01-18-2020, 07:12 AM | #353 |
Rep 20
Morning guys.
I did try the battery mode pete just to see what it did and how it affected the MPG. It took 2 miles off and was on for half an hour or so i think just the once. I cover the UK as a Technical Rep so have to claim my mileage back so generally i drive economically to make sure i am in the black when i claim the miles, plus it keeps me entertained whilst driving. Had a 320d prior to this and regularly get 65mpg on the same trips sticking at 65mph on the motor. I need some more data i think. Tuesday i will reset and drive on battery as far as i can and then go to eco pro individual mode and drive like Miss Daisy and see what i get. As i mentioned BMW are going to have it in next Friday so i can give them 2 weeks of data and find out why its only charging to 20 miles hopefully. Ill chuck the numbers here just for shits and giggles. Apologies if this boring anyone. Its very useful for me so thanks again and feel free to bail out anytime. Cheers and have a good weekend. |
01-18-2020, 09:50 AM | #354 | |
Rep 17
01-19-2020, 12:49 AM | #357 |
Rep 4
Hi guys! I plan to order my 330e next week and I have a question concerning the trips for which electric range is not enough:
Many times I read that entering the destination in the navigation is important... but except for road relief, is there any other benefit? Every weekend I have a trip of 60km and I would like to use the maximum of the battery capacity in an optimized way. The trip is divided in 10km city, 30 highway, 20km country roads. I would like that the car manage itself the utilization of fuel/electricity and at the same time arrive with the minimum remaining electricity range in it. Is this option available or I have to perform this micromanagement by switching the various modes while I am driving? Many thanks in advance! |
01-19-2020, 07:30 AM | #358 | |
Rep 43
The only exception is that Hybrid eco mode only works up to 110 km/h (at 110 km/h it always start combustion engine), so if you have to start the trip going faster than that there may be a situation you may want to start "Electric" mode to go up to 140 km/h on electric only mode. |
01-19-2020, 07:30 AM | #359 | |
Rep 92
01-19-2020, 07:47 AM | #361 | |
Rep 98
That is exactly my problem with Hybrid/Hybrid Eco Pro. I do most of the journeys on highway at 120-130km so it simply keeps the ICE always on with little (if any) electric.
I have always switched to electric and I do the opposite: drive on electric until deplete completely the battery. Just if i would be driving at the end in a city I would change to hybrid or battery control to keep some electricity for city driving. Quote:
01-19-2020, 09:26 AM | #362 | |
Rep 43
01-19-2020, 11:20 AM | #363 | |
Rep 395
City driving drains the battery quite fast. Depending on the roads/traffic/outside temp/if you have the heating on/etc you might only get one trip but not return out of a full charge since the BMW figures are 60km and that's basically impossible to do unless you put the engine on a lab bench or you live somewhere where the temps are always between 15-25 degrees which is sweet spot for batteries. |
01-19-2020, 11:44 AM | #364 |
Rep 4
Thank you for the replies!
I am aware that 60km is hardly possible to achieve in electric mode only. I was just wondering if there any way to say to the car: ok car, so we will travel 60km, please deplete totally your battery till the end of the trip and in the meantime use this energy the best way possible. As you said, some type of roads are energy consuming... initially I was thinking to drive first in electric mode until total depletion and then switch to hybrid mode until the end of the trip, but it seems not optimal. From what it was said I understood that the hybrid mode is deciding depending of the type of the road, what would be the most efficient utilization of fuel/electricity. So I probably should force the utilization of electricity in case that there is still electric remaining range before the end of the trip. |
01-19-2020, 12:15 PM | #365 |
Rep 395
Adaptive mode might be better suited, along with setting your destination via GPS which basically uses either ICE or battery in an optimal way but again this doesn't know you want a return trip from a full charge so it will optimize it one trip at a time.
It's more of a learning thing, once it got colder I can't do my work commute on the battery alone but I have learned that a 3km stretch of battery charge mode is needed and that stretches the range just enough. One tip that not many people seem to know is that if you are in battery charge mode, tip the gear stick to the left (or right depending on LHD/RHD) and that charges the battery quicker. |
01-19-2020, 01:26 PM | #366 | |
Rep 27
All in all the car is more frugal than even a small 3 cyl Diesel but you absolutely have to charge every chance you get... |
HighlandPete6658.50 |
01-19-2020, 02:53 PM | #367 | |
Rep 27
Charging the battery like this causes massive fuel consumption and there are significant losses in converting fuel to electric power (heat losses in the engine and generator. If you need to reach a place outside of EV range, drive hybrid or even sport (not XBOOST) and be gentle on the pedal. The engine will likely stay well under 7l/100km. When you get to within the EV range, go full electric. Then charge at the destination and do the same thing in reverse Doing so will make the care crazy efficient, even doing 110 to 120 kph on highways. |
01-19-2020, 04:06 PM | #368 |
Rep 92
380km trip. Full car (5 people + luggage) 6.3l/100km 135kph on the Cruise Control.
Battery started 75% ended at 25% (before some ev city driving at the end destination) As someone said, the battery/eletric motor helps even when the ICE is on, the "eboost" indicator does go up, usually under 20%, but I've seen it go as up as 80% of I accelerate on climbs. |
01-20-2020, 03:27 AM | #369 | |
Rep 4
Thank you very much Kris! |
KrisJ15.00 |
01-20-2020, 03:47 PM | #371 |
Rep 20
Crikey. Thats a lot of messages ive missed. Thought i would get notificiations. I will post my trip value later in the week but to all the new people on my thread, can you tell me what you battery charges to please. I have had my car a week and it only charges to 20-21miles at 100% ie plugged in at home thats the maximum range. That was the whole point of this thread and the car is going into BMW on Friday to be looked at. Id like to know how all yours are performing if possible please. cheers in advance.
01-20-2020, 04:12 PM | #372 | |
Rep 43
The prediction is just a guess and usually a conservative one. Today I was in a store 21 km from home and I happened to have exact same 21 km electric range left according to my car. When I got home I still had 6 km/20 % left. |
01-20-2020, 09:57 PM | #374 |
Rep 92
I have a similar experience, I had my car report from 30 to 50km range from full. From my experience it depends on previous trips efficiency, outside temperature, AC setting, etc
