2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) General G20 Sedan / G22 Coupe / G26 Gran Coupe Discussions Electric Trunk Spring Sound Normal?
      08-10-2020, 02:15 PM   #1
exhibhooligan
exhibhooligan's Avatar
Drives: 2022 430i Gran Coupe
Periodically the electric trunk (electric open and close) will make a spring type sound on the right side. For me it's only been when pressing the button and having the trunk close.
The car has 1400 miles on it so maybe it's just "breaking in sounds". Trunk functions correctly basically just sounds like the spring expanding and contracting.
Wondering if anyone else has this sound either with the electric trunk or manual trunk.
      08-11-2020, 12:30 AM   #2
Bmwphile
Bmwphile's Avatar
Drives: 2020 G20 330i
Not sure if its the same sound, but I had the left boot (trunk) hinge rubbing against the boot trim aperture, whenever it was opening or closing. Dealer adjusted trim and noise was gone. Simple!
BMWphile
2020 G20 330iM Sport (Tanzanite Blue), Visibility, Comfort, HK
2012 F30 328i Sportline (Mineral Grey)
      08-11-2020, 12:59 AM   #3
exhibhooligan
Hm that's interesting. I'll do some investigating tomorrow to see if anything is visibly rubbing.
To my ears it sounds more like a distinct spring sound. Like when a spring has tension and then the tension is released. It's not loud... but it's noticeable at times.
      08-11-2020, 06:07 PM   #4
phayze
Drives: BMW
Mine had a little spring sound on it, i spray some dry lube at the spring and the sound is gone.
      08-12-2020, 09:20 AM   #5
golferboy2312
Drives: 2020 M340i xDrive
I have never noticed any sounds as you describe
      05-26-2023, 04:24 PM   #6
Remikop
Drives: BMW G20 BMW f36
Hi
did you remove the trunk trim? Or go through the trunk opening?
Thx
      05-26-2023, 09:33 PM   #7
JacobM340i
JacobM340i's Avatar
Drives: 2020 M340i rwd
2020 BMW M340i  [0.00]
  [0.00]
Mine makes that “little spring sound”
