Technical Topics Cosmetic and Lighting Modifications (exterior & interior) Carbon Fiber Cosmetic issues under clear coat
      08-06-2020, 10:09 PM   #1
HXTX20
Drives: '23 M3 Comp, '23 X5 45E
Wondering if anyone else here have had issues with aftermarket CF trim parts showing cosmetic issues? I have carbon fiber mirror caps and rear spoiler that are both showing white cosmetic markings, and the CF caps are showing lifting in some areas. All the areas of damage are smooth to the touch.
Is this just an issue with the quality of the carbon fiber? It's odd the damage is happening under the clear coat which should be sealing everything. I got these parts for under 200 eachon ebay and have had them on for less than 3 weeks. I live in Houston where the weather is pretty hot and humid. Both sellers are offering replacements but I'm not sure it's even worth it if this is just going to happen again.
      08-06-2020, 10:26 PM   #2
PortimaoMystique
PortimaoMystique's Avatar
Drives: BMW M340i
Where did you purchase from? Which seller? Also how long have you had them?
G20 M340i portimao blue
      08-06-2020, 10:35 PM   #3
HXTX20
Both bought on ebay. CF mirror caps from bulbxpert ($150). Spoiler from IkonMotorsports ($190)
Spoiler installed for 3 weeks, mirror caps for 2 weeks. Driven less than a thousand miles with both parts.
      08-06-2020, 10:40 PM   #4
PortimaoMystique
Drives: BMW M340i
I have the same mirrors and mine have been fine. With exception that right one isn't completely flush with the housing but that's expected.
      08-06-2020, 11:10 PM   #5
HXTX20
I had the same problem. I took a dremel to the plastic brace that extends out the farthest and trimmed it down. When I measured it, it was about 0.5" long, but the mirror housing cavity was only about 0.35" deep for said brace.
Had a perfect fit after that. Anyways, thanks for the reply and I'll see if replacements will fare better.
