2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Is this normal post - Should I be able to 'hear' the steering?
      05-08-2021, 03:28 AM   #1
planetb00m
Drives: 330D F30
Picked up a 69 plate 320i. Its done 20k miles. Bought it 1 week ago and been driving it listening out for any weird squeaks, creeks and whines.
I've noticed that on slower speeds, especially with big turns I can 'hear the steering'. It's a whining noise more than anything else. Also, may be completely unrelated, but coming out of my drive steering tends to feel quite heavy (i'm still in comfort mode at this point, and thats set to default settings in the idrive and not set to sports steering.)
Coming from a 330d f30 this is different to what I'm used to. I've brought it up with the dealer but they've yet to respond to me.
      05-08-2021, 04:44 AM   #2
willougs
willougs's Avatar
267
Drives: BMW 330e
On mine there's definitely a small noise from the steering. sounds like a low whine. I put it down to the fact that the steering has some kind of mechanics/gearing attached to it for the self parking/lane guidance stuff.
For cheaper charging, switch to Octopus Energy using this link and get £50 free credit
      04-16-2022, 07:41 PM   #3
bavarianride
Drives: bimmer
my US-spec 2021 G20 330i also has the whine at local speed turns, dealer foreman and tech said it is normal.
      04-17-2022, 05:13 AM   #4
Carbon dude
Drives: G20 320D 2019, current M340i
I've had mine since new and it's the same for me. It sounds more like mechanical or fluid sounds.
      04-17-2022, 05:30 AM   #5
Alpine110
Drives: G21 M340i Touring
I had mine checked and there was a heat shield that was creating the noise, part of the steering column assembly had become scored and required replacement. It’s now much quieter but not silent but I think that’s the assistance systems that I hear.
G21 M340i Touring | Tanzanite Blue & Cognac
Alpine A110 | Premiere Edition
Gone | 997 Targa 4S | E85 Z4MR | E85 Z4 3.0i
      04-17-2022, 07:20 AM   #6
HighlandPete
Drives: BMW F11 535i Touring
When you guys say the 'assistance systems', do you mean you are hearing the servo motor in the steering rack, while turning?
G20 models (other than the M340i) have a different EPS rack design than the F3x models, so may be more audible.
      04-17-2022, 05:30 PM   #7
thescouselander
Drives: G20 330i
Yes, I can definitely hear the motor that's built into the steering working, it does seem like it's loud. I had a loaner 3er recently and it was exactly the same. I guess they must all do that.
      04-28-2022, 05:29 PM   #8
Nexstar2011
Drives: G21 M340i Dravit/Mocca
I too had noisy power steering - and the heat shield was also the cause. Not bad enough to damage the steering column, but after the tech adjusted the heat shield it's as close to silent as it gets. He even video'd the cause/resolution (crap pic below)
      04-29-2022, 06:00 AM   #9
a.summers86
a.summers86's Avatar
192
Drives: BMW G20 MSport Pro
Yes normal - is it not a metallic/clunk noise as such...more off a noise similar to turning a motor/ gear manually? I put it down to the mechanism used for the auto park/ lane assist.
I've had a few loan cars both G20 and x3 and all had this noise at low speed. Can only be heard if the radio is off and you are driving under 5-10mph.
