01-13-2020, 10:58 AM | #1 |
Rep 829
330e charging
My cheap rate electricity is between 12midnight and 8am. I leave the house at 9.45am. How do I ensure the charging is done using the cheap rate and also warm up the car for departure?
01-13-2020, 11:14 AM | #2 |
Rep 275
I seem to remember that you’re not using a Pod-Point or similar house charger only the supplied cable? The BMW Portal ( as far as I’m aware) won’t let you schedule your charging like the wall mount options so unless you can run the plug through a timer plug of sorts I don’t know.
As for the pre heating that will be charged at your normal rate from about 9:15? |
01-13-2020, 11:17 AM | #3 |
Rep 275
You will need to either program your daily departure time on the app or click on “Climitise now” whilst chowing down on your Rice Crispy’s.
I’m not sure if the supplied cable is capable of pre conditioning tbh |
01-13-2020, 12:17 PM | #5 |
Rep 43
Every cable/charging point is capable of preconditioning, but if you are using wall plug with 8A (1.8 kW) charging the preconditioning may use car battery in addiotion of what is coming from the plug, depending on weather/charging power needed.
You can set preferred tariff window from either car or from the app; I have set my tariff window to be between 02 am and 08 am. Whenever the car stops one can choose whether to charge immediately or during charging window. |
01-13-2020, 02:03 PM | #6 |
Rep 98
What happens if you set a time window too short to get a full charge? Does it stop the charge? Some days I’m going to a shopping center with charging points and I just want to charge like 50% so I can leave it plugged while do my shopping (and avoid some expense at home)
01-16-2020, 02:30 AM | #8 |
Rep 43
The charging tariff window and climatization are separate. Just set the charging to be done during charging window (instead of "charge immediately") when you leave the car and charging will be done during charging window even if you do not have any climatization set.
01-16-2020, 03:54 AM | #9 |
Rep 7
I use the connected app, you can set up two charging/climatisation profiles.
I have charging & climatise turned on mon-fri and just charging sat/sun. I do have a wall charger, so no reduction in usable battery level after climate function. I'm probably overthinking this as the weekend climate power usage would be pretty minimal anyway. |
01-16-2020, 04:25 AM | #10 |
Rep 829
How do you set the temperature that the climatisation will climatise to? Also when I got in my heated seat and steering wheel were on - very nice! How can I set it so that the passenger seat also pre-heats in order to keep my wife happy?
01-16-2020, 04:34 AM | #11 |
Rep 275
It Climitises to the temp you have set on the two zone display on the dashboard.
01-16-2020, 05:33 AM | #12 |
Rep 829
01-16-2020, 06:24 AM | #13 |
Rep 7
There's a setting in Car/Settings/Climate that allows you to select seat heating to come on if outside temps below a set level. I haven't checked if this turns on the passenger heating yet!
I always turn on the heated seats for her when i get in anyway, happy wife, happy life! |
01-16-2020, 11:07 AM | #15 | |
Rep 829
01-16-2020, 12:23 PM | #16 |
Rep 7
Go to Charge/Set climatisation and you have two time slots available,
I have 1st one set for Mon-Fri at a time and second one on weekend setting. You have to scroll below the time setting and there's a Mon-Sun bar. If you do this it opens a 3rd time slot and I assume a 4th etc. |
01-16-2020, 03:36 PM | #17 | |
Rep 534
01-16-2020, 03:39 PM | #18 | |
Rep 534
01-17-2020, 12:55 AM | #19 | |
Rep 829
01-17-2020, 01:33 AM | #20 |
Rep 283
01-17-2020, 12:30 PM | #21 | |
Rep 829
01-17-2020, 12:45 PM | #22 |
Rep 98
Thank you! Today i had a different issue, I plugged it and it started charging and did not stop... even it is scheduled! I keep having the departure time and the charging time frame, but it was charging immediately... why?? Any hint of what to do when this happens? On top of waking up at 3AM to plug it...
