2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Spotify on iDrive
      01-17-2020, 11:13 AM   #1
Chuckyarla
Ireland
297
Drives: G11 730d M-Sport 2018
Spotify on iDrive
Using Spotify on Apple Car Play on the idrive screen it won't let me see or select Liked Songs. Can you connect with a cable to get a better connection?
Also, can you increase the daytime brightness of the idrive screen?
      01-18-2020, 11:45 AM   #2
tricky6
Drives: G20 330e M Sport+
Not sure on Spotify but you can't use a cable to connect, it's wireless only. I've not found it too bad but every now and then it does drop out. There is an option in iDrive to change the display brightness. If you swipe the screen down with your finger from the top I think there is a menu item for screen settings. Or go to Car-Settings and one of the menu options is Display where you can change the brightness.
      01-18-2020, 12:11 PM   #3
Chuckyarla
Ireland
297
Thank you. Are you sure the brightness setting isn’t just for nighttime?
      01-18-2020, 02:49 PM   #4
Osxboy
Drives: G21 320d
There’s a physical scroll wheel in the area that contains the buttons for the lights just to the right of the steering column (RHD Cats)
      01-18-2020, 03:10 PM   #5
Tam the Bam
Grumpy Old Git
Tam the Bam's Avatar
443
Screen dimming has been a problem with heavy window tints. I don’t believe there is any manual way to make it brighter.
There is a whole discussion here..... worth a read.
https://g20.bimmerpost.com/forums/sh...hlight=Dimming
And here
https://g20.bimmerpost.com/forums/sh...Screen+dimming
Retired:
F10 520D M Sport
E60 520D SE
Volvo S60 type R
