Technical Topics DIYs and Coding Discussions Can you code Intelligent Cruise Control?
      07-14-2023, 07:03 PM   #1
nm2003
2023 M340i LCI xDrive (on order)
31
Drives: 2023 M340i LCI
I was reading an article about different types of ceuisw controls and it mentioned that some cars will automatically adjust to the signposted speed limit for you, without an intervention (this is typically known as Intelligent Cruise Control).
Is it possible to code this in G20 LCI using bimmercode?
Currently I have to press the "Set" button when the speed sign changes, for the adaptive cruise control to change to the current speed sign.
2023 (Australian Spec) G20 LCI M340 xDrive - Portimao Blue - Executive Pack, M Technology Pack, Carbon Fibre Trim
      07-19-2023, 06:30 AM   #2
TheNine90
Drives: bmw
Its called aSLA (Automatic Speed Limit Assistant) . Its possible to code it.
nm200330.50
      07-19-2023, 02:08 PM   #3
nm2003
31
Thanks for clarifying the terminology to use.
Has any successfully coded aSLA on an LCI model with Bimmercode?
      07-19-2023, 02:22 PM   #4
TheNine90
Drives: bmw
Its not possible to use bimmercode to code asla. You need to code some module like SAS DSC which bimmercode cant.
