2019+ BMW 3 AND 4-SERIES FORUMS (G2x Generation) Local Forums UK Exhaust flap mod word of warning
      12-22-2023, 11:59 AM   #1
225
Drives: 340i
If you unplug the cable and tie it out the way, just make sure it can't move over time and then sit against the exhaust itself....
Funnily enough hot exhaust pipe and plastic only ends one way.
Luckily it was wrapped in tape which saved it a bit but still the flap is now open permanently !
I assume you can buy a replacement cable and plug but don't want a main dealer to do that as it will cost a fortune. Oh well just be warned!
P-ToK72342.00
RichardM133.00
      12-27-2023, 11:55 AM   #2
RichardM
England
133
Drives: G21 M340i LCI
I should check mine. I've not looked since I first unplugged it when I got the car.
I had a similar issue with the Audi S4 I had and I was able to get the plug ok and fit it myself.
2023 G21 M340i LCI
Previous - 2020 G21 330d M-Sport, F31 335d M-Sport, F31 330d M-Sport
      01-08-2024, 08:51 AM   #3
Neovo88
Drives: BMW g20
First dry day in ages disconnected mine. As a precaution I used some heat shrink tubing to hold together and keep water tight.
      01-09-2024, 06:13 PM   #4
vadimo
vadimo's Avatar
310
Drives: 2014 F30 320D X-Drive
2020 M340i  [0.00]
I plugged it into SST box 😃
Current Ride: 2020 G20 M340i in Metallic Black Sapphire with Individual Full Merino Ivory White and Piano Black Trim Previous Ride1: 2014 F30 M Sport 320D X-Drive Auto, Dakota Beige Leather, M Sport Brakes, Adaptive M Suspension, Paddle Shifters, 19" 403 Alloys, Folding Mirrors, Pro Sat Nav & Harman Kardon Surround Sound. Previous Ride2: 2004 E46 M Sport 320CI Auto, Montana Beige Leather & 18" 135M Alloys.
      01-15-2024, 05:38 PM   #5
mattyrallye
mattyrallye's Avatar
25
Drives: G21 LCI 330e M Sport
  [0.00]
Crikey… I can’t believe this is still a thing.
If you remove the spring circlip and hold the flap in the open position with a bit of stainless wire, you don’t have to worry as the plug stays connected. 😉
      01-16-2024, 02:45 AM   #6
sjb993
sjb993's Avatar
191
Drives: G20 M340i XDrive MHT
mattyrallye, after discovering that the Bimmercode code option doesn't keep the valve permanently open, I'm planning to do this. Did you temporarily unbolt the motor to release the spring clip, or is it easy to compress with snipe-nosed pliers?
TIA
      01-16-2024, 07:31 AM   #7
POLYPOD
Hi Vadimo
Where did you place the SST box please?
      01-16-2024, 07:38 AM   #8
vadimo
vadimo's Avatar
310
2020 M340i  [0.00]
Originally Posted by POLYPOD View Post
Hi Vadimo
Behind wheel arch and cable tied
