Marketplace Members Classifieds Wheels and Tires Items 4 Goodyear f1 asymmetric 3 off set Summer Perf Rft $1,200 OR OBO Brand new!
      02-07-2022, 04:40 PM   #1
RLL RACER
Drives: BMWM8TurnerM6(2)M3's(1)Bavaria
BIMMERPOST / Classifieds
Asking Price:
Sold
Item Interest
WELCOME!
HERE WE HAVE A SET OF 4 OFF SET
GOODYEAR F-1 ASYMMETRIC 3
RUN FLAT VERSION.
ALL PRO SUMMER PERFORMANCE OUT OF THE BEST RUN FLATS AROUND!!
SPRING/SUMMER/FALL.. PERFORMANCE TIRES.
BRAND NEW!
MINT!
SIZES
(2) FRONT 225/40/R19
(2) REAR 255/35/R19
*PLEASE CHECK YOUR CARS TIRE SIZES BEFORE ORDERING.
*THESE FIT MANY CAR BRANDS WHEELS!
THESE WERE ON A BRAND NEW 2021 BMW 3 SERIES.
THE CAR WAS DRIVEN OFF OF THE BMW OEM FACTORY CUSTOMER DELIVERY SEMI. THE CAR WAS THEN DRIVEN INTO THE RACE SHOP,ABOUT 50FT AWAY FROM THE BMW SEMI HAULER, WHERE THESE TIRES WERE TAKEN OFF AND BAGGED, AND ALL SEASON TIRES WERE PUT ON THE FACTORY RIMS.
THATS IT!
THESE ARE PERFECT AND HAVE BEEN STORAGE IN THE ORIG BMW TIRE BAGS IN A CLIMATE CONTROLLED BUILDING.
THESE ARE SOME AWESOME TIRES ON TRACK OR WINDING ROADS IN WET OR DRY.
WHEN IT COMES TO PERFORMANCE THESE ARE TOPS
IF YOU GET A PUNCTURE, YOU KEEP ROLLING, THE OTHERS ARE TO A STOP!
GOODYEAR REALLY DID THE TRACK RESEARCH ON THESE.
CHECK THE SPECS AND REVEIW BELOW!
THESE ARE SHIPPED TO YOUR DOOR WITH FREE SHIPPING AND TRACKING & INSURNACE.
WOW!
BEST PRICE OUT THERE, IS RIGHT HERE!! BEATING OUT TIRE RACK AND DISCOUNT TIRE AND ALL THE REST!
THESE WILL BE SHIPPED IN THE ORIG TIRE BAGS AND IN TIRE BOXES FOR ADDIONAL PROTECTION.
I HAVE THESE SAME TIRES ON 2 OF MY OTHER CARS THAT ARE IN A WARM CLIMATE. I HAVE TRACKED AT HIGH SPEEDS AS WELL, AND THEY ARE IN THE TOP 2 TIRES FOR THIS CATAGORY!!
YOU WILL FIND THESE TO BE SOME OF THE BEST TIRES FOR YOUR HIGH PERFORMANCE DRIVING NEEDS.
PLEASE CONTACT ME BY PM WITH ANY QUESTIONS ANY PAYMENT ARRANGEMENTS.
PRICE $1,200 OR OBO FREE SHIPPING!!!
THANK YOU IN ADVANCE!
SPECS
Goodyear Eagle F1 Asymmetric 3 Treadwear and Warranty
The Goodyear Eagle F1 Asymmetric 3 is backed by a six-year limited warranty against manufacturer defects.
Max Performance Summer run-flat tires provide temporary self-supporting run-flat mobility for a distance of 50 miles at up to 50 mph, even after a puncture has allowed complete air pressure loss. They are designed for serious driving enthusiasts who want a combination of a performance appearance, competent handling and Z-speed rated (or higher) durability with enhanced dry and wet traction. Often used as Original Equipment (O.E.) on powerful sports cars, performance coupes and high performance sedans, Max Performance Summer run-flat tires are not intended to be driven in near-freezing temperatures, through snow or on ice.
Goodyear's warranty states: "Ultra high-performance summer tires are not recommended for winter use, and tread or shoulder cracking on those tires resulting from winter use will not be covered under our warranty."
O.E. Max Performance Summer run-flat tires are typically purchased as direct replacements for worn-out pairs/sets of the vehicle's original tires. They can also be used for other vehicle applications in complete sets of four or axle pairs if available in an appropriate size, load range and speed rating to match the existing O.E. run-flat tires' performance category and specifications.
NOTE: Run-flat tires are only recommended for vehicles that are originally equipped with self-supporting run-flat tires and equipped with a tire pressure monitoring system.
The Eagle F1 Asymmetric 3 features a summer-only tread compound designed to provide superior traction through enhanced road adhesion. This compound is molded into an asymmetric tread design featuring a solid center rib for responsive steering and solid on-center feel. The tire's outer shoulder is focused on achieving maximum dry traction through turns and the inner section and four wide-circumferential grooves improve wet-weather grip and hydroplaning resistance.
The internal structure of the Eagle F1 Asymmetric 3 includes a body of polyester cord supporting twin steel belts reinforced with spirally wrapped polyamide to enhance tread stability and high-speed capability.
Limited sizes of the Eagle F1 Asymmetric 3 are available with Goodyear's Sound Comfort technology, which involves the manufacturer adhering a layer of sound-absorbing foam to the inner liner of the tire to reduce cabin noise in the vehicle. These sizes are identified on the Specs page and in the search results.
SIZE UTQG MAX.
LOAD MAX. INFLATION PRESSURE TREAD DEPTH TIRE WEIGHT RIM WIDTH RANGE MEAS. RIM WIDTH SECT. WIDTH TREAD WIDTH OVERALL DIAM. REVS. PER MILE
