01-06-2020, 02:25 PM | #1 |
Rep 534
New record
Did a bit of experimenting with Electric mode today and surprisingly got from home to Reading services which is around 36 miles and I still had 4 miles range left. At times I must have done 3 miles without it dropping the remaining range. Just doing my usual inside lane bumbling along at 60MPH.
Anyway, put it on charge at my hotel tonight and got this... probably a total lie but highest I've ever seen by 3-4 miles. Maybe it's predicting that Summer is coming... :-) |
01-06-2020, 03:34 PM | #2 |
Rep 110
I’ve been driving in elec only today as I knew I could re charge before running out of battery. Noticeably holding its charge much better than of late on regular journeys I make. Didn’t go up to much more than 21 miles though when plugged it back in...
01-07-2020, 01:20 AM | #3 |
Rep 283
Haven’t tried electric only mode yet as my commute is too long for that but car consistently showing 30 mile range on the app after charge (3 days in a row) - but as soon as I start preconditioning it immediately drops to 23/22.
Currently using a granny plug - maybe the precondition draws more power than it can charge. Will try without. |
01-07-2020, 03:49 AM | #4 | |
Rep 62
01-07-2020, 03:54 AM | #5 | |
Rep 283
It’s a professionally installed outside plug point though with weatherproofing etc - and on current 6a setting, plug isn’t getting hot or anything. Barely even warm really. |
01-07-2020, 04:36 AM | #6 |
Rep 110
So I’ve upped mine to 10amp for home charging. House is a shambles from top to bottom in terms of electrics and plumbing (short term convenience rental)... worse case was it’d blow the electrics in a house we’re not fussed for, I’d play dumb and the landlord would sort it... nothing has happened.
It charges fine without any issues. I charge it most weekends two or three times and occasionally during the week if I’ve driven far enough between charges at work (official free to use Pod-Points at work). I fully expected issues or it at least to trip the fuse box or something - nothing has happened at all. Appreciate this sounds a little risky but am confident where any wiring concerned is remote enough in a cold, stone cellar (lead to car is run through an air brick I removed and re-cemented around the cable to outside) and there is only so much that can happen! Charges a lot faster on 10amp than 6, was hardly worth bothering on 6! One young electrician with all the recent training and qualifications doing some lighting work for me suggested that and another older more experienced one has seen it since and didn’t even raise an eyebrow... his dismissal of it being an issue was enough for me! Don’t get me wrong, if I owned this house I’d have had a PodPoint put in as soon as I got the car, but we don’t intend staying long and it wasn’t worth the investment... |
01-07-2020, 05:07 AM | #7 | |
Rep 283
Might up it incrementally to 8 first if that’s possible to check how it fares on that load. |
01-07-2020, 06:53 AM | #8 | |
Rep 62
I'd agree you're probably fine but equally I'd not chance it. |
01-07-2020, 10:46 AM | #9 | |
Rep 283
And after 90 mins plugged in, it's still nice and cool. |
01-07-2020, 12:28 PM | #11 |
Rep 283
01-07-2020, 12:49 PM | #12 | |
Rep 534
01-07-2020, 01:37 PM | #13 |
Rep 15,858
01-07-2020, 01:46 PM | #14 |
Rep 283
01-07-2020, 01:55 PM | #15 |
Rep 14
The question is, is pre conditioning more efficient than starting your journey cold? I'm guessing that because the engine (ICE) isn't running the auxiliary heater needs to kick in?
01-07-2020, 01:57 PM | #16 |
Rep 283
I guess it’s more efficient to warm the cabin up under plugged in conditions than it is on the road when you first get moving.
01-07-2020, 02:01 PM | #17 | |
Rep 15,858
Should be far more efficient to preheat the cabin while still plugged in, preferably on the maximum charging rate. |
01-07-2020, 04:24 PM | #18 | |
Rep 275
“ You can configure up to two departure times. By selecting "Precondition for departure time", you can precondition your vehicle ahead of the departure times. Once the departure times have been activated, they remain active for all week days, unless you do not move your vehicle for three consecutive departure times. If your vehicle is connected to the charging cable in the period leading up a configured time, the high-voltage battery will also be preconditioned. Full performance and full range will then be available to you.” So the battery is also pre conditioned for optimum efficiency |
01-09-2020, 04:10 PM | #19 |
Rep 534
Yeah you can enable preconditioning even if it's not connected to a charge source, providing the battery has enough charge. However, just watch how much charge you've lost when you get in... I've seen 20-25%!?
01-09-2020, 05:21 PM | #20 | |
Rep 15,858
I've just driven home this evening in my touring at -3°C, the heater was having to put out a lot of heat to keep the cabin at 20°C. Was thinking as I was driving, what if this was a PHEV, how much would it cost in mileage using the battery? |
01-10-2020, 07:08 AM | #21 |
Rep 14
Definitely agree that the auxiliary heater eats battery. I've just managed 36 miles in electric mode with the heating turned off. I've never managed anything above 30 with the heating turned on
01-10-2020, 11:20 AM | #22 |
Rep 534
Yeah, you can see the difference, when I switch off heating then it can add 2-3 miles of range instantly...
