04-08-2021, 02:14 AM | #1 |
Rep 8
Active Sound Design Menu
Recently I have found ASD Menu activation in Idrive.
You can change the sound density with it. I use Bimmercode. Headunit -- 3000 HMI --- DISPLAY_CONFIGURABILITY_ENGINE_SOUND -- ACTIVE |
04-08-2021, 06:27 AM | #2 | |
Rep 242
04-08-2021, 06:33 AM | #3 |
Rep 8
04-08-2021, 06:38 AM | #4 |
Rep 242
04-08-2021, 01:45 PM | #5 |
automotive enthusiast
32
Rep 43
Drives: G20 M340i 2021
The Engine Sound menu doesn't modify ASD sound. It opens the exhaust flap permanently in comfort and adaptive mode. Start the car in comfort, wait for the engine to heat, and select sporty, and you will hear the exhaust flap open. In Eco, the flap stays closed with every option from the Engine sound.
04-08-2021, 04:19 PM | #6 | |
1942
Rep 3,521
04-08-2021, 11:44 PM | #7 |
Rep 424
04-09-2021, 12:05 PM | #8 |
1942
Rep 3,521
No sir. I haven't figured it out yet. Which reminds me. I'll check our X3 to see if it remembers. The 2021 X3s have it but I forgot to mess around with it.
04-09-2021, 02:10 PM | #9 | ||
Member
55
Rep 249
04-10-2021, 06:12 AM | #11 |
Rep 1,165
04-10-2021, 11:49 AM | #12 |
1942
Rep 3,521
Wait. In your car, it remembers which mode you set the engine sound in even after you turn the car off completely and then back on? Did you change any other setting in BC? In my car, it doesn't (seems to be the case with many others too). It resets to the default setting once I turn it off completely and then back on.
04-10-2021, 02:08 PM | #13 | |
Rep 1,165
I set it to Sporty several days ago and have been out everyday since and its remained in Sporty. I used EsysX to make these changes: HU_MGU - CAFD_00003E52 - DISPLAY_MENU_CONFIGURATION_ENGINE_SOUND - Ausgelesen = enabled (was disabled) - DISPLAY_CONFIGURABILITY_ENGINE_SOUND - Ausgelesen = aktiv (was nicht_aktiv) |
VipinLJ1941.50 |
04-10-2021, 02:57 PM | #14 | |
1942
Rep 3,521
04-10-2021, 05:36 PM | #15 |
Rep 1,165
08-31-2021, 06:38 PM | #16 |
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Does this actually work on a 330 or is it only applicable to the 340. I know that in the X5 G05 it only works bigger 50i engine and not the 40i.
2019 X5 Alpine White M-Sport
Software Version 11/2022.31 2023 M2 (HEA) Brooklyn Gray 2021 330i XDrive Alpine White M-Sport |
08-31-2021, 11:21 PM | #18 |
Rep 380
Reports here from 330i owners says it works (after coding but with no memory). My european M440i 2021 has the menu available from factory SW from March -21, with memory. I can tell both visually and audibly that the Sporty setting opens the flap in the right side exhaust. In the balanced setting it closed the flap (at least at idle) but the external sound also changed somewhat, so my conclusion is that the menu settings changes, not only the flap and some added sound through the rear speakers, but also the engine control (at lift off etc).
I assume, if 330i (but maybe only M-sport) also has the exhaust flap it should work? |
09-01-2021, 02:45 AM | #19 |
Rep 42
G20 ASD activation need FSC Code for RAM.
(maybe need change the booster) If not have ASD in your car, engine sound menu control only exhaust flap. 330i, 330e, M340i has ASD & Flap. 320i has Flap. 320d has not anyone.
2014 ~ 2017 Chevrolet Cruze J300 1.8
2017 ~ 2019 Mercedes Benz W205 C200 2019 ~ 2020 KIA Motors YG K7 Premier 3.0 2020 ~ BMW G20 320i Last edited by Freelancer withour work; 09-01-2021 at 02:55 AM.. |
maximking107.50 |
09-01-2021, 07:42 PM | #20 |
Member
899
Rep 2,032
Coded the Sound menu and I did notice a difference. However, after coding the Sport Plus I don't think you'd need this. Suggest that if you haven't coded Sport Plus that you do so. I even got some burbles on the downshift. Let's see if my daughter notices what I did to her car.
