06-17-2023, 08:00 PM | #1 |
Rep 16
2020 M340i Ecutek Datalog Charts (DP, FF, Custom Tune)
Hi - I have a 2020 M340i which I recently had custom tuned on ecutek along with a catless dp, visconti ff kit and a xhp stage 3 trans tune.
My vehicle has the xdrive and we were not able to dyno at the shop. In any case I've done a few pulls and logged data. ethanol content on both runs was 50 TQ I am discounting 25% for Drivetrain loss (to be conservative) HP I am calculating as TQ*RPM/5252 Boost PSI values as is. I was thinking the values for HP would show maxing around 500 but am pleasantly surprised to see the numbers hitting north of 550. Am I missing something? Please take a look; other values in the chart are boost in psi. this is on a stock turbo. sorry for the large image sizes. Last edited by karayel; 06-21-2023 at 10:09 PM.. Reason: added xhp stage 3 trans tune to list of mods |
06-18-2023, 02:08 PM | #2 |
Rep 244
Well assuming 25 % drivetrain loss is not really reasonable so ya it’s going to make your crank number look higher than it really is. Or is that a typo and you meant 15 as your numbers seem pretty believable given your mods
06-19-2023, 12:19 AM | #4 | |
Rep 16
I was thinking I’d be at 500-520hp range on e50. So was just surprised to see it north of 550 . I’ll do a similar log when I’m on 93 to see how the numbers compare and share it here… it’ll just take me a couple weeks to run through the tank though. I’m curious myself. A true dyno test will be most accurate I know.. will make it out there to eventually. |
06-19-2023, 12:21 AM | #5 |
Rep 16
06-21-2023, 09:56 PM | #7 |
Rep 16
06-23-2023, 05:27 PM | #8 |
Rep 1,521
06-24-2023, 08:32 AM | #9 |
Rep 126
Chubbiejones891.00 |
06-24-2023, 09:05 AM | #10 |
Rep 1,521
06-24-2023, 09:41 AM | #11 |
Rep 524
AWD are typically 15% drivetrain loss, with RWD around 12%. I’d say dont get hung up on these numbers and slap a dragy on and do some 1/4 mile or 60-130 pulls to get a better gauge of how shes doing.
06-27-2023, 11:05 AM | #12 |
Rep 819
Drives: 2021 BMW X3 M
Highly recommend them. I also switched to racebox on ecutek.
2014 BMW 335i M-Sport - SOLD
07-01-2023, 02:31 PM | #14 |
Rep 819
It drives great. I have a flex fuel sensor so I can run anything between 93 and e85 and the car will automatically make changes on the fly. (I also have port injection on my car). I switched from a bigger bmw tuner and my drivability is better on the racebox tune.
07-01-2023, 07:57 PM | #15 | |
Rep 1,521
08-25-2023, 06:57 PM | #17 |
Rep 819
You can run full e85 on port injection. Yes, it helps on 93 but only really useful on full e85.
08-25-2023, 06:58 PM | #18 |
Rep 819
Yes, visconti flex fuel kit, visconti motiv reflex + pnp harness + eos port plate/ID1050x injectors. Stock LPFP, stock turbo.
08-26-2023, 06:36 PM | #19 |
Rep 1,521
08-26-2023, 10:30 PM | #20 |
Rep 819
Works great and is super easy to install. I had zero issues with it. Everything was working right when I installed it. The hardest part is getting all the wiring into the car because the cutout on the m340i is TINY versus the supra's cutout on the passenger side firewall. But for the FF kit it's not bad. For PI, it was bad.
