03-29-2024, 10:14 PM | #1 |
Rep 5
G22 Lift Points and Jack Stand Placement
I'm new to BMW and have searched the forum for the subject above and have not found any definitive information for my 2021 430i Coupe. What I DID find were several debates on whether or not there's a central point up front between the front wheels and another at the differential with some even stating that BMW specifically says these work for previous generations (Fnn series and such) but NOT the 'all new / redesigned' chassis of the G22. Does anyone know for sure?
I was hoping to find info like this in a sticky FAQ article under general maintenance but that has not happened. If anyone could point me in the right direction I would very much appreciate it. My first project requires I get the nose of the car in the air with both front wheels removed so I'm stalled until I find out how to elevate & support it safely with a floor jack and jack stands. There's a video out there of a guy looking for a Darwin Award using a hydraulic floor jack on each of the front factory jack points with both front wheels removed with NO jack stands at all. He's under the car working and just a seal failure away from death or WORSE (What's worse? A lifetime as a vegetable, that's what's worse.). I can't understand it... :-( Barry Last edited by Barry A. Waters; 03-29-2024 at 10:27 PM.. |
03-30-2024, 08:35 AM | #2 |
Rep 85
On my G20, i was able to drive the car on ramps, then raise the rear by putting a 2 inch rubber puck OR 4x4 pressure treated between the rear diff subframe and jack. Then crawl under the front, remove the undersheilding which reveals a metal subframe. I put a big rubber puck between the jack and subframe and then lifted the front of the car. At that point its on 4 stands. This is how i did it when i serviced my transmission.The puck left a beauty mark but did not indent the subframes at all. These cars are very heavy. I dont like doing it.
Barry A. Waters1.50 |
03-30-2024, 04:40 PM | #3 |
Rep 5
That's one way to do it! I finally found a post that shows the G22 DOES support central lifting from a front location AND the rear differential. Check out the info from Opie55 near the end of the post. Some good manual page & photos there BUT NOTE that the front location is slightly different between the all wheel drive cars and the rear wheel drive cars:
https://g20.bimmerpost.com/forums/sh....php?t=1976547 The downside is that you need a really LONG low profile jack to reach the front spot. I don't know about the rear differential spot but will check that soon. I have a couple of low profile jacks but they are just not long enough for the front spot so it's either ramps like you did OR 6x6 blocks (via jacking at the factory front side points first) temporarily under the front wheels to be able to get my jack in the correct position. I can work with that. Barry Last edited by Barry A. Waters; 03-30-2024 at 04:46 PM.. |
03-30-2024, 07:21 PM | #4 | |
Rep 85
