-pillars are not in shot. I had to get my dealer to reposition the front camera due to this reason. BTW, to achieve this, I had my front camera installed to the left of the mirror immediately below and to the left of the black dimpling on the windscreen - hope that makes sense to you. In this position you cannot see the the A-pillars and cannot see the camera from the drivers seat and, thus, does not obstruct your view. The BMW Viewer (to view video from the SD card on your computer) is available on line. I found it a bit painful to download and install, but I think I just had a bad run (you might find it easier). This viewer is OK but definitely not as good as the Blackvue Viewer. One redeeming thing for me is that I have not experienced battery issues since having the ACE 2.0 installed. I leave my car parked for days and weeks at a time which, in the past, caused problems for me with a Neo battery installed for my Blackvue dashcams. Note: Had I been driving the car every day, the issues would not have occurred. Hope this helps.
01-09-2023, 07:43 PM | #113 | |
31
Rep 125
Once I get my VIN number, hopefully in the next week or so, I will ask the dealer if the ACE 3.0 has been released locally and what it costs. |
04-15-2023, 10:09 AM | #114 | |
Rep 3
I wish I saw this post earlier.
I have my Viofo hardwired with Cellink Neo battery. But even I turn Viofo off when parked in garage, it still drain Neo completely after a few days. I monitor the circult for a while, found BMW wakes up by itself after a while, that triggered camera to power up and then switch to parking mode. Is there a way to fix this behaviour? I really like my Viofo setup and don't want to spend another grand and half for BMW advanced eyes. Quote:
04-15-2023, 11:32 AM | #115 | |
Rep 552
Here is a thread describing my installation. I hope this might help. P.S. There are a number of statements in the post you quoted from SteveAus that I have found to be incorrect. He states that there's no need for a wiring accessory because "the battery bypasses the need to use this product as it is independent of the car’s battery." This is not true. The Cellink battery relies on the car's battery to charge, and the Power Output Cable w/ Spliced Viofo USB-C (T130/A229) Hardwire Kit enables the camera to enter parking mode when the car's battery stops sending power to the Cellink Neo.
2022 M340xi Tanzanite Blue II Metallic
04-15-2023, 09:24 PM | #116 | |
Rep 3
Thanks for the reply.
I'm using fuse F273 for cellink neo input. And Viofo hardwire kit HK3-C because I'm using A139 Pro. I do notice Viofo and Cellink using different color coding for ACC and battery, resulting when I connect hardwire kit to Neo output, red connects yellow and yellow connects to red. Yes, I agree with you. Steve is not correct regarding hardwire kit. Without hardwire kit, there is no way to pass ACC signal to camera. I think he mean Neo doesn't need hardwire kit, as it only need ACC, no need for constant battery power. Everything looks fine, and camera goes to parking mode after about 7 minutes after car locked. But there is random event my BMW wake up by itself. I can see in Neo app, power is restored for Neo and it's charging. Of course, camear will think ignition is on and turn itself on and recording. I tend to believe this is not problem of camera installation, but the BMW behaviour described by steve: "The car periodically does electrical system checks. During this time the circuit is triggered to start charging the Neo battery, it then closes the circuit after a short period of time." Since you don't have this problem, now I'm thinking is this due to BMW setting or coding? I only did some basic tweak using bimmercode. Quote:
04-15-2023, 10:19 PM | #117 |
Rep 552
cool7 I hope you can get it solved. I can assure you that I don’t have this issue. I suggest you post this issue over at dashctalk.com
https://dashcamtalk.com/forum/
04-18-2023, 07:04 AM | #118 |
31
Rep 125
I have decided to stay away from ACE 3.0 dashcam as it didn't have ability to remote access and/or cloud storage.
Plus Blackvue have their new DR970x coming out next month, around mid May. I will look at also getting the locking mechanism to prevent unplugging power cable by dealership when booked in for a service. BTW: has anyone who has installed the locking mechanism got any comments from dealerships regarding needing to unplug power cable when in workshop? I will also be getting a Track My Ride GPS and Autowatch Ghost 2 immobiliser installed. You can never have enough layers of security.😁 I better get a discount from insurance once allnof thia stuff is installed, otherwise i am not sharing details with insurance if i get involved in an accident🤫 Last edited by nm2003; 04-18-2023 at 07:13 AM.. |
12-30-2023, 05:04 PM | #119 |
Rep 617
Hey, I used this guide to hardwire my BBMC Powercell 8 to my G87 M2 and it worked perfectly. Thanks!
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
