02-17-2024, 10:07 AM | #1 |
Rep 37
Drives: 2020 bmw 330i
Max rim width
Hello everyone, i have a 2020 bmw 330i sport line that came squared from factory 225/45/18. Im not sure about the width of the rims. My question is, if i get aftermarket rims, what is the best width i should get (front and rear width)? And what is the widest rim width (front and rear) i can fit without any bodywork without rubbing or hitting any suspension parts, frame, body, etc. information/advice on both square and staggered set up.
Thank you. |
02-27-2024, 08:38 PM | #2 |
Rep 17
Wondering the same, i have a 2019 here. Looking at a nice set of wheels new/used and im not sure if they will fit they are 19x9.5 all around.
The guy had them on his m340, limited info on this set up. |
02-29-2024, 07:08 AM | #3 |
Rep 17
So i did some research and 9 in the fronts and 10 in the rears fit fine.
if you go with a 9.5 all around like i am going to, you will need a 5mm spacer in the front. will have an unnoticeable amount of poke, but i think it looks a little more aggressive. driving to pick up the wheel in the next week or so, ill keep you updated on here. |
G20agba4.50 |
03-09-2024, 12:32 AM | #4 | |
Rep 37
