Technical Topics Suspension / Chassis / Brakes 330i vs M340i height
      05-29-2019, 11:03 AM   #1
tsn
Drives: BMW
Hi
Is the height of the 330i and M340i, in terms of wheelgap, the same - or is the M340i lower? Is the height the same if you have the adaptive suspension and the standard suspesion?
      07-20-2019, 05:14 PM   #2
tsn
Drives: BMW
Nobody knows?
      08-03-2019, 06:35 PM   #3
g20beam
g20beam's Avatar
Drives: G20 330i M Sport
2019 BMW  [0.00]
If I'm not wrong, both of them are the same height. This generation is already lower than the F30, but I think regardless of adaptive or standard suspension, they will be the same height.
      08-03-2019, 06:37 PM   #4
g20beam
g20beam's Avatar
2019 BMW  [0.00]
My question is - Why does this matter? Usually the car would not be too low from the ground coming out of factory anyway, if you want to lower it, then you should probably think about aftermarket, but I believe both 330i and M340i heights from factory are the same.
