04-04-2023, 06:13 AM | #23 | |
Rep 360
That should have us worried..no? |
04-04-2023, 06:54 AM | #24 |
Mad Linux Guru On The Loose
1121
Rep 5,397
Drives: 2008 335i Sedan, 2023 M3
Not having experienced it myself with S58, but having owjed a highly modified N54, this sounds like misfires at idle. The MSD80 and later ECUs have "Rough Running" control settings. They are adaptive and I believe fairly normal for direct injection engines. I would count it as normal.
On my N54, new spark plugs every 10K miles do wonders. |
04-04-2023, 07:36 AM | #25 | |
Rep 360
04-04-2023, 09:37 AM | #26 | |
1121
Rep 5,397
This "rough running" on N54 can be caused by many things: sticking injector, ignition coil that's randomly not releasing all the charge, worn out spark plug, etc. If a cylinder misses an ignition cycle, the DME will detect that, and usually the cure is to raise the idle a bit till it detects that everything is good. Remember, 600rpm means 10 crank rotations per second. If there is a single misfire event, you'll only notice a small hick-up followed by an rpm change. At least this is now things are on the N54. I am not sure exactly how this works on S58 so take everything above as nothing more than a theory.
04-04-2023, 09:42 AM | #27 |
1121
Rep 5,397
Also, one other thing I wanted to mention, in North America, we do not have OPF system like in the rest of the world. I am not exactly sure how this works, but it could be related to DME making adjustments for emissions purposes and this comes out as "unsteady" idle.
04-04-2023, 11:07 AM | #28 | |
Rep 360
This issue seems to be the same both in US and Europe. I have seen it on German forum as well. I have a much stronger concern regarding long crank when hot issue which happens intermittently. And on engine stumble when cold. And wondering if rough idle is just another symptom of that (i.e. injector failure).. |
04-04-2023, 02:53 PM | #29 |
1121
Rep 5,397
The S58 uses the same injectors as B58. The injector issues were sorted out way back with the N55 engines. I don't think it's an issue here.
04-05-2023, 08:17 AM | #31 |
1121
Rep 5,397
Oh wow. I have not seen this.
04-05-2023, 11:49 AM | #32 |
Rep 360
04-08-2023, 10:24 PM | #34 |
Rep 509
Looking like I have the same issue with a faulty fuel injector as well. I have an appointment on the 12th. Most notable symptom is long crank after the engine is warm, almost like the car doesn’t want to start. Sometimes strong gasoline smell as well after the long crank. I’ve noticed “bouncy” rpm as well, but initially thought it was just how the M3 was. Now I’m wondering if it’s related to a bad fuel injector.
04-09-2023, 02:49 AM | #35 |
Rep 119
OP checking back in. I have had the break-in service as well as the one year oil service (Don't judge me but I have tandem parking and I treat this thing like my special occasion Ferrari, but I only have about 1,700 miles on her)...but it has remained the same. It just kinda burps a lil' here and there, I truly do think it's normal or people just don't notice it. You can hear it happening as well if you are outside the car with the engine running and near the exhaust. Seems people have reported the same on 6MT and Comp so that doesn't seem to be a factor. ALSO, I find it very possible with that video of the iDrive 8 car, that BMW has added some sort of compensation to this so that it doesn't appear to the driver that the idle is fluctuating...Because it can be THAT subtle where if the tach didn't show me, I may not have even noticed at times, when it is warmed up especially, when cold would just chock it up to that.
Ok, so I don't know for sure, but I don't think the long crank is related to the possible fuel injector thing. Because my crank is 100% normal, starts up right away even after sitting (I do use a battery tender at times for what it is worth). It would be interesting to see if anyone with an iDrive 8 equipped G8X has this rev bounce, or at least has it displaying as fluctuations in the cluster. Mine has 7 and the tach does visibly do it's little thing but since it's simply a screen, I can see them adjusting the display refresh settings when at idle to not reflect this. The interesting this is that a non M (the ones I've seen) w/ iD7 don't have a fluctuation, but again, not an M and I know M idles can be a little extra. Maybe they can fix at least the way it is being displayed via software at some point. This is all speculation, but interesting the one video of a G8X not doing it, is with iD8. The plot thickens...but with no performance issues, I can't really imagine it being ABnormal...but I just think we would have seen more documentation at this point. I am a very picky/astute type of person so leave it up to me to find something odd that probably is normal. |
04-09-2023, 06:26 AM | #36 | |
Rep 360
Anyway, my car is ID8 and the idle fluctuates just the same as you describe, and I do feel light shudder from time to time. And I have the long crank, as well as stumble and die on cold start already a few times. The car performs flawlessly otherwise, the engine took a 3 day long beating at the track going all the way. |
04-09-2023, 08:28 PM | #37 | |
Rep 119
04-10-2023, 04:57 AM | #38 | |
Rep 360
That's the problem, x3m, other m3/m4 I have seen don't have this issue. They have steady idle. So it's definitely not normal. By the way, can you measure your resting battery voltage? Engine off, use the jump start connectors under the hood. I have another theory that the weak battery may be causing the floating idle.. |
04-10-2023, 01:02 PM | #39 |
1121
Rep 5,397
Unfortunately, this sounds like a deja-vu from the N54 days. Sad to see this happening 3 generations of turbo I6 engines later.
04-10-2023, 03:35 PM | #40 | |
Rep 360
For example, does cooling system or charge cooler need to be drained or stays on? |
04-12-2023, 01:47 AM | #41 | |
Rep 119
I don't have a multimeter at the moment, but I will order one promptly as I didn't realize I was without this garage essential tool. For further info, I do regularly use the rebranded BMW C-Tek trickle charger. Do you mind taking a video of your idle and that long crank at warm by chance? I will do as soon as I can drive it as it is currently blocked in garage. Thank you for your detailed analyses of these possibly related/but not confirmed issues, and now people are having a failing injector. I just wonder if the people that are claiming rough idle with a failed injector are referring to a VERY extreme rough idle and not the, for lack of a better word "small burps" that I experience, and very slight up and down movement also heard from exhaust on exterior. I know that doesn't explain the videos of some cars not doing it...but I think we need more videos of the tach of G8X S58 engines idling once warm...the more we see the more we can determine normality or not. A lot can change in a I-Step version, I haven't even gotten the most recent OTA and it's possible it exists in certain versions and not in others, granted we are also comparing US vs Euro spec. |
04-12-2023, 02:34 AM | #42 | |
Rep 360
My idle is exactly as you describe - very light shaking of the needle, and really just very seldom something that I can actually feel i.e. shudder, and barely noticeable. Whether the idle and fuel injectors are related, we will hopefully know soon when my car is brought in next week. But the original poster in another thread actually said his idle was fixed after replacing the injector. So I am hoping this is related. |
04-12-2023, 07:31 AM | #43 |
Rep 2,030
Drives: G80 M3 Competition
My G80 has exhibited choppy idle for quite some time now. Mostly smooth, but it will do the occasional burp (what almost feels like a miss). Did this when the car was bone stock, and still after being modified; intake and full exhaust.
The car starts like a champ though, and runs flawlessly. She’s coming up on 18k miles and has not blown up yet. |
Nkr151123.50 |
04-12-2023, 07:51 AM | #44 | |
1121
Rep 5,397
I have no clue how this process works for B58 and S58 engines. |
